Highlight Top 10 Values using Excel Conditional Formatting
Highlight Top Values in Range using ExcelIn excel conditional formatting basics article, we have learned the basics of excel conditional formatting. In this and the next 4 posts, we will learn some more nifty uses of excel conditional formatting.
Let us see how we can highlight top 5 or 10 values in a list using excel as shown aside:
To do this, you need to learn the excel formula – LARGE (more on large formula)
Large formula is used to fetch the nth largest value from a range of numbers. Refer to the above link for easy to understand help on large (and SMALL too)
To highlight the top 10 values,
1. Select the range of values and launch conditional formatting dialog.
2. Assuming you have cells in the range c5: c30, In the formula we need to specify a condition that would be true only if a value is more than or equal to the top 10th value in the range c5:c30 – LARGE($C$5:$C$30,10), thus our formula will be, C5>=LARGE($C$5:$C$30,10)
3. Finally specify the formatting you want to apply. When you are done, press ok.
Conditional Formatting Rules for Highlighting Top 10 Values
That is all.
If you want to highlight the entire row instead of a cell, you should use $C5 instead of C5. Why so? That is your home work. Here is a little tip on using relative vs. absolute cell references in excel.
To highlight bottom 10 in a list, all you need to do is change the formula from LARGE to SMALL.
Download the example workbook and learn how to highlight top 10 values in a range.
In the next article
We will learn how you can search a spreadsheet full of data using conditional formatting. So stay tuned and if you havent already, join our newsletter.
Facebook
Twitter
LinkedIn
Learn & be awesome.
Welcome to Chandoo.org
Rebekah S
Reporting Analyst
Advanced Pivot Table tricks
54 Responses
  1. Hi Chandoo,
    This is awesome *****
    Khalid
  2. Oh I found the last one, (custom format hmm)
    You are an Artist Chandoo.
  3. Hi Chandoo,
    Thanks!
    -Ranjith
  4. This was very fun and challenging, thanks for posting! I found all of them (well, Sheet1 was tricky, it seems you’re supposed to find the cell and type it in yourself?). Wasn’t sure if it was cool to post the answers here or not, though. Guess I’ll post SPOILER ALERTS so you can skip the rest of the message if you don’t want to see what I came up with.
    SPOILER! SPOILER! SPOILER!
    My answers appear below.
    Sheet2: cell AB201
    Sheet3: cell J8 (Picture1)
    Sheet4: cell H9
    Sheet5: expand Chart1
    Sheet7: named range (A1:I18)
    1. Wookie – I would love to get a walkthrough of HOW you figured out sheet 1 and a bit of a formula walkthrough for Sheet 6.
      1. Hi Rachel,
    2. I agree, this was a fun way to test your ability to navigate through the functionality of Excel! And since you already posted the SPOILER ALERT warning, I should be safe posting a reply to your comment with some solutions of my own… 🙂
    3. I must admit sheet 7 defeated me, but I have some corrections
      Sheet 6 – I corrected to
      1. I know; that was weird. I did try using a LEFT formula, but I kept getting the $ prefix from the cell address. So I tried a couple of variations using MID and it gave me the result I needed. This is actually the first time I’ve ever tried using a MID formula starting at the first character, but I wasn’t trying to spend a lot of time on it, so I went with what worked.
  5. —–Spoilers———
    Alternate Solutions
    1. @ Rob
      1. @ Navdeep I found PAN3489 by going to “Formulas” and then “Name Manager” and saw there was a field called “Clue1” listed in the Name Manger that references 3489. Finding PAN as the column index was just a bit of a lucky guess through trial and error. Then a note in cell PAN3489 when you navigate there says to try “typing something.” I tried scrolling through the Format Cells menu to see if the text typed in the cell needed to be formatted a certain way, and noticed that “1= Panda” was listed in the custom text menu and tried it. A bit brute force, but I think the desired text entry.
  6. Sheet 1: The answer is not type in Panda. Type 1. There’s a special formatting that replaces 1 with Panda.
  7. WOW! I’ve just found the secret eighth PANDA!
    Truly awesome!!!
    Btw, thanks for the puzzle!
  8. It was truly a artists work
    chandoo you are grate
  9. Guys I Got 8 PANDA in the workbook… 🙂
    Here is the full list:
    2) Sheet2: Goto Cell AB201
    4) Sheet4: Goto Cell H8
    1. 1) Sheet1: Type 1 in Cell PAN3489
      4) Sheet4: Goto Cell H9
    2. Actually, for sheet7, if you set the zoom to 39% or less, you will see the word PANDA. Yet another PANDA! 🙂
  10. Hi,
    Thanks,
    Ram
  11. Hi Chandoo!
    Sheet 1: ??
    Sheet 2: ??
    Sheet 3: Cell J8
    Sheet 4: Cell H9
    Sheet 6: B2
    Sheet 7: ???
  12. I love this time of year and look forward to Chandoo’s egg hunts. Whilst I got all the pandas, I do not understand how sheet 7 works; Where is the source data and why does it only work when zoomed out to 39% or more?
      1. Ha ha, that’s fantastic. Thanks Hui. @Chandoo, thanks for yet another method to decrypt worksheets in order to re-build or explain them better to clients.
  13. These were fantastic and kept me intrigued until I could finish them. (Had to look here for help with Sheet1!) Definitely learning a lot about some new formulas. Awesome, Chandoo!
  14. Ok, just saw the notes on the Zoom 39% on Sheet 7. Can someone explain what’s happening here and why PANDA shows up at that level?
  15. Wow, great exercise.
    Thanks 🙂
  16. Wow.. Awesome set of puzzles Chandoo!!
    Thanks!
    1. Looks like this is an XL feature.. Zooming out the worksheets below 40% level, by default displays all named ranges (more than 2 cells)! Had not come across this till date..
  17. Great works! Was having FUN in finding the pandas. Thanks.
Leave a Reply
