Display Alerts in Dashboards to Grab User Attention [Quick Tip]
Share
Facebook
Twitter
LinkedIn
Dashboards can be overwhelming with lots of details and context. A simple way to drag user’s attention to important stuff in the dashboard is to use alerts. See this example to understand what alerts mean.
Alerts in Dashboards grab user attention and prompt them to take action
How to display alerts in Excel Dashboards?
The easiest way to display alerts is to use Excel 2007’s Conditional Formatting feature – Icon sets.
[Excel 2007+]
Alerts in Dashboard - Data Setup
Assuming you have a table in dashboard like above (data),
  1. Select the alert column and go to Conditional Formatting > Icon sets > 3 Traffic Lights (unrimmed)
  2. Now, go to Conditional Formatting > Edit Rules
  3. check “Icons in reverse order” and “Show icons only” buttons and you are done!
    Conditional Formatting Settings for Alerts in Dashboards - Excel 2007
[Excel 2003]
  1. Add an extra column next to Alert column.
  2. Here type the formula =IF(C1,CHAR(152),"") [assumes column C has alert data]
  3. Select the column and set its font to “Wingdings 2” and color to Red. The Char code 152 is a big black circle in wingdings 2 font.
Do you use Alerts in Dashboards?
I think alerts add richness to dashboards and prompt users to take action. But too many alerts can be distracting. I have used alerts by showing red color dots or circles in dashboards to draw my manager’s attention to certain points.
What about you? Do you use alerts in dashboards? How do you automate them? What technique do you use? Share your ideas and tips using comments.
More resources on Excel Dashboards:
Facebook
Twitter
LinkedIn
Learn & be awesome.
Welcome to Chandoo.org
Rebekah S
Reporting Analyst
Advanced Pivot Table tricks
24 Responses
  1. I’d suggest simply using the subtotal function and filtering the data using the Win/Loss column.  You get the same results and the formula is more comprehensible.
    1. @John
      That is one option.
      There are times however when you want to see the whole data table or a filtered subset and still want to produce summary reports against an unfiltered field.
  2. Is there a particular reason why you are using a comma and the unary (–) operator for the second array in the SUMPRODUCT formula?  It seems to work the same if you were to string the arrays together using the asterisk (*).  The advantage is that SUMPRODUCT treats the entire string of arrays as a single array.
  3. Is there a way to do this on a large set of data? As in ~100,000 rows? When I try I get an error because the formula becomes too long. It says the max length of a formula is 8,192 characters. Excel 2010.
  4. How do I incorporate a specific text within a cell for the second array. For instance, – -(C7:C13=”Apple”)
    when I chose a specific text the formula does not work.
    1. @RB
      I am not sure what is the issue as if I use the sample data in the post the following work fine
      Count:
      =SUMPRODUCT(SUBTOTAL(3,OFFSET(C7:C13,ROW(C7:C13)-MIN(ROW(C7:C13)),,1)), –(C7:C13=”L”))
      Sum:
      =SUMPRODUCT(SUBTOTAL(3,OFFSET(C7:C13,ROW(C7:C13)-MIN(ROW(C7:C13)),,1)),(C7:C13=”L”)*(D7:D13))
      You may want to check that there are no leading or trailing spaces in your list of Apples
      1. I should have given a better explanation. Heres my situation. I have a column with cells filled with names like Column 1, Column 2, Pier 1, Pier 2, etc. If the cell just contained Pier and searched for that it works. But because it has other characters in the cell its not recognizing the pier. So how can I extract specific characters of a string of text in this formula?
        Hopefully this was a better explanation
  5. Hello-
    This formula works pretty well for me except that it slow down excel and prevents some of my macros from working. I was wondering if there was a way to program this in VBA so that excel isn’t always trying to recalculate it. I would like to use a push of a button to get it to run then paste in a cell.
    Thanks!
  6. I am trying to sum filtered data in a column, but would want to ignore the negative values in the column. How to go about doing this?
      1. The negative values are required for reporting purposes, but their effect on the total is distorting the required output. Please advise.
  7. I have this working for counting and summing, however, I have a list and for the second array, I need a criteria. That is, I’m looking for b13:b200=”01.??.??” or =left((a1,2) or something like that. These types of criteria matches do not appear to work as I get a blank as a result.
    Thanks!
    1. @Bob
      As your formula b13:b200=”01.??.??” looks like you are trying to check the first day of the month of the range
      What about trying Day(B13:B200)=1
  8. Hai Experts,
    i understood this formula well and working fine in MS Excel 2013
    but when the same am trying to place in google Spreadsheet it shows error as
    “SUMPRODUCT has mismatched range sizes. Expected row count: 1. column count: 1. Actual row count: 2014, column count: 1.” and as a result #VALUE! Appears in cell.
    Can anyone please help me how would i get it done in Google Spread sheet
    or is there any other formula as a substitute for this.
    Thank you very much.
    1. @Vivek
      I don’t know
      I just downloaded the file and it is working fine and not showing that error
      Goto the Formulas, Calculation Options Tab and check that Calculation is set to Automatic
      What version of Excel and Windows are you using ?
  9. I know that this forum is for MS Excel, but I am trying to help someone who is working in Google Sheets. The below formula works in Excel but Google Sheets returns:
    “SUMPRODUCT has mismatched range sizes. Expected row count: 1. column count: 1. Actual row count: 39000, column count: 1.” and as a result #VALUE! Appears in cell.
    This is the same problem asked by Srichirin above. Does anyone know if there is a formula for Google Sheets that will replicate what MS Excel does?
    =SUMPRODUCT(SUBTOTAL(3,OFFSET($C$6:$C$39500,ROW($C$6:$C$39500)-MIN(ROW($C$6:$C$39500)),,1)),- -($C$6:$C$39500=H1),($D$6:$D$39500))
  10. Trying to find a SUMPRODUCT formula that counts the word Closed by date for the last 7 days in a filtered list.
    =COUNTIF(M:M,”>”&TODAY()-7) works ok for unfiltered count Column M contains Closure dates (blank if open) and Column L is Status Open or Closed
  11. I used this formula and worked like a charm! But, now I’ve been requested to use it but adding not one but two criteria in the same formula. For instance the sum I was doing added negative and positive numbers. I’ve been asked to use the exact same formula but adding that only positive numbers were considered… any idea on how to do this?
  12. Thank you so much brother literally I have been struggling since morning to get the sum of the filtered category, however, after reading your blog attentively i got my solution, so thanks a lot once again.
Leave a Reply
