Power Query (Get & Transform data in Excel 2016) is a must have tool, if you wrangle with data every day. Here is a quick introduction, in case you are new.
Let’s learn how to use Power Query to unpivot data.
Essentially, we are trying to go from left to right in this picture.
Doing something like this thru either formulas or VBA can be very complex. But Power Query can get you unpivoted data in just a few clicks. Sounds interesting? Read on.
Tutorial: Unpivot data using Power Query
Step 1: Set up your pivoted data as a table
If you want Power Query to work with data in Excel, it must be in table form. So select any cell in the pivoted data and press CTRL+T to turn it in to a table.
At this stage, we get this:
Step 2: Load table data in to Power Query
While keeping the selection inside pivot data, go to Power Query ribbon (or Get & Transform area of Excel 2016 data ribbon) and click on “from Table” button.
This will take your table data and load it in to a new query in Power Query. It looks like this:
Step 3: Get rid of grand totals
When unpivoting data, we don’t need the grand totals. To remove them,
- Select the grand total column
- Click on “Remove Columns” button in query editor (Power Query window)
- Click on “Remove Rows” button, select remove bottom rows option.
- Enter the number of rows as 1
At this stage, grand total column & row are gone. We end up with this:
Step 4: Fill down the missing region names
If your pivot table has null / blank values in the first column, you can fill them with values from above cells using the Fill option of query editor. Select the Region column and click on the Fill button from transform ribbon. See this demo:
Step 5: Remove sub-total rows by filtering them away
Click on the filter button next to region and filter away all the sub-total columns too. We don’t need them for unpivoting.
Step 6: Unpivot the data
Now that our data is in correct shape, let’s unpivot.
Select the last 3 columns and click on Unpivot columns button in Transform ribbon.
And we get the unpivoted data.
You can load this data to Excel or to your data model for further processing.
Download example Power Query workbook
Please click here to download the example workbook for this tutorial. To examine the query settings and power query steps,
- Open the workbook
- Go to Power Query ribbon (or Data ribbon in Excel 2016) and click on Workbook Queries Show Pane option.
- Right click on “Unpivot Data” query and choose edit
- This opens the query editor. You can examine the steps in the query steps pane to right.
Learn more about Power Query / Get & Transform data:
Power Query (or less intimidating Get & Transform data in Excel 2016) is an impressive technology to help you deal with common data problems easily. If you are an analyst who relies on Excel, learning Power Query is going to make you super productive. Check out below tutorials to get started with this amazing feature.
- Introduction to Power Query – podcast
- Importing web data using Power Query
- Recommended Power Query training from Ken & Miguel
How do you unpivot your data?
I used to write VBA programs to unpivot my data. But now that I have Power Query, I use it anytime I need unpivoting.
What about you? How do you unpivot your data? Please share your thoughts and tips in the comments section.
19 Responses to “Free Invoice Template using Excel – Download”
Nice post! Invoicing for the small biz or solo entrepreneur is something I see a lot of interest in. Also there are great templates from http://office.microsoft.com/en-us/templates
This is awesome.
I would need a little more. e.g. say I generate a Inv. # 1 with all the details. Once done I can click a button all the relevant details gets stored in some table. Further, when i generate a new invoice those details gets stored in same table but just below the previous invoice.
Is their a way to do this?
I did create a solution you are looking for, however its wrapped in a larger 'Medical Scheduler' and it uses VBA, But you can Save, Update, Lookup, Email, Print & Apply Payments to the Invoice.
You are welcome to download it here:https://www.dropbox.com/s/2yvo0o2tgq9quhe/Medical_Massage_and_Salon_Application-Free.xlsm
The Invoice Items are created from the Appt. Types & Service Items table.
I would love all feedback from this
Thank you for sharing. I will definitely have a look at it.
Daily dose of Excel held a competition in 2005 for this same topic
It obtained 9 solutions which are shown:
http://dailydoseofexcel.com/archives/2005/10/27/invoice-app-the-results/
[…] http://chandoo.org/wp/2014/03/19/free-invoice-template/?utm_source=feedburner&utm_medium=email&a… […]
How can i removed Dollar Sign, As want to use this in india.
Please reply.
Also if possible then can i use Indian Rupee Sign and how?
Hi Chandoo,
Thanks for sharing this invoice template, Let me tell you this template will definitely help me since I got a process to handle where this invoice piece comes. Just a small doubt, can we store all the invoice details in PRODUCT & SERVICES sheet. So that whenever I select an invoice number from invoice sheet I can take print out and I can share it as well. Can we do that?? Since I will be dealing with this on monthly basis.
It would be great if you can help me with this.
Thanks in advance for your help!
Gaurang Mhatre
Hi Chandoo,
I was thinking learning excel is quite tuff task but your blog proved me wrong. You made it very interesting. Thank you. Also the template you have provided for Invoice is very helpful to us.
Thanks thanks thanks.. Very helpful. 🙂
Hi i love the speadsheet but would like to ask how do i get it to add the description into the invoice as well
Hi Randy, I tried to download one of your link "https://www.dropbox.com/s/2yvo0o2tgq9quhe/Medical_Massage_and_Salon_Application-Free.xlsm" However, i found the link unavailable. Can you please help me get the new link or can you please send this VBA file on my Email-ID.
Hello Anuj,
Thanks for alerting me to the broken link. This one should work:
https://www.dropbox.com/s/gz89gshex1ad0ex/Medical_Massage_and_Salon_Application-Free.xlsm?dl=0
Please let me know if you have any questions.
Randy
Thank you so much Buddy. will check and revert you soon.
Hi, is there any chance that this can work with the "Products & Service" sheet outside of the Invoice sheet. I create multiple invoice files for the numerous clients. Updating the product sheet for each of them maybe a task. Hence, I want to create a MASTER FILE from which data can be picked up without having to insert new data in each of the invoice files.
Possible? Or am I asking for the moon 😉
Thank you so much for tutorial.
This example can be reviewed for the example of the advanced invoice that made with excel userform :https://youtu.be/Qr-4of-38DI
Good Day
i love this template may i ask if it could be modified to have the following
when you lookup a item code in the next column to the right it brings up the description then the quantity, unit cost, discount and then total otherwise i love the template
Item Code Description Quantity Unit Cost Discount Total
When creating an Invoice template in Excel are you able to utilize the auto row height and wrap feature when the cell is a merged cell? I need to have a number of cells merged together to allow for enough space to type in the description of work performed (lets say cells A-D are merged in each row) however it seems that I am unable to utilize the auto format feature. To work around this I have to manually increase the row height after each entry. Is there a better solution for this? Thank you!
