Last week we learned how to create dynamic hyperlinks in Excel. Today, I want to show you something even cooler. An interactive dashboard based on hyperlinks, like this:
Isn’t it impressive?
Well, to create something like this, you don’t need a degree in advanced cryogenics. You just need a bunch of data, a chart, a one line macro code and some pixie dust (go easy on pixie dust).
5 Step Tutorial to Create Interactive Dashboard using Hyperlinks
Step1: Setup your data
It is no wonder that any good chart or dashboard exercise must begin with data setup. So, the first thing we need to do is, to set up our data.
If you observe carefully, you will realize that we just have one chart and we are changing the chart’s source data based on which option user selected.
So, assuming you have 4 series of data – sales, expenses, profits & number of customers, we will add fifth series. This will always show data for the series that user selected. Like this,
Lets call the series name in fifth column as “valSelOption“. Lets assume that we will use some sort of magic to change the series name.
Note: Using this series name, we can fetch the position of the series out of 4 with MATCH formula. Once you know the position, You can fetch corresponding values using INDEX() formula.
Step 2: Create a chart from the series 5
This is very simple. Just create a chart from the data in 5th column as above. You can format this as you want.
Step 3: Create the dashboard area
This is a bit tricky, but easy too. Just set up 4 column area (since we have 4 charts) such that you can place your chart and mouse-over cells for selection. like this,
Step 4: Create Roll-over effect
Now comes the magical part. We need a simple macro or UDF to change the series based on where user pointed the mouse.
But how to activate that UDF on mouse rollover?
This is where we can use Hyperlinks.
Do you know that you can use a UDF as source for hyperlink.
Just like we can write =HYPERLINK(“http://chandoo.org/”,”Click here”)
we can also write =HYPERLINK(myFunction(),”Click here”)
And Excel would run your function when user clicks on the link.
But, there is more to it.
Excel would also run the function, when you place your mouse on the link. No need to click!
But, seasoned VBA programmers would know that Functions are not allowed to change values in other cells or format them. Well, that restriction does not apply if you use a function from Hyperlink!!!
So, we would write a one line function – highlightSeries(seriesName as Range) and put this code in there.
Public Function highlightSeries(seriesName As Range)
Range(“valSelOption”) = seriesName.Value
End Function
This function would take the series name as a variable and assigns it to named range valSelOption. As the valSelOption changes, so does the data for our chart and then we get new chart.
Now, we just write this hyperlink formula in all the 4 cells, like this:
(Assuming the series names in B3:E3)
=IFERROR(HYPERLINK(highlightSeries(B3)),"6")
Why this formula works?
- While using a UDF inside HYPERLINK() works the trick, Excel would also throw up a #VALUE! error. To fix it, we use the IFERROR()
- The number 6 is the down-arrow symbol in webdings font
- So, change the cell’s font to webdings!
Now, drag this formula sideways to fill in all 4 cells.
Note: Word-wrap the hyperlink cells so that the link works when you hover anywhere on the cell, not just the down-arrow symbol.
Step 5: Add Conditional Formatting to highlight selected series’ name etc.
This is optional, but just as awesome. Once you add conditional formatting, the dashboard feels slick and interactive.
That is all. Your interactive dashboard is ready.
Download the Example Workbook
Click here to download the interactive dashboard workbook and play with it. Examine the technique, formulas and UDF code to see how it is weaved together.
Special Thanks to Jordan:
Many thanks to Jordan, who blogged about this technique on his OptionExplicit VBA blog. He reviewed my file and gave me few suggestions too. He made an interactive snake application using this technique. You can download that file from here.
How do you like this technique?
I like the possibilities of this technique. However, it is also a bit tricky to explain. So I will use it with caution. (Also, I am not sure if this would slow down Excel, but in my experience it did not)
What about you? Do you like this idea? Are you going to experiment with it? Please tell me how you are planning to use it thru comments.
More techniques for Dashboard Makers & Analysts
If you work with Dashboards or data analysis, then you are at the right place. We have a wealth of information, tutorials, examples & ideas for you. Please check out a few below:
54 Responses
Hi Chandoo,
This is awesome *****
Khalid
go to AB201 on Sheet2, you will see Panda there !!!
Press F2 in Cell A1 and then read the actual text !!
In Sheet 2 go to Cell AB201. You will find one.
There is one on first sheet, if you press F5 (goto), the word PANDA can be seen there.
Oh I found the last one, (custom format hmm)
You are an Artist Chandoo.
Hi Chandoo,
Thanks!
-Ranjith
yeah! found all 7 panda, time to go to china.
This was very fun and challenging, thanks for posting! I found all of them (well, Sheet1 was tricky, it seems you’re supposed to find the cell and type it in yourself?). Wasn’t sure if it was cool to post the answers here or not, though. Guess I’ll post SPOILER ALERTS so you can skip the rest of the message if you don’t want to see what I came up with.
SPOILER! SPOILER! SPOILER!
My answers appear below.
Sheet2: cell AB201
Sheet3: cell J8 (Picture1)
Sheet4: cell H9
Sheet5: expand Chart1
Sheet7: named range (A1:I18)
Wookie – I would love to get a walkthrough of HOW you figured out sheet 1 and a bit of a formula walkthrough for Sheet 6.
Hi Rachel,
I agree, this was a fun way to test your ability to navigate through the functionality of Excel! And since you already posted the SPOILER ALERT warning, I should be safe posting a reply to your comment with some solutions of my own… 🙂
I must admit sheet 7 defeated me, but I have some corrections
Sheet 6 – I corrected to
I know; that was weird. I did try using a LEFT formula, but I kept getting the $ prefix from the cell address. So I tried a couple of variations using MID and it gave me the result I needed. This is actually the first time I’ve ever tried using a MID formula starting at the first character, but I wasn’t trying to spend a lot of time on it, so I went with what worked.
Sheet1: Type 1 in PAN3489
Sheet6: =LEFT(ADDRESS(9,2^3*23*59,4),3)&BIN2HEX(11011010)
Slight change…
For sheet 1 goto PAN3489 and type in 1. The word PANDA appears.
Love it!
Sheet 6 was my favorite. How many people still know what binary, hex and octal are? :o)
—–Spoilers———
Alternate Solutions
@ Rob
You reach PAN3489 by pressing Ctrl + End to bring you to the last used cell in Sheet 1
@ Navdeep I found PAN3489 by going to “Formulas” and then “Name Manager” and saw there was a field called “Clue1” listed in the Name Manger that references 3489. Finding PAN as the column index was just a bit of a lucky guess through trial and error. Then a note in cell PAN3489 when you navigate there says to try “typing something.” I tried scrolling through the Format Cells menu to see if the text typed in the cell needed to be formatted a certain way, and noticed that “1= Panda” was listed in the custom text menu and tried it. A bit brute force, but I think the desired text entry.
Clever!
The Data Validation one took me a bit. Had to resort to brute force.
Thanks for the fun!
Awesome! Found 7 pandas in 20 minutes)))
Sheets 1 and 6 were the best!
Thanks!
Sheet 1: The answer is not type in Panda. Type 1. There’s a special formatting that replaces 1 with Panda.
when you changed the zoom level to 39% or below, you will see the name of namedrange (if any)
WOW! I’ve just found the secret eighth PANDA!
Truly awesome!!!
Btw, thanks for the puzzle!
Found them all – very inventive. Had to think outside the “box”. Great fun!
It was truly a artists work
chandoo you are grate
it is fun and great invent
Guys I Got 8 PANDA in the workbook… 🙂
Here is the full list:
2) Sheet2: Goto Cell AB201
4) Sheet4: Goto Cell H8
4) Sheet4: Goto Cell H9
Actually, for sheet7, if you set the zoom to 39% or less, you will see the word PANDA. Yet another PANDA! 🙂
Thanks,
Ram
Hi Chandoo!
Sheet 1: ??
Sheet 2: ??
Sheet 3: Cell J8
Sheet 4: Cell H9
Sheet 6: B2
Sheet 7: ???
Sheet1 F5
Sheet2 AB201
Sheet3 Picture1
Sheet4 H9
Sheet5 Chart
Sheet7 Zoom to 30%
I love this time of year and look forward to Chandoo’s egg hunts. Whilst I got all the pandas, I do not understand how sheet 7 works; Where is the source data and why does it only work when zoomed out to 39% or more?
@Leon-K
When you change the zoom level to be less than 40% Excel shows the Ranges which have Names applied to them
Ha ha, that’s fantastic. Thanks Hui. @Chandoo, thanks for yet another method to decrypt worksheets in order to re-build or explain them better to clients.
These were fantastic and kept me intrigued until I could finish them. (Had to look here for help with Sheet1!) Definitely learning a lot about some new formulas. Awesome, Chandoo!
Ok, just saw the notes on the Zoom 39% on Sheet 7. Can someone explain what’s happening here and why PANDA shows up at that level?
@Bryan
Wow, great exercise.
Thanks 🙂
Hi Chandoo,
Gr8 …had fun in searching it. I got 5 out of 7.
You are brilliant.
Found all except in sheet6 as not able to understand formula.
thanks
Raja Aurongzeb
I am not able to find 1st Panda, which is on Sheet1. Rest all I have found.
Wonderful Chandooji… you are brilliant.
Wow.. Awesome set of puzzles Chandoo!!
Thanks!
Looks like this is an XL feature.. Zooming out the worksheets below 40% level, by default displays all named ranges (more than 2 cells)! Had not come across this till date..
Great works! Was having FUN in finding the pandas. Thanks.
Had fun doing this, Found 5 and the rest I saw clues on here 🙂
I really enjoyed when finding the pandas.And also I am so surprised.Very Nice thought and Excellent.
This was fun! Thanks!
Nice and fun post. Thanks, Chandoo!
