This post is written by Paramdeep.
Today, let us learn how to use NPV() function in Excel & create a simple financial model.
NPV – Introduction:
If you are dealing with cash and valuations, you are bound to have come across the NPV function. If you don’t know the assumptions behind the same, I bet it could cost you your job!
Let’s take a simple project – You buy a MSFT stock for USD 100. You receive a dividend of USD 10 in the first year, USD 20 in the second year, USD 40 in the third year and then you sell it out for USD 140. If you could have alternatively put this money in bank at 10% interest rate, have you gained anything?
How do you model this in excel? In this tutorial we understand how you can use NPV to do this analysis and what kind of pitfalls you can land into!!
What is the NPV() function
Simply speaking, NPV function calculates present value of your cash flows. Let’s take a simple example first –
You invest $100 in a bank, which pays 10% interest
- What is its value 1 year down the line?
- I am sure, you don’t need any coffee to get that value – 100 x 10% is the interest and 100 is the principal that you had. So the value 100 x (1+10%) = 110
- What about 2 years?
- Simple 100 x (1 + 10%)^2 = 121
- So, if I were to ask you, the present value of a cash flow of 121, that you were to get 2 years down the line at 10% interest?
- Again simple, you told me initially, it was $100
NPV does exactly that – gets you the present value of your cash flows
The function is simple, it does all the difficult calculations for you and gets you the solution!
Beware – The function has its own assumptions!
Though the function is quite convenient, but it has its own pitfalls. And in my modelling experience I have seen a lot of people making that mistake! Lets model the situation described in the beginning (The MSFT Case). The cash flows are given to you as:
Let us see, internally what we get by modelling the NPV from the first principles and using the NPV function
You can clearly see that there are two ways of using NPV function (and each has its own assumption!)
So what is happening internally?
Usually when we start a project, we assume that the investment is made upfront (On day 0). Then the revenues, costs and the cash would start flowing in. Since the investment is made on day 0, it should not be discounted.
But when you use the NPV function, excel internally makes an assumption that even the first cash flow is at the end of the year (Per se, this is not wrong, but in normal circumstances, you make the payment upfront!).
So the right usage of the function would be to add the first cash without discounting and then use the NPV function to discount the rest of the cash flows.
If you just use the NPV function on all the cash flows, then the inherent assumption is that even the first cash flow is at the end of the year.
Few other ways of calculating NPV
When you are dealing with cash flows and valuations (typically that is when you come across the functions like NPV, etc) even small mistakes cost dear. You want to make sure that you are as accurate as you can ever be. At that point of time, if the cash is not flowing at the year ends, you can use a more powerful function in excel – XNPV. You can show it the cash and the exact dates and it would calculate the exact NPV for you. People don’t often use it as they don’t know the exact dates of cash flow!
How do you calculate the discounted cash values in your models?
I know the easiest way would be to use the NPV function. It is easy to use but at the same time could be tricky. So how do you implement such functionality in your models?
Templates to download
I have created a template for you, where the subheadings are given and you have use the functions to get the right values for you! You can download the same from here. You can go through the case and fill in the yellow boxes. I also recommend that you try to create this structure on your own (so that you get a hang of what information is to be recorded).
Also you can download this filled template and check, if the information you recorded, matches mine or not!
For any queries regarding the cash impact or financial modeling, feel free to put the comments in the blog or write an email to paramdeep@edupristine.com
Join our Financial Modeling Classes
We are glad to inform that our new financial modeling & project finance modeling online class is ready for your consideration.
Please click here to learn more about the program & sign-up.
Learn more about Financial Modeling:
Go thru these articles to learn more about Excel Financial Modeling:
- Excel Financial Modeling – 6 part tutorial
- Introduction to Project Finance
- Using MOD() function to implement frequency escalation in Excel
- Creating a P&L Reporting Model in Excel – 6 part tutorial
The article is written by Paramdeep from Pristine.
Chandoo.org has partnered with Pristine to launch a Financial Modeling Course. For details click here.
54 Responses
Hi Chandoo,
This is awesome *****
Khalid
go to AB201 on Sheet2, you will see Panda there !!!
Press F2 in Cell A1 and then read the actual text !!
In Sheet 2 go to Cell AB201. You will find one.
There is one on first sheet, if you press F5 (goto), the word PANDA can be seen there.
Oh I found the last one, (custom format hmm)
You are an Artist Chandoo.
Hi Chandoo,
Thanks!
-Ranjith
yeah! found all 7 panda, time to go to china.
This was very fun and challenging, thanks for posting! I found all of them (well, Sheet1 was tricky, it seems you’re supposed to find the cell and type it in yourself?). Wasn’t sure if it was cool to post the answers here or not, though. Guess I’ll post SPOILER ALERTS so you can skip the rest of the message if you don’t want to see what I came up with.
SPOILER! SPOILER! SPOILER!
My answers appear below.
Sheet2: cell AB201
Sheet3: cell J8 (Picture1)
Sheet4: cell H9
Sheet5: expand Chart1
Sheet7: named range (A1:I18)
Wookie – I would love to get a walkthrough of HOW you figured out sheet 1 and a bit of a formula walkthrough for Sheet 6.
Hi Rachel,
I agree, this was a fun way to test your ability to navigate through the functionality of Excel! And since you already posted the SPOILER ALERT warning, I should be safe posting a reply to your comment with some solutions of my own… 🙂
I must admit sheet 7 defeated me, but I have some corrections
Sheet 6 – I corrected to
I know; that was weird. I did try using a LEFT formula, but I kept getting the $ prefix from the cell address. So I tried a couple of variations using MID and it gave me the result I needed. This is actually the first time I’ve ever tried using a MID formula starting at the first character, but I wasn’t trying to spend a lot of time on it, so I went with what worked.
Sheet1: Type 1 in PAN3489
Sheet6: =LEFT(ADDRESS(9,2^3*23*59,4),3)&BIN2HEX(11011010)
Slight change…
For sheet 1 goto PAN3489 and type in 1. The word PANDA appears.
Love it!
Sheet 6 was my favorite. How many people still know what binary, hex and octal are? :o)
—–Spoilers———
Alternate Solutions
@ Rob
You reach PAN3489 by pressing Ctrl + End to bring you to the last used cell in Sheet 1
@ Navdeep I found PAN3489 by going to “Formulas” and then “Name Manager” and saw there was a field called “Clue1” listed in the Name Manger that references 3489. Finding PAN as the column index was just a bit of a lucky guess through trial and error. Then a note in cell PAN3489 when you navigate there says to try “typing something.” I tried scrolling through the Format Cells menu to see if the text typed in the cell needed to be formatted a certain way, and noticed that “1= Panda” was listed in the custom text menu and tried it. A bit brute force, but I think the desired text entry.
Clever!
The Data Validation one took me a bit. Had to resort to brute force.
Thanks for the fun!
Awesome! Found 7 pandas in 20 minutes)))
Sheets 1 and 6 were the best!
Thanks!
Sheet 1: The answer is not type in Panda. Type 1. There’s a special formatting that replaces 1 with Panda.
when you changed the zoom level to 39% or below, you will see the name of namedrange (if any)
WOW! I’ve just found the secret eighth PANDA!
Truly awesome!!!
Btw, thanks for the puzzle!
Found them all – very inventive. Had to think outside the “box”. Great fun!
It was truly a artists work
chandoo you are grate
it is fun and great invent
Guys I Got 8 PANDA in the workbook… 🙂
Here is the full list:
2) Sheet2: Goto Cell AB201
4) Sheet4: Goto Cell H8
4) Sheet4: Goto Cell H9
Actually, for sheet7, if you set the zoom to 39% or less, you will see the word PANDA. Yet another PANDA! 🙂
Thanks,
Ram
Hi Chandoo!
Sheet 1: ??
Sheet 2: ??
Sheet 3: Cell J8
Sheet 4: Cell H9
Sheet 6: B2
Sheet 7: ???
Sheet1 F5
Sheet2 AB201
Sheet3 Picture1
Sheet4 H9
Sheet5 Chart
Sheet7 Zoom to 30%
I love this time of year and look forward to Chandoo’s egg hunts. Whilst I got all the pandas, I do not understand how sheet 7 works; Where is the source data and why does it only work when zoomed out to 39% or more?
@Leon-K
When you change the zoom level to be less than 40% Excel shows the Ranges which have Names applied to them
Ha ha, that’s fantastic. Thanks Hui. @Chandoo, thanks for yet another method to decrypt worksheets in order to re-build or explain them better to clients.
These were fantastic and kept me intrigued until I could finish them. (Had to look here for help with Sheet1!) Definitely learning a lot about some new formulas. Awesome, Chandoo!
Ok, just saw the notes on the Zoom 39% on Sheet 7. Can someone explain what’s happening here and why PANDA shows up at that level?
@Bryan
Wow, great exercise.
Thanks 🙂
Hi Chandoo,
Gr8 …had fun in searching it. I got 5 out of 7.
You are brilliant.
Found all except in sheet6 as not able to understand formula.
thanks
Raja Aurongzeb
I am not able to find 1st Panda, which is on Sheet1. Rest all I have found.
Wonderful Chandooji… you are brilliant.
Wow.. Awesome set of puzzles Chandoo!!
Thanks!
Looks like this is an XL feature.. Zooming out the worksheets below 40% level, by default displays all named ranges (more than 2 cells)! Had not come across this till date..
Great works! Was having FUN in finding the pandas. Thanks.
Had fun doing this, Found 5 and the rest I saw clues on here 🙂
I really enjoyed when finding the pandas.And also I am so surprised.Very Nice thought and Excellent.
This was fun! Thanks!
Nice and fun post. Thanks, Chandoo!
