Learn an Excel Feature: Picture Links (or Camera Snapshots)
Share
Facebook
Twitter
LinkedIn
Learn about Picture Link feature in ExcelToday I want to introduce a new excel feature to you, called as Picture link.
Well, picture links are not really new, they are called as camera snapshots in earlier versions. They provide a live snapshot of a range of cells to you in an image. So that you can move the image, resize it, position it wherever you want and when the source cells change, the picture gets updated, immediately.
What is the use of Picture Links or Camera Snapshots?
At the outset picture links may seem like a useless feature. But they are pretty powerful. Here are few sample uses for picture links:
  • In dashboards & reports: Usually in dashboards, we need to combine charts, tables of data, conditional formatting etc., all in one sheet. When the size of these are not uniform, aligning them on output sheet could be a huge pain. This is when you can use picture links. First create the individual portions of dashboard in separate worksheets. Then, embed picture links to these portions in final dashboard. Re-size them and align as you see fit.
    See this in action: Project management dashboard in excel.
  • In micro-charts & sparklines: While Excel 2010 has native support for sparklines and other micro-charts, if you want to create a micro-chart in earlier versions of excel you have to use trickery. This is where picture links can help. You can make a regular chart and take a picture link of that. Then resize the picture so that it fits in to a small area.
    See this in action: Micro-charts using camera tool.
  • In Dynamic Charts: Since picture links are nothing but images with a formula assigned to them, you can easily construct dynamic charts & dynamic dashboards using these.
    See this in action: Dynamic chart using camera tool, Dynamic dashboard using camera tool
  • In shared workbooks: When you share a workbook with a colleague or boss, a common worry is what if they change formulas or edit something. This is where picture links can be of great use. You can embed a picture link of actual data so that no one can edit it.
How to insert a picture link in Excel – 3 step tutorial:
To insert a picture link to your data, just follow these 3 steps:
  1. Select the cells. Press CTRL+C
  2. Go to a target cell. From home ribbon select Paste > As picture > Picture link option (see image below)
  3. That is all. Your picture link is live. Move it or play with it by changing source cells.
How to paste a picture link in Excel - tutorial
Do you use Picture Link / Camera Snapshot ?
I have been a fan of picture links / camera snapshots ever since I learned about them. I have used them in various dashboards, reports, workbooks to wow my clients, bosses and colleagues. However, one problem with picture links / camera snapshots is that, they do not print well. So I avoid using them for workbooks that get printed alot.
What about you? Do you use picture links often? Share your experience, tips and ideas using comments.
Read more quick tips to become awesome in excel, in less than a minute.
PS: Donut to Hui for telling me about Picture links feature.
Facebook
Twitter
LinkedIn
Learn & be awesome.
Welcome to Chandoo.org
Rebekah S
Reporting Analyst
Advanced Pivot Table tricks
8 Responses to “Introducing PHD Sparkline Maker – Dead Simple way to Create Excel Sparklines”
  1. zak says:
    This looks like it could be very useful for a project I'm putting together right now, thank you so much. Quick & silly question, how do I copy & paste the sparkline as a picture?
  2. zak says:
    Question answered. For anyone else:
    Select chart>Hold Shift key & select Edit/Copy Picture>Paste
  3. [...] more information about PHD Sparkline Maker, please read this article and to learn more about Sparklines, read this article from Microsoft Excel 2010 blog. Also there [...]
  4. Andy says:
    Am I right in thinking that the y-axis is set automatically by excel?
    That makes it possible to get the column chart not to start at zero.
  5. Brian Basden says:
    Andy - yes, it is currently set to 'auto', which defaults to a zero base for positive values, but you can change that by left-clicking the chart, then choosing (in Excel 2007):
    "Chart Tools/Layout/Axes/Primary Vertical Axis/More Primary Vertical Axis Options"
    PUBLIC SERVICE ANNOUNCEMENT: When manually editing a chart's minimum/maximum axis values, PLEASE be sure there's a valid reason and that doing so won't skew the message shown by the data (e.g. by exaggerating differences). If in doubt, go back and read Tufte. (W.W.T.D.?)
  6. [...] gridlines, axis, legend, titles, labels etc.) and resize it so that it fits nicely in a cell [example]. This is the easiest and cleanest way to get sparklines in earlier versions of excel. However this [...]
  7. jan says:
    thanks for the work creating the template!!!!
  8. Ghazanfar J says:
    looks good
Leave a Reply
