In this article we will learn what a Panel Chart is and how you can construct a panel chart in Excel.
What is a Panel Chart?
A panel chart is a set of similar charts neatly aligned in panels to help us understand some data which has multiple variables in it.
Here is an example panel chart showing the total defects per module over the last 4 weeks.
Panel charts are also called by names “trellis displays” or “small multiples”. They are an effective way to display multi-variable data.
Why use Panel Charts?
Excel has several built-in chart types like stacked column chart, clustered column chart that can help you visualize same data. I have shown 2 alternatives below. First observe them,
As you can see these charts communicate the data very poorly (despite using same colors and other chart elements as the panel chart). This is where a panel chart shines.
How to make a Panel Chart in Excel?
There are 2 approaches to make panel charts in excel.
1. Making one complex chart that internally has panels containing individual charts (requires lots of calculations and chart formatting.)
2. Making different charts and aligning them on excel sheet.
There are merits and de-merits both approaches, but I personally prefer #2, since it is very easy to make panel charts with that approach.
Step 1: Make different charts
Very simple. Make different charts, one for each panel in your panel chart.
Trick: Make the first chart. Format it completely. Now select the chart and press CTRL+D to duplicate it. Now, using the mouse adjust the source data ranges of this new chart. That is all.
Step 2: Adjust Axis Formatting of the charts
You should set the axis minimum and maximum values for all charts at the same level. This will ensure that users can compare values from multiple panels without worrying about axis scale.
Also consider setting the axis labels of subsequent panels (other than first) to white color (or background color). Since axis has same scale and limits, there is no point in showing that in every panel.
Step 3: Align the charts
There are various alignment options possible for panel charts. I have shown a few samples below:
Depending on the number of panels, choose an alignment that works best for you. Keep in mind that when you align vertically, horizontal axis comparison is easier and when you align horizontally, vertical comparison is easier.
So align the charts in a logical order that works for you. And that is all. Your panel chart is ready to roll.
Panel Charts – Things to keep in mind:
- Make sure all panels have similar axis ranges. Otherwise your audience cannot compare panels and the chart becomes useless.
- Select the alignment that is both aesthetic and comparable
- Panel charts usually contain multi-variable data. You must figure out what is the best panel arrangement (in our case, other alternative is, Weekly panels with Defects by Modules) for your audience.
Download Excel Panel Chart Template & Example Workbook:
Click here to download excel panel chart template & examples. [Excel 2007 version here]
Panel Charts – More Resources & Help:
- Jon Peltier has written at length about Panel Charts in Excel. Here is a beautiful article showing vertical panel chart example. Here is an article on Panel Charts with Different Scale.
- Kelly O’ Day has coined the term Panel Charts and he has several useful examples of panel charts in his site Process Trends.
- Juice Analytics beautifully explains what panel charts are.
- I have written about panel charts before. Learn more from incell panel chart, Incell dot plot panel chart, and see some example panel charts in visualizing market share changes.
Have you ever used panel charts? What is your opinion?
I find panel charts very powerful and insightful. However, I hate the fact that making them in Excel is so cumbersome. (but the effort is totally worth it.) I have used panel charts in various consulting and work assignments and wowed my audience.
What about you? Have you ever used panel charts? How do you make them? What is your experience like? Please share using comments.
54 Responses
Hi Chandoo,
This is awesome *****
Khalid
go to AB201 on Sheet2, you will see Panda there !!!
Press F2 in Cell A1 and then read the actual text !!
In Sheet 2 go to Cell AB201. You will find one.
There is one on first sheet, if you press F5 (goto), the word PANDA can be seen there.
Oh I found the last one, (custom format hmm)
You are an Artist Chandoo.
Hi Chandoo,
Thanks!
-Ranjith
yeah! found all 7 panda, time to go to china.
This was very fun and challenging, thanks for posting! I found all of them (well, Sheet1 was tricky, it seems you’re supposed to find the cell and type it in yourself?). Wasn’t sure if it was cool to post the answers here or not, though. Guess I’ll post SPOILER ALERTS so you can skip the rest of the message if you don’t want to see what I came up with.
SPOILER! SPOILER! SPOILER!
My answers appear below.
Sheet2: cell AB201
Sheet3: cell J8 (Picture1)
Sheet4: cell H9
Sheet5: expand Chart1
Sheet7: named range (A1:I18)
Wookie – I would love to get a walkthrough of HOW you figured out sheet 1 and a bit of a formula walkthrough for Sheet 6.
Hi Rachel,
I agree, this was a fun way to test your ability to navigate through the functionality of Excel! And since you already posted the SPOILER ALERT warning, I should be safe posting a reply to your comment with some solutions of my own… 🙂
I must admit sheet 7 defeated me, but I have some corrections
Sheet 6 – I corrected to
I know; that was weird. I did try using a LEFT formula, but I kept getting the $ prefix from the cell address. So I tried a couple of variations using MID and it gave me the result I needed. This is actually the first time I’ve ever tried using a MID formula starting at the first character, but I wasn’t trying to spend a lot of time on it, so I went with what worked.
Sheet1: Type 1 in PAN3489
Sheet6: =LEFT(ADDRESS(9,2^3*23*59,4),3)&BIN2HEX(11011010)
Slight change…
For sheet 1 goto PAN3489 and type in 1. The word PANDA appears.
Love it!
Sheet 6 was my favorite. How many people still know what binary, hex and octal are? :o)
—–Spoilers———
Alternate Solutions
@ Rob
You reach PAN3489 by pressing Ctrl + End to bring you to the last used cell in Sheet 1
@ Navdeep I found PAN3489 by going to “Formulas” and then “Name Manager” and saw there was a field called “Clue1” listed in the Name Manger that references 3489. Finding PAN as the column index was just a bit of a lucky guess through trial and error. Then a note in cell PAN3489 when you navigate there says to try “typing something.” I tried scrolling through the Format Cells menu to see if the text typed in the cell needed to be formatted a certain way, and noticed that “1= Panda” was listed in the custom text menu and tried it. A bit brute force, but I think the desired text entry.
Clever!
The Data Validation one took me a bit. Had to resort to brute force.
Thanks for the fun!
Awesome! Found 7 pandas in 20 minutes)))
Sheets 1 and 6 were the best!
Thanks!
Sheet 1: The answer is not type in Panda. Type 1. There’s a special formatting that replaces 1 with Panda.
when you changed the zoom level to 39% or below, you will see the name of namedrange (if any)
WOW! I’ve just found the secret eighth PANDA!
Truly awesome!!!
Btw, thanks for the puzzle!
Found them all – very inventive. Had to think outside the “box”. Great fun!
It was truly a artists work
chandoo you are grate
it is fun and great invent
Guys I Got 8 PANDA in the workbook… 🙂
Here is the full list:
2) Sheet2: Goto Cell AB201
4) Sheet4: Goto Cell H8
4) Sheet4: Goto Cell H9
Actually, for sheet7, if you set the zoom to 39% or less, you will see the word PANDA. Yet another PANDA! 🙂
Thanks,
Ram
Hi Chandoo!
Sheet 1: ??
Sheet 2: ??
Sheet 3: Cell J8
Sheet 4: Cell H9
Sheet 6: B2
Sheet 7: ???
Sheet1 F5
Sheet2 AB201
Sheet3 Picture1
Sheet4 H9
Sheet5 Chart
Sheet7 Zoom to 30%
I love this time of year and look forward to Chandoo’s egg hunts. Whilst I got all the pandas, I do not understand how sheet 7 works; Where is the source data and why does it only work when zoomed out to 39% or more?
@Leon-K
When you change the zoom level to be less than 40% Excel shows the Ranges which have Names applied to them
Ha ha, that’s fantastic. Thanks Hui. @Chandoo, thanks for yet another method to decrypt worksheets in order to re-build or explain them better to clients.
These were fantastic and kept me intrigued until I could finish them. (Had to look here for help with Sheet1!) Definitely learning a lot about some new formulas. Awesome, Chandoo!
Ok, just saw the notes on the Zoom 39% on Sheet 7. Can someone explain what’s happening here and why PANDA shows up at that level?
@Bryan
Wow, great exercise.
Thanks 🙂
Hi Chandoo,
Gr8 …had fun in searching it. I got 5 out of 7.
You are brilliant.
Found all except in sheet6 as not able to understand formula.
thanks
Raja Aurongzeb
I am not able to find 1st Panda, which is on Sheet1. Rest all I have found.
Wonderful Chandooji… you are brilliant.
Wow.. Awesome set of puzzles Chandoo!!
Thanks!
Looks like this is an XL feature.. Zooming out the worksheets below 40% level, by default displays all named ranges (more than 2 cells)! Had not come across this till date..
Great works! Was having FUN in finding the pandas. Thanks.
Had fun doing this, Found 5 and the rest I saw clues on here 🙂
I really enjoyed when finding the pandas.And also I am so surprised.Very Nice thought and Excellent.
This was fun! Thanks!
Nice and fun post. Thanks, Chandoo!
