Gantt in 60 seconds – churn out an excel project plan in no time
Share
Facebook
Twitter
LinkedIn
excel gantt charts in 60 seconds
One of the most frequent tasks for any manager is “planning”, be it putting together a hiring schedule or designing a jumbo jet, it all starts with a simple project plan and gantt chart is simple and intuitive representation of the same. But how to make a gantt chart in excel without writing too many formulas or adding conditional formats? Do not worry! with the simple trick we are going to learn today, you will be able to “gantt in 60 seconds” 🙂
You dont have even 60 seconds, worry not, download the free gantt chart template and get your project plan ready in 6 seconds.
For our example purposes, we will look at a fictitious project plan shown below:
project plan data table excel
Even though you can use this trick to pretty much any data format, it works better when the project plan is structured around how I represented it above.
Now lets build a gantt chart in 60 seconds, get your stopwatches out and get, set …. GO!
1. Create a bar graph
Select the data part of your plan (ie all the cells except header row in the above table) and click on chart icon in excel. Select “bar chart” as chart type and “stacked bar 2d” as sub-type (2nd left on the top row) as shown here.
create excel gantt chart with bar graphs
Click finish. At this point your gantt chart should look like this:
1-gantt-chart-in-excel
2. Transform your bar graph to gantt chart
Now we will convert this stacked bar graph to a gantt chart by using chart formatting options.
  • First we will reverse the way data is charted, so that it looks like a gantt chart. For this we need to right click anywhere on the “y-axis” of the graph and select “format” option. Go to “scale” tab and check “Categories in reverse order” option.
    EXCEL CHART SCALE OPTIONS
    Click ok, now out gantt chart should look like this:
    2-gantt-chart-in-ms-excel
    btw, what is the time on that stop clock, 34 seconds, well, thats just fine, we have got plenty of time to spruce this up.
  • Now, lets get rid of first data series so that our graph looks more like gantt chart. Select the first data series of your chart (should be in violet blue color 🙂 ), right click and go to “format data series” option.
    4-format-first-stack-in-chart
    Select “none” for “border” and “area” options in the “patterns” tab. This will make sure that the first series is invisible, so we see second data series floating on the chart, thus making it look almost like a gantt chart.
    5-remove-background-lines
    Go to “data labels” tab and check “category name” option. This will make sure our gantt chart will show labels (but on the now invisible first data series)
    6-show-data-labels
    Click ok, at this point our gantt chart should look like this:
    Gantt chart in microsoft excel graphs - how to?
  • Finally we will adjust labels and backgrounds to convert this to a perfect gantt chart
    1. First lets remove the legend box on the right by selecting it and hitting “del” key.
    2. Now, lets also remove the y-axis since labels are visible on data-series 1. Just click on the y-axis (or category axis) and hit “del” again.
    3. Lets adjust the alignment of the data labels on series 1 so that they are properly visible. Right-click on the data labels and select “format” option. Go to “alignment” tab in the dialog and select “Right” for horizontal alignment and “inside end” for label position. This will ensure that our data labels are right aligned and shown at the end of data series 1, ie closer to the actual series 2 (duration of the task). See the below screen cap for more help.
      7-adjust-alignments for data labels in excel charts
    4. Lets also remove the plot back ground to remove the annoying grey color from our gantt chart. Just click on the grey color anywhere and hit “del”. While we are at it, you can also change the line color of x-axis (the days) to white or transparent to reduce the eye sore.
    5. Finally, lets adjust the plot area size so that we can read all the data labels and everything looks normal.
    At this point our gantt chart should look something like this:
    gantt chart in excel spreadsheets download
    If you still have few seconds left, you can tweak the chart format to make it look better. I had 3 more seconds left, so I tried this 🙂
    final-excel-gantt-chart
Feel free to download the free gantt chart template and see how to create gantt charts using excel bar graphs.
Bonus tips for enthusiastic excel experimenters:
1. Adjust the grid line format to make them more subtle
2. Select a particular task’s data point and change its color to emphasize progress / stalled statuses
3. Enhance this to add another column with no. of resources (or difficulty etc.), add this to the stacked chart and make it invisible just like series 1, but show the data labels.
4. You get the picture… so start gantting… 😀
Also read:
Learn how to create project plans / gantt charts using conditional formatting
Create art grade excel charts with these 73 designer templates
Other uber cool excel tricks to make your colleagues zealous and your boss happy
Facebook
Twitter
LinkedIn
Learn & be awesome.
Welcome to Chandoo.org
Rebekah S
Reporting Analyst
Advanced Pivot Table tricks
14 Responses to “How to Add your Macros to QAT or Excel toolbars?”
  1. Ashfire says:
    We have only just got excel 2007 so this is helping me navigate my way through the differences cheers.
    For Macro's i always add a Command Button, rename it something obvious, change the colour of it and finally add the following to its View Code section.
    Application.Run "MAcro1"
    This way anyone opening the file knows what to do if i ever win the lottery and dont make it in 🙂
  2. Ron Murphy says:
    Good article. But I have this problem.
    1) Customized QAT with a macro. Macro name = MacroX
    2) Runs OK from original location (e.g. C:\TestLoaction1\TestFile.xls)
    3) Copy past file to new location (e.g. C:\TestLoaction2\TestFile.xls)
    Menu button now fails:
    Cannot run the macro "C:\TestLoaction1\TestFile.xls'!MacroX' The macro may not be available in this workbook...
    Of course the code is there, and macros are enabled.
    Could get it to work after deleting and recreating macro custom buttons. So have to re-assign macro to QAT button every time I move the file?
    If I put a form button on he worksheet and assign the macro to that, it's location independent.
    Any ideas?
  3. Hui... says:
    @Ron
    What you have said is correct
    Macros within a worksheet are stored within the worksheet and hence follow it.
    Macros referenced by a button in the QAT or elsewhere are locaed in a file and if that file is moved the linkages don't follow.
    The easiest way around this is to store all your macros in a location that doesn't move and is in fact reloaded everytime that Excel starts and that is called the Personal.xlsx/b file.
    These are refered to several time at Chandoo.org or have a read of
    http://www.rondebruin.nl/personal.htm
    or
    http://office.microsoft.com/en-us/excel-help/deploy-your-excel-macros-from-a-central-file-HA001087296.aspx
    • Col Delane says:
      In Excel 2003 and prior versions, a button added to the Toolbar maintained a DYNAMIC link to the file (e.g. Personal.xlsb) holding the assigned macro, such that if the file was relocated for any reason (by using Excel's native Save As command rather than just moving it via Windows Explorer), the link between the button and the file was updated.
      I expected the same to occur with Excel 2007+, but alas, Microsoft in their infinite wisdom have removed another feature useful to advanced users (just as they did by removing the ability to design your own buttons)!!
      So having just done some reorganisation of my files, I now have to remove and recreate every friggin macro button on my QAT (I have lots) - what a pain in the proverbial!!
  4. Ron Murphy says:
    Hi Hui,
    Thanks for the help, that's really useful.
    1) The macros I'm adding are for one specific Excel application, so I really wanted the macros to follow the file
    2) I didn't want to have to pass other files around too and have users installing those - either Personal.xlsx/b or as an Add-In.
    3) I realise now that the QAT additions will appear for other Excel workbooks in which I don't want the macros available.
    So, it looks like I need to keep it local, by using a button on the worksheet. Unless you can suggest any way of adding to menus just for a specific workbook.
    Thanks again for your help. Great site, so I'll be signing up for the emails.
    Ron
  5. cheryl says:
    I know I'm a little late jumping on this post, but wondering if anyone knows how to add a UDF to the QAT? I've saved my UDF in my personal workbook, but it does not show up in my list when I choose Macros when customizing my QAT. Suggestions? Thanks!!
    • Chandoo says:
      @Cheryl: UDFs cannot be accessed like Macros. You can use them from other macros or from worksheet cells as formulas...
      @David: If you save your macros file and then install it as an add-in then it will be always available for you.
  6. David says:
    The instructions work great when you are creating a new file, and it is still open. I find that I can't access macros after I've saved a file as an xlam and closed it. When I reopen the xlam, either by browsing to it, or by having it set to open as an addin using Excel Options, the macros are no longer available in the macros list when I go to edit the QAT. Any way around that?
  7. JimH says:
    I need to create a button that will run a macro. Once you click the button it needs to open up a browser asking you to select a report/file. Once you select the file, it will run the macro on the selected file and then save it as a new report with a name and the current date. I created the macro to sort/modify the report but I do not know how to do what I mentioned above. I hope this makes sense.
  8. NathanG says:
    I'm having trouble adding a macro to the QAT. I've done everything up to step 5 but my macro isn't showing up. What am I doing wrong?
  9. surfinette says:
    Thank you for the explanation. Very useful for a recent switcher from office 2003 to office 2010.
    My follow-up question is: in Excel (or ppt) 2010, can you customize the macro button that you put in the QAT?
    In office 2003, once you chose the custom button for your Macro, you could then edit pixel by pixel the said button.
    For instance, I've created 2 Macros in PPT that are converting all my slides to either English or French language, so I'd like one button to show EN and the other FR... that would be more meaningful that any of the possible "custom" office 2010 buttons
  10. Morton Wakeland says:
    I read all the post and one important aspect to the QAT was never mentioned. That is, you have a macro driven worksheet that you want to share with other. You have customized the QAT with two icons to run the macros (VBA programs in reality). However, when the others receive the workbook, the icons are no where to be found. It's my understanding those "customized buttons" have been saved to an outside file, Excel.qat. QUESTION: Could one simply attach that file to your email, along with the worksheet, and tell the recipients to copy that file to correct location on their computer - C:\Users\\AppData\Local\Microsoft\Office|\
    Would the customize macro buttons then appear in the worksheet and, more importantly, work? Thanks for your thoughtfulness and thanks for well written instructions Chandoo!
    MortW
Leave a Reply
