Implementing Modular Spreadsheet Development – a walkthrough
Share
Facebook
Twitter
LinkedIn
This article is written by Michael Hutchens from Best Practice Modelling.
In the first article on Modular Spreadsheet Development, we got a high level overview of Modular Spreadsheet Development principles. This article discusses the practical implementation of these principles in Excel.
A quick review
In my first article, I discussed the infinite potential provided by Modular Spreadsheet Development to improve the way spreadsheets are built, used, shared and communicated.
This is made possible by sub-dividing spreadsheets into modules, which can be re-used and linked like Lego® pieces, thereby reducing model build time and the risk of errors.
profitability_model_modules - MSD Implementation in Excel
These concepts were well received by Chandoo’s readers, although some concerns were raised about their practical implementation in Microsoft Excel. This article aims to address those concerns.
Overview of implementation methods
From my experience using Modular Spreadsheet Development over the past decade, there are three increasingly-efficient methods of implementation in Microsoft Excel:
  1. Manual implementation;
  2. VBA automated implementation; and
  3. Commercial add-in implementation.
I will provide an overview of each of these methods and a summary of their advantages and disadvantages.
1. Manual Implementation
The key to implementing Modular Spreadsheet Development is standardization, because it is the robust consistency created by standardized spreadsheets that makes it possible to interchange the modules within a spreadsheet.
There are numerous approaches to spreadsheet standardization (my organization uses the Best Practice Spreadsheet Modeling Standards), but the key requirement of any standardized approach for Modular Spreadsheet Development purposes is consistency. Once this consistency is present, re-using and sharing modular content within spreadsheets becomes surprisingly easy.
Let’s consider an example ( ➡ download example files ) in which a model developer has built a dynamic 3-way financial statement model. This model contains various modules, ranging from revenues and expenses through to financial statements and a dashboard module that looks as follows:
financial_model_dashboard
After completing this model, the model developer decides to add an equity valuation. Creating the equity valuation assumptions and outputs from scratch is a big job, and a risky one given the complexity of the discounted cash flow (DCF) valuation formulas required.
Luckily, the model developer has included an equity valuation in a prior model, and had the foresight to keep a copy of this equity valuation module in a standalone workbook called Equity Valuation.xlsb. The composition of this module is shown below:
equity_valuation_module_composition
This equity valuation module contains four components; an assumptions component, a calculation outputs component, an outputs summary component and a lookups component (to hold drop down box control lookup data).
From an Excel perspective, this module is a workbook with these four components placed on three sheets; one assumptions sheet, one outputs sheet and one lookups sheet, as shown below (the lookups sheet is to the right of the image):
equity_valuation_toc_annotated
Each of these components is comprised of blocks of entire rows that contain Excel content (such as constants, formulas, controls, hyperlinks, etc.) that together undertake an equity valuation. For example, the top sections of the equity valuation assumptions component are shown below:
equity_valuation_module_assumptions
Rather than try to re-build all of this content into the financial model, the model developer decides to implement Modular Spreadsheet Development and insert this equity valuation module into the financial model.
Two steps are required to do this:
  1. Collectively copy the sheets containing the equity valuation module components into the financial model workbook from the workbook containing the equity valuation module; then
  2. Insert formulas into the equity module assumptions to link this module to the surrounding financial model outputs, and thereupon calculate the DCF equity valuation.
To copy the sheets containing the equity valuation module components into the financial model workbook, the following actions are required:
  1. Activate the Equity Valuation.xlsb workbook;
  2. Collectively select the three sheets containing the equity valuation module components (i.e. the sheets named Eq_Val_Ann_TA, Eq_Val_Ann_TO and Eq_Val_LU) and copy them to the end of the Financial Model.xlsb workbook using the Excel Move or Copy sheets command, as shown below:
    move_or_copy_sheets_dialog
  3. Click the OK button (or press/hold down the Enter key) each time you are asked to use the destination workbook version of a range name. This will happen quite a few times in this example, as range names have been used in the time series parts of the model to ensure consistency;
  4. Move the inserted sheets into their appropriate locations within the Financial Model.xlsb workbook – i.e. move the sheet containing the equity valuation assumptions into the assumptions section of the workbook, etc.; then
  5. Update any necessary surrounding content within the financial model workbook, such as the table of contents, to reflect the inclusion of these sheets.
After doing this, the newly-inserted equity valuation module needs to be linked to other modules within the financial model in order to correctly calculate the DCF equity valuation. This is a complex example, but for those familiar with DCF valuations, the following data must be linked into the equity valuation module:
  1. Cash flow available to equity;
  2. Tax paid;
  3. Earnings before interest, tax, depreciation and amortization (EBITDA); and
  4. Closing debt balances.
You can learn more about DCF valuation theory from the financial modelling resources on the Best Practice Modelling website.
After doing this, the financial model contains a DCF equity valuation, as shown below in the table of contents, which has been compacted to highlight the newly-added components:
financial_model_with_equity_valuation_toc
Amazingly, this sophisticated equity valuation analysis was inserted into the financial model in minutes, with only a few formulas required to link it to the surrounding model outputs. As a result, assuming that the source equity valuation module has integrity, the model developer instantly has confidence that the new equity valuation in the financial model is also reliable and correct.
As demonstrated by these steps, the manual implementation of Modular Spreadsheet Development is somewhat fiddly, but it is possible as long as the content within all workbooks and module files is sufficiently standardized to support interchanging components.
The implementation steps used in this simple example can be used to insert any pre-existing module into an existing modular spreadsheet, thereby greatly reducing model development time, cost and risk.
Excel users with intermediate to advanced VBA skills will probably have recognised while reading the manual implementation steps that VBA code can be written to automate to automate the majority of this process.
A full discussion and example VBA code is outside the scope of this article, but if you’re considering have a go at this here are some general tips:
  1. Use a user form containing list box control with its MultiSelect property set to fmMultiSelectMulti to allow users to select the sheets containing the module assumptions and outputs to be imported;
  2. Ensure that Application.DisplayAlerts is set to FALSE before running the code used to copy sheets to prevent prompts being displayed to users; and
  3. Use the VBA Range.Replace function to redirect formula links after moving the imported module assumptions and outputs onto existing sheets.
These steps were in fact the steps that I first took when developing an add-in for our organization to automate the insertion of modules. 10 years later, this add-in is called bpmModules, and I’ve provided an overview of it below.
When I first started implementing Modular Spreadsheet Development, I did it manually. It was fiddly, but as my colleagues and I built more complex modules, it soon became much quicker than re-building content from scratch in each model.
In 2004 we started refining a basic Excel add-in to automate the insertion and deletion of modules, and this once again saved us a lot of time and reduced the risks involved in these processes. But three main issues still haunted us:
  1. Models often differed in term – e.g. one model might be 5 years long while the next might be 10 years long;
  2. Every model required a different number of categories – i.e. one might require 3 revenue categories while the next might require 20 revenue categories; and
  3. Manually entering and removing formula links between modules before deletion and after insertion was tedious and error-prone.
So we set out to build a comprehensive add-in to make Modular Spreadsheet Development quick and easy within Excel. We called it bpmModules, and thought it would take a couple of years to develop.
It ended up taking 10 years to develop, and only after we completed it did we realize that we’d effectively created a modular content creation, management and sharing system for Excel. It’s a mouthful, but that’s exactly what it is, and with it you can do things like:
  1. Create your own modules;
  2. Use and edit other people’s modules;
  3. Insert, delete and link modules;
  4. Automatically change the term of a model; and
  5. Automatically add and remove categories without manually editing formulas, etc.
bpmModules also allows you view and manage the modules within your spreadsheet via simple diagrammatic interfaces, such as the one below that shows all the modules in the underlying Excel workbook:
bpmmodules_project_manager
We’ve made the Lite version of this add-in free, and you can download thousands of free modules fromthe downloads section of BPM’s website. The software does become commercial once you start building larger models, but by this stage it is hopefully saving you enough time to justify the investment.
Comparison of approaches
Modular Spreadsheet Development is an awesome concept capable of revolutionising the way spreadsheets are created, managed and shared. Unfortunately, Excel is not by default modular, so to implement Modular Spreadsheet Development you will need to standardize your spreadsheets and then use one of the three implementation methods discussed in this article.
I’ve provided a summary of the advantages and disadvantages of each of these implementation methods below:
  1. Manual implementation is free but requires rigid standardization and is somewhat fiddly, thereby creating risks of errors when inserting modules into workbooks;
  2. VBA automated implementation is free and less fiddly then manual implementation, but still requires rigid standardization and at least intermediate VBA skills to develop a reliable Excel add-in; and
  3. Commercial add-in implementation is not free for larger models but provides an automated mechanism for creating, re-using and sharing modular content in Excel.
Each of these methods provides the core efficiency gains resulting from Modular Spreadsheet Development, so your choice depends largely on your existing Excel skills and the time, cost and risk savings you estimate you would achieve via automation.
Source files
Click here to download example workbooks [zip file].
The following workbooks can be used to replicate the manual Modular Spreadsheet Development example provided in this article, and consist of the financial model before and after the insertion of the equity valuation module, and the workbook containing this module:
  • Financial Model.xlsb
  • Equity Valuation Module.xlsb
  • Financial Model (with Equity Valuation).xlsb
The following workbooks can be used to demonstrate the automation of this process using the bpmModules Excel add-in:
  • Financial Model (bpmModules).xlsb
  • Equity Valuation.bpm
  • Financial Model (with Equity Valuation) (bpmModules).xlsb
Note that you will need to download and install a trial of bpmModules to insert the equity valuation module (with the file extension *.bpm) into the bpmModules-created financial model.
More information
You can watch a range of Modular Spreadsheet Development movie tutorials via the following link:
www.bestpracticemodelling.com/chandoo/msd
Download thousands of modular Excel workbook examples from:
www.bestpracticemodelling.com/downloads/excel_models
Download thousands of modules from:
www.bestpracticemodelling.com/downloads/modules
Watch bpmModules build a financial model in less than 1 minute
Added by Chandoo
Thanks Michael for writing these very detailed articles on Modular Spreadsheet Development to spread the awareness among our readers. With your help, I am sure many modeling professionals & analysts around the world can embark on the time-saving & fruitful journey of modular development.
If you enjoyed these articles, Please take a minute and say thanks to Micheal. Also please share your thoughts, implementation notes & experiences with us using comments.
More on Modeling Best Practices:
Facebook
Twitter
LinkedIn
Learn & be awesome.
Welcome to Chandoo.org
Rebekah S
Reporting Analyst
Advanced Pivot Table tricks
67 Responses to “How to use XLOOKUP in Excel?”
  1. Ron says:
    Sure it's a nice new command. It would be useful if everyone had access to it. But if there is any chance you will be sharing the file with someone who has a onetime payment Office license, or an older version of Office you can't use it.
    • Chandoo says:
      That is my biggest gripe with many new features MS is launching. With such vast userbase and existing spreadsheet "systems", all of these formulas are going to create more trouble than imagined. That said, we should learn new things, especially if you move to a new job chances are you will be using a different version of Excel there.
      • Ron says:
        I love to learn new things, like this new command. But I can't afford, literally don't have the money, to keep paying for 365.
        This is the thing that especially offends me about the Office 365 pricing scam/scheme. Sure, if they want to milk more money from users using the rental scam, fine I know I don't have to fall for it. But restricting new "features", like new commands to 365 is offensive. It makes one-time payment users "second class" customers, especially anyone who has paid for Office 2019. At least in the past new features/commands came only came out every few years, with new versions so there was some logic to the separation. But now the new features are coming every few months and there is no real separation between 2019 and 365, but still they limit the new features to 365. Even 2016 is close enough. MS "accidentally" pushes a few new features to 2016, when they feel like it or when they are too lazy to do the extra work to prevent them from going to 2016.
        • Brian Crawford Wilson says:
          I agree with Ron I have MS Office 2019 which I used for Charity work but a pensioner I find the cost of the MS365 unaffordable. Perhaps there is some way for a Ms Guru to perhaps create 3rd party update for the stand alone versions.
          I will however continues with Ms 365 this year as I have just renewed the subscription
          thanks very much for keeping us abreast of latest developments and also the excel community for their useful feed back
          regards Brian 18/03/2024
          • Chandoo says:
            Good point. I suggest using the free MS Office online (you just need onedrive account) to maintain old files and work on them. The only limitation is that it is browser based, so you won't be able to do many advanced things. But it is better than the alternative of shelling out $100+ every year.
  2. Narendra says:
    Yes, of course this is the latest and excellent update from Microsoft but this feature will take years to come in the market because most of the people or offices are still using Office 2007 or 2013.
  3. Dear Chandoo Sir
    Thank you for updating latest idea this idea is centralized lookup formula all about.
    this idea is realy impressive and samart
  4. I couldn't observe any benefit, over MATCH+INDEX.
    • Chandoo says:
      Hmm, the base scenario is similar to index+match, but XLOOKUP makes life simple with single formula and default "exact match" setup. Plus I find the "lookup from last" and "less than" "greater than" options very useful and less cryptic than MATCH options.
  5. Nicole says:
    Thanks for sharing, it added some excitement to my Friday morning! I don't have 365 but am still excited to be aware of the existence of these features! I know that vlookup on larger sets of data can really take up some resources--it makes sense, it's performing a lot of operations for us while we sit and sip on coffee. 😉 However, I'm wondering if you've you noticed a difference in performance with xlookup? Is it slower, faster, or pretty much the same in terms of calculation speed?
  6. Fernando Navarro says:
    A nice addition to the function list. Very usefull and easier to use then INDEX + MATCH.
    Since XLOOKUP is in beta testing, it would be great if Microsoft development team added a 5th. argument: if_na. That is: if XLOOKUP returns #N/A, an alternate value could be returned instead. Therefore, it wouldn't be necessary to do =IFNA(XLOOKUP(...), value_if_na).
  7. Abdul Kader Salaymeh says:
    Although I don't have and expecting to be around soon in EXCEL 2019, my question is there a way to work around the new function "xlookup" but not the old ones.
    However it is appreciated tip,thanks
  8. Hui... says:
    Chandoo
    You can also use XLookup like
    =Sum(xlookup():Xlookup())
    Refer the example 4 at:
    https://support.office.com/en-us/article/xlookup-function-b7fd680e-6d10-43e6-84f9-88eae8bf5929?ui=en-US&rs=en-US&ad=US
    This makes it hugely powerful as it is returning an address like Index can do
    • Chandoo says:
      Great point Hui. I am yet to find a practical use case for summing between lookups, but I am pretty sure others will find this useful.
      • Peter Bartholomew says:
        Here is an idea.
        If you wish to analyse data for a given month, the relevant portion of the Sales table (sorted by date) is given by
        = XLOOKUP( EOMONTH(month,0), EOMONTH(+sales[Date],0), sales,0,1 ) :
        XLOOKUP( EOMONTH(month,0), EOMONTH(+sales[Date],0), sales,0,-1 )
        which can be referred to as a named formula 'selected'. Being a reference to the original table, range intersection with columns works. Hence
        = XLOOKUP( MAX(selected sales[Net Sales]),
        selected sales[Net Sales], selected sales[Sales Person] )
        provides an answer to
        Who had most sales for February?
        Caution: The formula requires 7 separate searches of the data but they are very fast.
  9. Hamish Waugh says:
    I use VLOOKUP a lot with named ranges, are you able to reference those in XLOOKUP?
    • Chandoo says:
      @Hamish... you should be able to use any reference styles that work with other formulas in XLOOKUP. So yes for names, structural, cell and references to other sheets / workbooks.
      Hamish, Yes it all works perfectly. That includes cases in which the data table does not comprise raw data but rather is made up of dynamic arrays. Naming the anchor cell of each dynamic array allows expressions such as
      = XLOOKUP( MAX(selectedNetSales#), selectedNetSales#, selectedSalesPerson# )
      Conversely, if the returned field is comprised of anchor cells for separate dynamic lists (e.g. employment data for the specified salesman) then the list can be returned by adding '#'
      =XLOOKUP(0,sales[Net Sales],EmployeeInfo,1)#
  10. kphagen says:
    Since the documentation says it returns a reference array, could you write formulas that could answer questions that need to perform a function upon a result set that contains multiple rows such as:
    1. What is the total Profit/Loss for SalesPersons named [Jamie]?
    2. What is the MAX/MIN Net Sales for SalesPersons named [Jamie]?
    3. What was the Average Net Sales for everyone that had exactly [8] Customers?
      I think the answer to your question is 'no' unless you are willing to sort the table so that the records you wish to aggregate form a continuous range. That is, the formula
      = SUM(
      XLOOKUP(salesPerson,sales[Sales Person],sales[Profit / Loss],,,1):
      XLOOKUP(salesPerson,sales[Sales Person],sales[Profit / Loss],,,-1))
      only works if the data is sorted by Sales Person.
      Otherwise it looks like SUMIFS (and similar) offers the best solutions with FILTER a close second.
      = SUMIFS( sales[Profit / Loss], sales[Sales Person], salesPerson )
      = SUM( FILTER(sales[Profit / Loss], sales[Sales Person]=salesPerson ) )
  11. Duncan Williamson says:
    XLOOKUP allows us to look for a variable in a column and return a value from a row: combining VLOOKUP ad HLOOKUP in essence.
    I watched a video last night in which the presenter showed an example that returned an error. The solution that the presented was using is this: =XLOOKUP(A4,B7:B9,C6:E6)
    To see the problem in action, put a b c in the range B7:B9 and 1 2 3 in the range C6:E6 and in A4 enter a or b or c
    I solved this problem in this way:
    =XLOOKUP(A12,B15:B17,TRANSPOSE(C14:E14))
    I have also set up a financial analysis example in which I wanted to find, for every line item in an income statement, which month was exactly equal to the mean of that row or which was immediately below the mean or immediately above it. Or Median, or Standard Deviation ...
    I used XLOOKUP() and IFS() together with Data Validation (although that is optional) and while the formula is a little unwieldy, again I am effectively combining vertical and horizontal lookups.
  12. Rohit Tiwari says:
    Can you please tell me if there is any way to return multiple values with a single match.
    Thanks in Advance
  13. Abdul Kader Salaymeh says:
    when will be in excel 2019
    • Ron MVP (2012-2018) says:
      Never.
      "New features" like the XLookUp() command are only added to Office 365. They will never be added to Office 2019. They may show up in Office V-Next, when ever it comes out, in the near future. MS has not yet announced a new version. If they follow the pattern in the last few versions that would be fall 2021. But that is only a guess.
    • Abdul Kader Salaymeh says:
      I have it now in office 2021
  14. wschloss says:
    I downloaded your sample spreadsheet and three of your first seven examples are incorrect. Then I stopped.
    • Chandoo says:
      Which version of Excel are you running? XLOOKUP doesn't work in any version except Office 365.
      • Tom says:
        Hi, Chandoo.
        Great tips, thanks!
        In example #11, "What is the 'net sales' for Johnson? = 1540" the formula only takes into account the first match for Johnson (D10)?
        In row 21 Johnson appears again so the correct answer should be 4192 (D10 + D21).
        Imagine a DB with hundreds of records!
        How can we deal with duplicates using XLOOKUP?
        Thanks.
  15. Sherry says:
    Is there an easy way to handle if the cell is blank in the data table to prove the result of a blank? With VLOOKUP, previously to get this result, I had to do:
    =IF(VLOOKUP($B2,data,6,FALSE)="","",VLOOKUP($B2,data,6,FALSE))
    I am hoping that I don't have to resort to the same lengthy format. I did try the "Value Not Found" example you provided (love it). However that is when the search value is not listed, not when the search value is found and the result value is a blank cell.
    Thanks for everything you do!!!!
    • Chandoo says:
      Hi Sherry,
      Are you using the IF formula to show "" instead of 0 ?
      If so, you can use this structure
      =XLOOKUP($B$2, data[col1], data[col6]) & ""
      This will force 0 to convert to empty space. It won't impact other results though, (assuming column 6 is text)
  16. Peter Bartholomew says:
    A bit longer, but to force the 'value not found' you could remove the entry from the lookup array
    = XLOOKUP(lookupValue,
    IF(data[col6]"", data[col1]),
    data[col6], "Missing data")
  17. Stuart says:
    Hi Chandoo,
    I've been waiting for this function for months so that I could replace all my INDEX / MATCH / MATCH statements. However, I have hit a snag with using nested XLOOKUPs as replacements. If the inner XLOOKUP can't find a value, then whatever value I specify as the [if not found] value causes the outer XLOOKUP to fail and return #VALUE. So the [if not found] functionality works if a single XLOOKUP can't find the search value, but it causes nested XLOOKUPs to fail. Can you see any way around that?
    • Chandoo says:
      Hey Stuart... Can you share an example of what result you are expecting in nested case? One option is to use a single IFERROR outside all the nested functions.
  18. Peter Bartholomew says:
    @Stuart
    Do not limit yourself to thinking of [if_not_found] as being a text string, e.g. "Oops"; it can be a formula in its own right, returning a default row from the original table or even a lookup from an alternative table.
    What it must return is an array in order to form a valid parameter for the outer XLOOKUP.
    • Stuart says:
      Hi Peter,
      You've got it! As you suggest, by setting the inner XLOOKUP to return an array full of zeroes (or whatever) solves the problem. The outer XLOOKUP can of course just have 0, or whatever, stated its if_not_found value.
      I am surprised that I haven't come across this issue or solution anywhere else. There are lots of blogs / videos which mention using nested XLOOKUPs as a replacement for INDEX / MATCH / MATCH. I can't say I've read or watched them all, but the ones I have don't mention this issue. I suspect there are / will be a lot of people getting #N/As or, worse, #VALUES depending on what they specify as the inner function's if_not_found.
      Thanks for your help!
  19. Kathryn says:
    I am trying to lookup a date and name and return the number of hours from another worksheet? If I'm mixing text and dates, will this still work?
  20. Michael says:
    Great article. But,...two questions:
    1) I do have Office 365. Yet, the XLookup is not recognized by Excel. Your sample file displays a #NAME? Why?
    2) In your samplefile you have a leading '_xlfn.' in front of the formula. Why is that?
    • Chandoo says:
      Hi Michael...
      Can you confirm what is your current version of Excel is? Also see if you can update to newer version. You can do both from File > Account.
  21. Jonathon Tom says:
    My values that I want to join are not exact, i.e.
    000025868 and 0000258 68 Total
    Is there a way to join the data?
  22. Jonathon Tom says:
    Getting a #N/A as the results.
    Is there a way to convert "0000258 68 Total" to 000025868 (or visa versa) before I run the =XLOOKUP?
    • Chandoo says:
      If you just want to remove the word "total" at the end, use SUBSTITUTE for that. If there can be other words, you are better off first running the data thru Power Query so you can clean it.
      One thing that is possible is to take a numeric lookup value and convert it to text before searching a text lookup array. For example
      = XLOOKUP(TEXT( value, "0000000\?00\*" ), array, return, , 2 )
      will perform a search with wildcards that allow "Total" to be appended or any character to be inserted two digits before the end of the number.
      That would pick up
      "0000258 68 Total"
      but you would need an alternative test to match the number 25868, itself.
  23. Amit says:
    Check the reference, while selecting data the xlookup function automatically starts from new line. Try changing it to the first row and it would work.
  24. Veronica says:
    YOU ARE THE EXCEL KING!
    Thank you
  25. DDong says:
    Hi Chandoo,
    I have 2 sheets with 5 columns. data in columns A:C is similar except that changes are made in columns A and C. I want to lookup in column C in Sheet2 and update Sheet1 columns A:C.
    for example
    Sheet1
    ColA ColB ColC
    123 AB12 One
    234 BC23
    323 CB22 Six
    Sheet2
    ColA ColB ColC
    123 AB12 One
    234 BB22 Two
    323 CB22 Six
  26. David N says:
    I don't think we can claim that XLOOKUP "replaces" INDEX+MATCH. Yes, it provides a suitably powerful alternative, and is absolutely a full replacement for VLOOKUP and HLOOKUP, but it can't easily play some of the "math" games that are possible with INDEX+MATCH and sometimes even necessary when the data isn't in a convenient layout.
    What if you needed the row above or below the match or if the data was laid out in repeating sections where you first needed to know the location of the section header and then the location of a given item within each section? Both of those problems can be solved with plus/minus shifting of the number returned from the MATCH.
    So I would argue that INDEX+XMATCH are the true replacement for INDEX+MATCH, thus taking full advantage of the X -- defaulting to exact matches, virtual sorting, and so on -- while preserving the ability to "shift" the match as needed.
  27. Stephan Chayer says:
    I'm looking for a price in a multiple column price list. With Vlookup, I specified the entire table and for the column, looked at the user selected model/column. In Xlookup, how to specify the column number and the range up and down or can I just specify the column number only?
    • Wiz says:
      One advantage that VLOOKUP retains over XLOOKUP is the ability to supply a lookup column number dynamically, as a purely numerical result of a calculation. To replicate this functionality using XLOOKUP, you would need seperate logic to calculate the column reference (i.e. the column's number, range name or range address) and pass it to the XLOOKUP formula. You could do this inside the XLOOKUP function by setting up the 3rd param of XLOOKUP to be based on your "user selected model/column".
  28. KS Jolly says:
    Using Xlookup with "match mode" = -1 and "if not found" = "ABC"
    Now if the lookup value is not found in the lookup_array excel gives the the highest value from the return_array.
    This is not what I expect from xlookup.
    It should return "ABC"
    Can you explain why?
  29. Jennifer Jeffords says:
    Chandoo,
    I am having trouble with XLookUp. How do I get it to return multiple values such as employees with salary greater than $45,000 or to sum all the sales in the East region? Are these more pivot table inquires?
    Is XLOOKUP more useful for finding one record than multiple records?
    Thank you,
    Jennifer Jeffords
  30. CK says:
    Hi Chandoo,
    Is it possible to use XLOOKUP to return a status such as "Checked" and "NoCheck"(something similar to IF stmt)
    Thank you.
  31. Paula Paden says:
    I used the index and match to look up the hourly rate for a job classification as a part of a drop down. Now, I want to calculate the hourly rate multiplied by hours worked and the cell will not calculate. What might be the problem? The results cell of the look-up is formatted to be currency?
  32. Dorothy Adams says:
    You show return array can be more than 1 column but what about Look up array? What if I want to find a value than can be in 1 of 3 columns and then return one value from another column.
    • Chandoo says:
      You can use XLOOKUP for such things too.
      For example, if you have three columns: home phone, cell phone and email address
      and a column with customer name
      and you want to lookup the name of the customer when you specify any value from one of those 3 columns,
      you can use the below XLOOKUP.
      =XLOOKUP(TRUE,BYROW(C3:E22=I2,LAMBDA(a, OR(a))), B3:B22, "No record found!")
      Here I2 contains the search criteria (either home phone, cell phone or email)
      B3:B22 have names
      C3:E22 have the home / cell / email values
  33. Musawir Rasool says:
    Hi my name is Musawir Rasool i am from India in a state of jammu and Kashmir I love watching your videos and lot from your videos
    And one more can u teach me full power bi?
  34. Abizer says:
    Hi Chandoo,
    I was referring to your xlookup-examples file, and in that I saw your formula for Sl. 8 - Who has least sales? You wrote formula =XLOOKUP(0,sales[Net Sales],sales[Sales Person],,1) but I think a more better way would be to write =XLOOKUP(MIN(sales[Net Sales]),sales[Net Sales],sales[Sales Person],,1). This is because your formula would not reliable unless you're specifically looking for a salesperson who has exactly 0 in sales, which is not the same as the least sales — unless 0 happens to be the lowest. Also, the 1 as the last argument means "approximate match in ascending order," which could return wrong results if 0 isn't found.
Leave a Reply
