Save a range as text file using VBA [tutorial]
Last night I asked members of our Chandoo.org facebook page to share an Excel problem you are struggling with.  Francis asked,
How to save a file as .txt in vba without quotes? When I save as .txt, the file has got quotes inside of it. I used the code Print, but it didnt work because the file loses its delimitation.
Does anyone know how to solve this?
Let’s understand how to save a range as text and overcome the double quote problem.
Saving a range as Text – the easy way
Say you have a file like this:
save-range-as-text-vba-data
The easy option is to save your worksheet as text file using below macro.
Sub saveText()
    ActiveWorkbook.SaveAs filename:= _
        ThisWorkBook.Path & "\textfile-" & Format(Now, "ddmmyy-hhmmss") & ".txt", FileFormat:=xlText, _
        CreateBackup:=False
While this works, it has 2 problems.
  1. It exports the entire current worksheet.
  2. It adds double quotes “” to text values or formatted cells.
So you get this.
save-as-text-quotation-marks
Saving a range as Text – the proper way
We can create a blank text file using VBA and write the range data values in to that file. This way we will have full control over what goes in to the file and how it’s formatted.
Here is the code:
Sub saveText2()
    Dim filename As String, lineText As String
    Dim myrng As Range, i, j
    filename = ThisWorkbook.Path & "\textfile-" & Format(Now, "ddmmyy-hhmmss") & ".txt"
    Open filename For Output As #1
    Set myrng = Range("data")
    For i = 1 To myrng.Rows.Count
        For j = 1 To myrng.Columns.Count
            lineText = IIf(j = 1, "", lineText & ",") & myrng.Cells(i, j)
        Next j
        Print #1, lineText
    Close #1
Let’s understand the code…
Create a file name
We take the current workbook path and set up textfile-time stamp.txt in that directory.
Note, the time stamp portion is dynamic and changes every time you run the code.
We then open the file using Open filename For Output As #1 line.
This sets up a new file and opens it for us to write anything we want.
Loop thru range data and write values to the file
We loop thru each and every cell of the range("data"). We need to take all the values in a row and concatenate them with delimiter comma (,).
This is done in nested for loops (related: Introduction to For loop- Excel VBA)
We loop thru each column in a row and construct lineText.
We then print this lineText to file #1 using,
Print #1, lineText
Finally we close the file.
The end result
This is what we get.
save-as-text-final
Download Save Text example macro
Click here to download the example workbookExamine the savetext macro to learn more.
How do you create text files using VBA?
Do you create text / CSV / TSV files from Excel data? How do you automate the process? Please share your tips and ideas in the comments section.
Learn more powerful ways to use VBA:
Facebook
Twitter
LinkedIn
Learn & be awesome.
Welcome to Chandoo.org
Rebekah S
Reporting Analyst
Advanced Pivot Table tricks
54 Responses
  1. Hi Chandoo,
    This is awesome *****
    Khalid
  2. Oh I found the last one, (custom format hmm)
    You are an Artist Chandoo.
  3. Hi Chandoo,
    Thanks!
    -Ranjith
  4. This was very fun and challenging, thanks for posting! I found all of them (well, Sheet1 was tricky, it seems you’re supposed to find the cell and type it in yourself?). Wasn’t sure if it was cool to post the answers here or not, though. Guess I’ll post SPOILER ALERTS so you can skip the rest of the message if you don’t want to see what I came up with.
    SPOILER! SPOILER! SPOILER!
    My answers appear below.
    Sheet2: cell AB201
    Sheet3: cell J8 (Picture1)
    Sheet4: cell H9
    Sheet5: expand Chart1
    Sheet7: named range (A1:I18)
    1. Wookie – I would love to get a walkthrough of HOW you figured out sheet 1 and a bit of a formula walkthrough for Sheet 6.
      1. Hi Rachel,
    2. I agree, this was a fun way to test your ability to navigate through the functionality of Excel! And since you already posted the SPOILER ALERT warning, I should be safe posting a reply to your comment with some solutions of my own… 🙂
    3. I must admit sheet 7 defeated me, but I have some corrections
      Sheet 6 – I corrected to
      1. I know; that was weird. I did try using a LEFT formula, but I kept getting the $ prefix from the cell address. So I tried a couple of variations using MID and it gave me the result I needed. This is actually the first time I’ve ever tried using a MID formula starting at the first character, but I wasn’t trying to spend a lot of time on it, so I went with what worked.
  5. —–Spoilers———
    Alternate Solutions
    1. @ Rob
      1. @ Navdeep I found PAN3489 by going to “Formulas” and then “Name Manager” and saw there was a field called “Clue1” listed in the Name Manger that references 3489. Finding PAN as the column index was just a bit of a lucky guess through trial and error. Then a note in cell PAN3489 when you navigate there says to try “typing something.” I tried scrolling through the Format Cells menu to see if the text typed in the cell needed to be formatted a certain way, and noticed that “1= Panda” was listed in the custom text menu and tried it. A bit brute force, but I think the desired text entry.
  6. Sheet 1: The answer is not type in Panda. Type 1. There’s a special formatting that replaces 1 with Panda.
  7. WOW! I’ve just found the secret eighth PANDA!
    Truly awesome!!!
    Btw, thanks for the puzzle!
  8. It was truly a artists work
    chandoo you are grate
  9. Guys I Got 8 PANDA in the workbook… 🙂
    Here is the full list:
    2) Sheet2: Goto Cell AB201
    4) Sheet4: Goto Cell H8
    1. 1) Sheet1: Type 1 in Cell PAN3489
      4) Sheet4: Goto Cell H9
    2. Actually, for sheet7, if you set the zoom to 39% or less, you will see the word PANDA. Yet another PANDA! 🙂
  10. Hi,
    Thanks,
    Ram
  11. Hi Chandoo!
    Sheet 1: ??
    Sheet 2: ??
    Sheet 3: Cell J8
    Sheet 4: Cell H9
    Sheet 6: B2
    Sheet 7: ???
  12. I love this time of year and look forward to Chandoo’s egg hunts. Whilst I got all the pandas, I do not understand how sheet 7 works; Where is the source data and why does it only work when zoomed out to 39% or more?
      1. Ha ha, that’s fantastic. Thanks Hui. @Chandoo, thanks for yet another method to decrypt worksheets in order to re-build or explain them better to clients.
  13. These were fantastic and kept me intrigued until I could finish them. (Had to look here for help with Sheet1!) Definitely learning a lot about some new formulas. Awesome, Chandoo!
  14. Ok, just saw the notes on the Zoom 39% on Sheet 7. Can someone explain what’s happening here and why PANDA shows up at that level?
  15. Wow, great exercise.
    Thanks 🙂
  16. Wow.. Awesome set of puzzles Chandoo!!
    Thanks!
    1. Looks like this is an XL feature.. Zooming out the worksheets below 40% level, by default displays all named ranges (more than 2 cells)! Had not come across this till date..
  17. Great works! Was having FUN in finding the pandas. Thanks.
Leave a Reply
