Calculating Maximum Change [solutions & discussion]
Maximum change problem - Solutions, Discussion & Video
Last Friday, we had a fun little Excel challenge – Calculate Maximum Change. More than 170 people commented and shared their solutions to this problem.
And the best part?
The best part is the variety of solutions & thinking displayed by our community. So if you are one of those 170, puff your chest & pat yourself on the back. Go ahead, I will wait.
Today, lets take a look at some of these awesome formulas and understand how they work. Read on and watch the video you below to gain few awesomeness pounds.
First, lets understand the problem
Here is a look at the problem:
Calculate maximum change - formula problem
We need more information to answer this question.
  • Are we talking about positive change, negative change or absolute change?
  • Are we talking about % change or value change?
In the original problem, even though I did not mention it, most people assumed that we want absolute change of value (ie the answer is 40, for Product 2).
But in real life, you may want to understand the problem a little more before writing any formulas.
Note: The data is in C3:C8 for last month and D3:D8 for this month.
Solution #1: Using MAX array formula
This is the solution most people got.
The array formula:
=MAX(C3:C8-D3:D8)
press CTRL+Shift+Enter after typing.
How it works?
C3:C8-D3:D8 portion:  This gives the result {-20;40;15;21;0;-25} in array form.MAX(…) portion: This simply calculates the maximum value of above array and returns 40 as answer.
Why press CTRL+Shift+Enter (CSE)?
We need to press CTRL+Shift+Enter because MAX() is not capable of handling arrays. If you write MAX({-20;40;15;21;0;-25}) you would get 40, but the same array when calculated by doing math on ranges will not work. To force MAX to treat arrays, we need to press CTRL+Shift+Enter.
Solution #2: Using MAX+ABS array formula
Quite a few people figured out that the formula needs to work even when the change is negative. And that is where this new solution comes handy.
The array formula:
=MAX(ABS(C3:C8-D3:D8))
How it works?
ABS() portion: converts the change values {-20;40;15;21;0;-25} to positive {20;40;15;21;0;25}
Rest of the formula is same as solution #1.
Solution #3: Using INDEX to avoid Ctrl+Shift+Enter
The thing with Ctrl+Shift+Enter is that you have to remember it. If you accidentally press Enter instead of CSE, the formula stops working. One way to avoid this is to route the calculation thru an Excel function that can natively process arrays. This is where INDEX (or SUMPRODUCT etc.) come handy.
The formula:
=MAX(INDEX(C3:C8-D3:D8,0))
or
=MAX(INDEX(ABS(C3:C8-D3:D8),0))
How it works?
Same as Solution #1, except for this formula you do not have to press Ctrl+Shift+Enter. The INDEX will automatically calculate the array and send numbers to MAX. Then MAX feels mighty comfortable dealing with those numbers and spits out the answer as 40.
Learn more:
Solution #4: Using AGGREGATE
AGGREGATE() is a new function introduced in Excel 2010. This too, like INDEX & SUMPRODUCT can process arrays natively (provided you are using one of the aggregates like LARGE). Kyle, one of our commenters shared 2 brilliant solutions that involve AGGREGATE.
The formula:
=AGGREGATE(14,4,(C3:C8)-(D3:D8),1)
How it works?
14, 4 portion: This tells AGGREGATE that you want to calculate LARGE value (14) and you want to consider all cells (4). To understand more about AGGREGATE see the links below.
(C3:C8)-(D3:D8) portion: As seen above, this just gives an array – {-20;40;15;21;0;-25}
1 portion: This tells AGGREGATE that you want 1st largest number.
Learn more:
Solution #5: Using MMULT and AGGREGATE
Now this is what I call a scary formula. It can potentially waste your entire afternoon when you try to understand it first time. But once you get it, you feel awesome. This too is posted by Kyle.
The formula:
=AGGREGATE(14,4,MMULT(C3:D8,{1;-1}),1)
How it works?
Watch the video. Explaining how this works in text is difficult.
Learn more:
I am still trying to understand MMULT(). It can be as complex and deep as string theory (or recipe of making bread at home). Go thru below links to learn more about it. Make sure you put on your helmet, cause it will blow your mind.
More ways to get maximum change + Bonus problem
Watch below video to understand how to solve the maximum change problem and another related problem.
Click here to watch if you can’t see the video above
Download Answer workbook
Click here to download answer workbook and examine the formulas to learn more.
What did you learn from this formula challenge?
I learned how to use AGGREGATE, Array SUMIFS and got a better handle on MMULT.
What about you? What did you learn thru this challenge. Please comment and let us all know.
Facebook
Twitter
LinkedIn
Learn & be awesome.
Welcome to Chandoo.org
Rebekah S
Reporting Analyst
Advanced Pivot Table tricks
54 Responses
  1. Hi Chandoo,
    This is awesome *****
    Khalid
  2. Oh I found the last one, (custom format hmm)
    You are an Artist Chandoo.
  3. Hi Chandoo,
    Thanks!
    -Ranjith
  4. This was very fun and challenging, thanks for posting! I found all of them (well, Sheet1 was tricky, it seems you’re supposed to find the cell and type it in yourself?). Wasn’t sure if it was cool to post the answers here or not, though. Guess I’ll post SPOILER ALERTS so you can skip the rest of the message if you don’t want to see what I came up with.
    SPOILER! SPOILER! SPOILER!
    My answers appear below.
    Sheet2: cell AB201
    Sheet3: cell J8 (Picture1)
    Sheet4: cell H9
    Sheet5: expand Chart1
    Sheet7: named range (A1:I18)
    1. Wookie – I would love to get a walkthrough of HOW you figured out sheet 1 and a bit of a formula walkthrough for Sheet 6.
      1. Hi Rachel,
    2. I agree, this was a fun way to test your ability to navigate through the functionality of Excel! And since you already posted the SPOILER ALERT warning, I should be safe posting a reply to your comment with some solutions of my own… 🙂
    3. I must admit sheet 7 defeated me, but I have some corrections
      Sheet 6 – I corrected to
      1. I know; that was weird. I did try using a LEFT formula, but I kept getting the $ prefix from the cell address. So I tried a couple of variations using MID and it gave me the result I needed. This is actually the first time I’ve ever tried using a MID formula starting at the first character, but I wasn’t trying to spend a lot of time on it, so I went with what worked.
  5. —–Spoilers———
    Alternate Solutions
    1. @ Rob
      1. @ Navdeep I found PAN3489 by going to “Formulas” and then “Name Manager” and saw there was a field called “Clue1” listed in the Name Manger that references 3489. Finding PAN as the column index was just a bit of a lucky guess through trial and error. Then a note in cell PAN3489 when you navigate there says to try “typing something.” I tried scrolling through the Format Cells menu to see if the text typed in the cell needed to be formatted a certain way, and noticed that “1= Panda” was listed in the custom text menu and tried it. A bit brute force, but I think the desired text entry.
  6. Sheet 1: The answer is not type in Panda. Type 1. There’s a special formatting that replaces 1 with Panda.
  7. WOW! I’ve just found the secret eighth PANDA!
    Truly awesome!!!
    Btw, thanks for the puzzle!
  8. It was truly a artists work
    chandoo you are grate
  9. Guys I Got 8 PANDA in the workbook… 🙂
    Here is the full list:
    2) Sheet2: Goto Cell AB201
    4) Sheet4: Goto Cell H8
    1. 1) Sheet1: Type 1 in Cell PAN3489
      4) Sheet4: Goto Cell H9
    2. Actually, for sheet7, if you set the zoom to 39% or less, you will see the word PANDA. Yet another PANDA! 🙂
  10. Hi,
    Thanks,
    Ram
  11. Hi Chandoo!
    Sheet 1: ??
    Sheet 2: ??
    Sheet 3: Cell J8
    Sheet 4: Cell H9
    Sheet 6: B2
    Sheet 7: ???
  12. I love this time of year and look forward to Chandoo’s egg hunts. Whilst I got all the pandas, I do not understand how sheet 7 works; Where is the source data and why does it only work when zoomed out to 39% or more?
      1. Ha ha, that’s fantastic. Thanks Hui. @Chandoo, thanks for yet another method to decrypt worksheets in order to re-build or explain them better to clients.
  13. These were fantastic and kept me intrigued until I could finish them. (Had to look here for help with Sheet1!) Definitely learning a lot about some new formulas. Awesome, Chandoo!
  14. Ok, just saw the notes on the Zoom 39% on Sheet 7. Can someone explain what’s happening here and why PANDA shows up at that level?
  15. Wow, great exercise.
    Thanks 🙂
  16. Wow.. Awesome set of puzzles Chandoo!!
    Thanks!
    1. Looks like this is an XL feature.. Zooming out the worksheets below 40% level, by default displays all named ranges (more than 2 cells)! Had not come across this till date..
  17. Great works! Was having FUN in finding the pandas. Thanks.
Leave a Reply
