Create a Dynamic Chart in Excel in 2 Minutes [spreadcheats]
Share
Facebook
Twitter
LinkedIn
We have written about dynamic charts several times before. But I think the technique I am going to show you today beats them all. It is so simple, so easy to set up and so beautiful that I am cursing myself for nothing thinking of it earlier.
First take a look at the dynamic charts in excel demo:
Dynamic Charts in Excel - Demo
Just follow these 5 steps to create the dynamic chart in excel:
1. Prepare your charts: Make as many charts as you want. Lets say 3.
2. Set up the area where dynamic charts will be loaded: Just take 3 cells in a row and adjust the row height and column width such that the charts can be fit inside snugly. Also, type the chart names (1 for each cell) in the cell. Let us say, the charts you have are for Costs, Sales and Profits, just type these names in the cells.
3. Move and fit charts inside these cells: This should be simple.
4. Finally apply data filter to the cell on top of the 3 cells. Select a filter option and you will see only that chart.
5. Show off your dynamic chart and let people know you kick excel’s butt.
You can see these steps in the dynamic chart tutorial below:
Microsoft Excel Dynamic Charts Tutorial
What do you think about this technique?
Which technique you like better? This one or the Dynamic Charts using INDEX() function, Use Data Filters as Chart Filters tips? One issue I can think of with this technique is that, there is no way the filter will tell which chart is selected (as the chart covers the cell text). But this can be overcome with chart titles.
This post is part of our Spreadcheats series, a 30 day online excel training program for office goers and spreadsheet users. Join today.
Facebook
Twitter
LinkedIn
Learn & be awesome.
Welcome to Chandoo.org
Rebekah S
Reporting Analyst
Advanced Pivot Table tricks
38 Responses to “Time to showoff your VBA skills – Help me fix ActiveSheet.Pictures.Insert snafu”
  1. shokks says:
    I tried your code with 2003, it works.
    But, I know Addpicture does not take URLs anymore with 2007 onwards, perhaps its the same with picture.insert as well.
    http://support.microsoft.com/kb/928983/en-us
    The above link gives the solution as "picture fill in a shape such as a rectangle".
  2. Vince E. says:
    Tried to recreate this, but it worked fine for me. I just took the image of the error you showed in the post. Is there more info that can narrow this down a bit?
  3. Ian Hinckley says:
    Hi
    Not sure if this is what you're after, but I just tried this
    Sub Macro1()
    ActiveSheet.Pictures.Insert("http://www.google.co.uk/intl/en_uk/images/logo.gif").Select
    Tied a button to it on the sheet and it seems to work; hope this helps a little
    Ian
  4. Chandoo says:
    @All.. the issue is in Excel 2007. In 2003 ActiveSheet.Pictures.Insert seems to work fine. Unfortunately, I have design this in Excel 2007.. that is why I posted it here..
  5. Ian Hinckley says:
    v2
    Sub Macro1()
    Set n = ActiveSheet.Pictures.Insert("http://www.google.co.uk/intl/en_uk/images/logo.gif")
    With Range("c12")
    t = .Top
    l = .Left
    With n
    .Top = t
    .Left = l
    Ian
  6. Ian Hinckley says:
    That didn't come out very well. This positions at c12, so can change easily:
    Sub Macro1()
    With Range("c12")
    t = .Top
    l = .Left
    With n
    .Top = t
    .Left = l
    Works OK in 2007
    Ian
  7. Chandoo:
    Try 'ActiveSheet.Pictures.Insert'
    With ActiveSheet.Pictures.Insert("C:\Example.png")
    .Left = ActiveSheet.Range("A1").Left
    .Top = ActiveSheet.Range("A1").Top
  8. Jon Peltier says:
    activesheet.pictures.insert "C:\Documents and Settings\Jon Peltier\Desktop\2007 stuff\insert_charts_2007.png"
    Works for me in 2003 SP3 and in 2007 SP2.
    Check the URL, and make sure you have internet connectivity.
    What also works, and is newer (pictures.insert was supposedly deprecated in '97):
    activesheet.shapes.addpicture "C:\Documents and Settings\Jon Peltier\Desktop\2007 stuff\insert_charts_2007.png", false, true, 200,200,100,100
    Unfortunately you must specify dimensions (the last four arguments) and you don't necessarily know them. But the picture size is still related back to the original picture size, so you could use scaleheight and scalewidth to fix this.
  9. Chandoo: I just re-read your post.
    The code I posted works for me. However, I'm using a local picture. If you try to add a picture from the web, this won't work.
    I remember solving this problem before by adding a rectangle shape first, then using the Shapes.AddPicture method to get a picture from the web.
    I'll find that code and post it here.
  10. Chandoo says:
    Some more updates... The code "ActiveSheet.Pictures.Insert (path)" works fine in Excel 2007 at home. Strange it failed miserably on my work laptop. Do you think this has got something to do with SP2 of MS Office 2007 or something like that?
    @Ian, Jon: Thanks for the code snippets. I guess I will use my home installation of excel to do this.
  11. Chandoo:
    Try this on your work laptop:
    Sub test()
    ActiveSheet.Shapes.AddShape msoShapeRectangle, 50, 50, 100, 200
    ActiveSheet.Shapes(1).Fill.UserPicture _
    "http://www.datapigtechnologies.com/images/dpwithPig6.png"
  12. Jon Peltier says:
    I didn't mean to post code with a local file, because both approaches worked with an internet image as well. This is in Excel 2007 SP2.
    activesheet.pictures.insert "http://peltiertech.com/images/2009-07/col_area_noblanks.png"
  13. Jon: Looks like I have SP1 on my client machine! I wasn't paying attention.
    Just checked my home computer where I have SP2, and you're right...looks like they fixed it.
  14. Jon Peltier says:
    I didn't even bother testing in SP1, though I could if anyone cares enough.
  15. teylyn says:
    I'm afraid I don't have a solution, but I find it remarkable that after attaining a certain status in the Excel world, Chandoo does not need to post on an Excel discussion forum to get help for an Excel problem. Instead, he posts on his blog and all the gurus come rushing to his help.
    Isn't Web 2.0 great?
  16. Jon Peltier says:
    Teylyn - I saw Chandoo's tweet first, and followed the link back to his blog.
  17. Chandoo says:
    @Mike.. thank you. I have seen the fill rectangle solution before posting the query here. For that matter, I have also tried the solution of embedding a browser control on a spreadsheet. both of these seemed a bit extreme. That is why I have asked it here.
    But I guess I will end up using it if I had to build this in work laptop.
    @Teylyn: I have thought of posting this in a forum. (Unfortunately I have not been to any excel group in the last 5 years. Last time I was active was when I built a jave based excel sheet construction solution using POI.HSSF classes of Apache... ) After searching for a few hours, I found several forum posts where others had same problem and the solution recommended (using .left and .top parameters) is not working for me. Incidentally most of these solutions are from a certain Jon Peltier 😛
    I thought may be the problem is interesting for fellow blog readers. So I posted it here.
  18. Justin B says:
    Adapting the code in the question,
    [code]
    Sub InsPicture()
    pPath = "http://chandoo.org/images/pointy-haired-dilbert-excel-charts-tips.png"
    With ActiveSheet.Pictures.Insert(pPath)
    .Left = Range("a1").Left
    .Top = Range("a1").Top
    [/code]
    Seems to work fine
  19. Jon Peltier says:
    Looks like it was a problem in 2007 up to SP1, which was corrected in SP2.
  20. Chandoo says:
    @Jon.. seems like the case. I just checked the version at work laptop. it is 12.0.6331.5000 (SP1).
    Thank you so much every one. I really appreciate your time and suggestions in solving this.
  21. Jon Peltier says:
    Glad to help. I couldn't understand why something so straightforward wasn't working.
  22. Kieranz says:
    Hi All
    Is there a way of inserting a motion clip eg animated gif or swf or flv?
    Thks
    • Chandoo says:
      You can insert animated GIFs by inserting them in a browser control through VBA. For other types of movies, I can guess you can insert them as clip art.
  23. ashvini says:
    I WANT THE INSERT PICTURE BY USING COADING
  24. Lutz says:
    so currently i was struggling same as you, chandoo, with the insert picture method in excel 2007/10 from an url and came along your thread here.
    so i re-designed the code on the addshape method as mike was suggesting it and all of the sudden it works just fine.
    thanks alot to you guys, you were a great help
    a big salut from switzerland
  25. Santiago says:
    Hi guys,
    I need help copying and pasting an image with the path in a cell.
    I leave the code.
    And thank you very much!
    Sub Copiarimg()
    Dim pic As Picture
    With ActiveSheet
    Set pic = .Pictures.Insert(Range("f2").Value)
    With .Range("e9:g22")
    pic.Top = .Top
    pic.Left = .Left
    pic.Width = .Width
    pic.Height = .Height
  26. I've played around with the approaches in these comments, and the code below is what I've come up with. The ImagePath can be a local file or a URL. As Jon mentioned above, the trick is to set an arbitrary value for the width and height, then call the ScaleWidth and ScaleHeight methods afterward to reset the picture to its original size. Once the LockAspectRatio property is set, you can change the picture width and the height will automatically scale (or vice-versa).
    Sub AddPictureToRange(TopLeftCellAddress As String, ImagePath As String)
    Dim pic As Shape
    Dim l As Single, t As Single
    Dim temp As Single
    l = Me.Range(TopLeftCellAddress).Left
    t = Me.Range(TopLeftCellAddress).Top
    temp = 10# ' arbitrary value
    Set pic = Me.Shapes.AddPicture(ImagePath, msoFalse, msoTrue, l, t, temp, temp)
    pic.ScaleHeight 1#, msoTrue
    pic.ScaleWidth 1#, msoTrue
    pic.LockAspectRatio = msoTrue
  27. dip says:
    I need some help with inserting pictures. I have an excel file with a column of item numbers next to this row I want to insert a picture of this item. The pictures are coded with the item number so I tried to insert it with one of the codes above:
    Sub InsPicture()
    pPath = "http://img.bricklink.com/P/80/55236.gif"
    That worked but I need to do that for every row separtly.
    So I tried in the code
    pPath = "http://img.bricklink.com/P/80/"&Text(a1;"#")&".gif"
    But that gives errors.
    Anybody ideas?
  28. alex says:
    Hi Nicholas, I used your solution in a related problem in Excel 2003 and it worked flawlessly..thank you!
  29. Richard says:
    Hi Mike Alexander,
    Your solution with some changes was helpful in my problem in XL 2007, thanks.
  30. seejay says:
    thanks all. In addition, I had a problem with multiple pictures inserting (every new picture replaced the prior one). I've changed it a bit, may be helpful..
    Sub test()
    ActiveSheet.Shapes.AddShape msoShapeRectangle, 50 , 50, 100, 200
    ActiveSheet.Shapes(1).Copy
    ActiveSheet.Paste
  31. Jon Peltier says:
    Try this instead:
    Sub test()
    ActiveSheet.Shapes(ActiveSheet.Shapes.Count).Fill.UserPicture _
    • Kez says:
      Thanks to everyone, this thread has been very helpful. However, image inserting still doesn't work quite as expect for me.
      While I can get a picture inserted into an Excel 2010 worksheet using either:
      1) ActiveSheet.Shapes(ActiveSheet.Shapes.Count).Fill.UserPicture...
      2) ActiveSheet.Pictures.Insert(pPath), and
      3) Shapes.AddPicture...
      unfortunately the images all insert with a display size determined not by the actual pixel dimensions of the image but by the dpi resolution.
      So for example, if I insert two copies of the exact same 600x600 pixel image, one with a 300dpi resolution and the other with 72dpi, they display at vastly different sizes on screen.
      While this might be intended behaviour for Excel in order to maintain a WSYWIG printing layout, I actually need a way to insert the image based on the the actual pixel dimesnsions and ignoring the dpi resolution.
      Any help appreciated.
      Kez
  32. Kez says:
    Not doing an intentional bump, but realised I posted in rely to one of the repsonses here instead of to the main thread, so reposting.
    Thanks to everyone, this thread has been very helpful. However, image inserting still doesn’t work quite as expected for me.
    While I can get a picture inserted into an Excel 2010 worksheet using any of the below methods:
    1) ActiveSheet.Shapes(ActiveSheet.Shapes.Count).Fill.UserPicture....
    3) Shapes.AddPicture....
    So for example, if I insert two copies of the exact same 600×600 pixel image, one with a 300dpi resolution and the other with 72dpi, they display at vastly different sizes in Excel on screen.
    While this might be intended behaviour for Excel in order to maintain a WYSIWYG printing layout, I actually need a way to insert the images based on the the actual pixel dimesnsions and ignoring the dpi resolution.
    Kez
  33. Kez says:
    Well, answered my own question 🙂
    For those who might be interested, you can use this function:
    Public Function GetPicDims(strFilePath As String, strFileName As String) As String
    GetPicDims = CreateObject("Shell.Application").Namespace((strFilePath)). _
    ParseName(strFileName).ExtendedProperty("Dimensions")
    End Function
    to get the dimensions of the image you want to insert. Then you can parse the return string and use the width and height values to add a rectangle shape of the appropraite size, like:
    ActiveSheet.Shapes.AddShape msoShapeRectangle 50, 50, iWidth, iHeight
    which you then fill with the picture:
    ActiveSheet.Shapes(ActiveSheet.Shapes.Count).Fill.UserPicture "c:\temp\test.jpg"
    This way the picture gets inserted using the pixel dimensions and the (print) resolution gets ignored.
    If desired, the GetPicDims function can be made more generic to get other ExtendedProperties.
    Kez
Leave a Reply
