Extracting Unique, Duplicate and Missing Items using Formulas [spreadcheats]
Often I wish Microsoft had spent the effort and time on a data genie (and a set of powerful formulas) that can automate common data cleanup tasks like extracting duplicates, makings lists unique, find missing items, remove spaces etc. Alas, instead they have provided features like clippy which are intrusive to say the least.
So as part of our second installment of spreadcheats we will learn how to tackle few of the most common data processing tasks:
Getting Unique Items from a List of Cells
There are 3 simple ways to do this:
  1. Using Advanced Data Filter
  2. Using countif() and auto filter
  3. Using formulas as described here
Assuming you have data as shown in the picture aside (and wishing you will have customers like those):
  • First add a column to the left of the list. Here we will use formulas to fill numbers based on the uniqueness of the cell next to it.
  • Essentially our formula should generate numbers in increasing order as long as the corresponding item is unique and not increase the number otherwise.
  • So the formula for order column can be like this: =IF(COUNTIF(list-upto-that-point, current element)=1,previous-order+1, previous-order)
    See the example below:
    remember, the first cell order is 1.
  • See how we are using both absolute and relative references to fetch the counts.
  • Now add another column to the right of the list, here we will fetch unique items.
  • We will use vlookup() to fetch each of the 12 unique items. The formula goes like this:
    =VLOOKUP(running number,$B$4:$C$22,2,FALSE)
    You can wrap the vlookup() with if() formula to avoid seeing #value errors.
That is all. Using this method you can extract unique items froma list.
Eliminating Doubles from a List
There are 2 ways in which you can find and remove duplicates(doubles) in excel lists with ease:
  1. Using countif() and then auto-filter
  2. Using formulas
The process for finding duplicates using formulas is same as that of finding unique items.
Instead of writing COUNTIF(list-upto-that-point, current element)=1, we now write COUNTIF(list-upto-that-point, current element)=2. Also the first element’s count should be changed to zero.
Once done the list should look like what you see on the side.
Finding Missing Items by comparing one list with another:
Even though this might seem like a different challenge, it is infact same as the above techniques. You need to use countif() to compare first list’s elements with second list. How? that is your home work.
Download and see these formulas in action:
Still having some doubts? Download the excel tutorial – unique & duplicate items and learn by poking around.
Facebook
Twitter
LinkedIn
Learn & be awesome.
Welcome to Chandoo.org
Rebekah S
Reporting Analyst
Advanced Pivot Table tricks
54 Responses
  1. Hi Chandoo,
    This is awesome *****
    Khalid
  2. Oh I found the last one, (custom format hmm)
    You are an Artist Chandoo.
  3. Hi Chandoo,
    Thanks!
    -Ranjith
  4. This was very fun and challenging, thanks for posting! I found all of them (well, Sheet1 was tricky, it seems you’re supposed to find the cell and type it in yourself?). Wasn’t sure if it was cool to post the answers here or not, though. Guess I’ll post SPOILER ALERTS so you can skip the rest of the message if you don’t want to see what I came up with.
    SPOILER! SPOILER! SPOILER!
    My answers appear below.
    Sheet2: cell AB201
    Sheet3: cell J8 (Picture1)
    Sheet4: cell H9
    Sheet5: expand Chart1
    Sheet7: named range (A1:I18)
    1. Wookie – I would love to get a walkthrough of HOW you figured out sheet 1 and a bit of a formula walkthrough for Sheet 6.
      1. Hi Rachel,
    2. I agree, this was a fun way to test your ability to navigate through the functionality of Excel! And since you already posted the SPOILER ALERT warning, I should be safe posting a reply to your comment with some solutions of my own… 🙂
    3. I must admit sheet 7 defeated me, but I have some corrections
      Sheet 6 – I corrected to
      1. I know; that was weird. I did try using a LEFT formula, but I kept getting the $ prefix from the cell address. So I tried a couple of variations using MID and it gave me the result I needed. This is actually the first time I’ve ever tried using a MID formula starting at the first character, but I wasn’t trying to spend a lot of time on it, so I went with what worked.
  5. —–Spoilers———
    Alternate Solutions
    1. @ Rob
      1. @ Navdeep I found PAN3489 by going to “Formulas” and then “Name Manager” and saw there was a field called “Clue1” listed in the Name Manger that references 3489. Finding PAN as the column index was just a bit of a lucky guess through trial and error. Then a note in cell PAN3489 when you navigate there says to try “typing something.” I tried scrolling through the Format Cells menu to see if the text typed in the cell needed to be formatted a certain way, and noticed that “1= Panda” was listed in the custom text menu and tried it. A bit brute force, but I think the desired text entry.
  6. Sheet 1: The answer is not type in Panda. Type 1. There’s a special formatting that replaces 1 with Panda.
  7. WOW! I’ve just found the secret eighth PANDA!
    Truly awesome!!!
    Btw, thanks for the puzzle!
  8. It was truly a artists work
    chandoo you are grate
  9. Guys I Got 8 PANDA in the workbook… 🙂
    Here is the full list:
    2) Sheet2: Goto Cell AB201
    4) Sheet4: Goto Cell H8
    1. 1) Sheet1: Type 1 in Cell PAN3489
      4) Sheet4: Goto Cell H9
    2. Actually, for sheet7, if you set the zoom to 39% or less, you will see the word PANDA. Yet another PANDA! 🙂
  10. Hi,
    Thanks,
    Ram
  11. Hi Chandoo!
    Sheet 1: ??
    Sheet 2: ??
    Sheet 3: Cell J8
    Sheet 4: Cell H9
    Sheet 6: B2
    Sheet 7: ???
  12. I love this time of year and look forward to Chandoo’s egg hunts. Whilst I got all the pandas, I do not understand how sheet 7 works; Where is the source data and why does it only work when zoomed out to 39% or more?
      1. Ha ha, that’s fantastic. Thanks Hui. @Chandoo, thanks for yet another method to decrypt worksheets in order to re-build or explain them better to clients.
  13. These were fantastic and kept me intrigued until I could finish them. (Had to look here for help with Sheet1!) Definitely learning a lot about some new formulas. Awesome, Chandoo!
  14. Ok, just saw the notes on the Zoom 39% on Sheet 7. Can someone explain what’s happening here and why PANDA shows up at that level?
  15. Wow, great exercise.
    Thanks 🙂
  16. Wow.. Awesome set of puzzles Chandoo!!
    Thanks!
    1. Looks like this is an XL feature.. Zooming out the worksheets below 40% level, by default displays all named ranges (more than 2 cells)! Had not come across this till date..
  17. Great works! Was having FUN in finding the pandas. Thanks.
Leave a Reply
