Extract currency amounts from text – Power Query Tutorial
Share
Facebook
Twitter
LinkedIn
Let’s say you got some text values and want to extract the amounts from them. Something like this:
extract-amounts-from-text
Note: Thanks to Monty for posting this problem on our forum.
How to go about it?
We could use a variety of techniques to extract the values.
Extracting amounts from text items – Power Query Tutorial
  1. Specify a list of currency codes. Create a table in Excel and mention the codes. Something like below. Let’s name this table as codes
    currency-codes
  2. Load text data in to Power Query (Use Power Query > from Table or Data > from Table). We get this:
    text-values-loaded-into-pq
  3. Now, let’s bring in currency codes as a cross join. To do this, just insert a new custom column. In the formula section, type
    = Excel.CurrentWorkbook(){[Name=”codes“]}[Content]
    addin-codes-table-to-text-data
  4. This will bring a new column with all currency codes as tables. Expand the column to cross join both tables. See below demo.
    expand-corss-join-two-tables
  5. Now, add a conditional column to check which currency code is present in the text data. You can use below settings:
    conditional-column-on-codes
  6. At this stage, our PQ data looks like this:
    currency-codes-found
  7. Now, let’s filter away any nulls in the Found? column.
  8. Splitting each row by the currency code in next column: this is the tricky part. We can use Text.Split() to split a text value by delimiter. But the result will be a list. We just want one of the items of that list. Simple, we can pass the result of Text.Split() to List.Last() to get that. Use below formula:=List.Last(Text.Split([String],[Custom.Codes]))
    column-formula-to-extract-amount-from-text
  9. We get this:
    output-after-extracting-amounts-almost
  10. Now, convert the Amount column to decimal number. This will throw errors for incorrect values like .530.680268. Simply remove all these errors.
    amounts-after-converting-to-number
  11. Tidy up by removing unnecessary columns and renaming the rest. Load in to Excel. Here is a snapshot of cleaned data.
    final-output-amounts-from-text
Download Example Workbook
Click here to download sample workbook. Try cleaning the data in first tab yourself using PQ. You will realize how awesome and simple this approach is compared to either formula or VBA driven methods.
How are you using Power Query?
These days, PQ (or get data & transform as it is known in newer versions of Excel) has become my go to tool for most data polishing, cleanup and reshaping problems. What about you? Are you addicted to PQ yet? Please share your experiences and wins in the comments section.
More ways to extract, clean and massage data with Power Query:
If this looks interesting, check out below tuts to learn more about PQ.
Facebook
Twitter
LinkedIn
Learn & be awesome.
Welcome to Chandoo.org
Rebekah S
Reporting Analyst
Advanced Pivot Table tricks
26 Responses to “FIFA Worldcup Excel Spreadsheets [Roundup]”
  1. J. J. says:
    Nice roundup! Do you know of any one-page spreadsheets which will be updated by an administrator after each game? Would be nice to be able to print out the latest results whenever I feel like checking them as I probably won't be following closely every day.
    I actually haven't tried any of the above ones yet, but I thought I'd mention this one that I found which makes a nice one-page form you can fill in dynamically. http://exceltemplate.net/sports/world-cup-2010-schedule-and-scoresheet/
  2. Diego Garcia says:
    I would like to recommend you these one: http://www.anotagol.com/
    You can choose your interface language (english, spanish, italian, portuguese, german or french) and your country for the timezone of match. I like it very much.
  3. [...] Passend zu gerade laufenden Fußball-WM gibt es auf Chandoo.org alles wissenswerte über Excel-Anwendungen für den Fußball-Fan. [...]
  4. Rohit1409 says:
    Great!!!
    I strongly recommend this :
    http://www.en.excel-soccer-2010.de/downloads
    Chandoo how you found this ...
  5. Chandoo says:
    @Rohit.. really beautiful file. I missed it during my research. Now, I recommend it. 🙂
  6. Mourad Louha says:
    Hi Chandoo - thanks for the recommandation 🙂 - Regards
  7. [...] Excel, then print it on the other side of your Match Schedule from step 2 above. There are several other Excel spreadsheet templates you can download, but this is probably the only one-page version you can find; plus, it [...]
  8. Robert says:
    Does anybody know how to re-create this(?): http://www.marca.com/deporte/futbol/mundial/sudafrica-2010/calendario-english.html
    ...or do you know where a template can be found? I am DYING to have something like this on my site. When I found it, I had been looking for the longest time for a circular calendar. I found a couple that weren't adequate. Then I stumbled upon this one and my eyes nearly popped out of my head. If anyone can lead me in the right direction, I would be eternally grateful!
    Thanks in advance!
    Robert
  9. Chandoo says:
    @Robert...
    Doing something like that is a lot of work. You can probably get it done with some hired help from a flash developer.
  10. Pedro Wave says:
    @Robert, the World Cup flash in the Spanish Marca newspaper is impresive, but not much as my own animated spreadsheet with the Goals of 2010 World Cup South Africa in Excel that I just published into my blog:
    http://pedrowave.blogspot.com/2010/06/goals-of-2010-world-cup-south-africa-in.html
    Download from here:
    http://cid-6b219f16da7128e3.office.live.com/view.aspx/.Public/Goals%20South%20Africa%20Animated.xlsx
    And start to enter the goals of the rest of matches.
  11. Neil says:
    Has anyone seen, or made, a Spreadsheet where you can record the scorers and see a 'top scorers' chart. Would be a nice enhancement
  12. Chandoo says:
    @Neil... checkout this one http://www.inflexionary.com/sports/world-cup-2010-excel
    it uses macros to fetch scores from web (and provides very comprehensive analysis too)
    @All.. Thanks for the comments. I have updated the post with few more links now.
  13. Sergio Mathias says:
    Check this dashboards too:
    http://dashboards.org/world-cup-dashboards-and-visualizations/
  14. [...] Here is a collection of FIFA World Cup Spreadsheets if you are more in to that sort of thing. | [...]
  15. [...] Cup fever is here!In FIFA Worldcup Excel Spreadsheets Roundup, Chandoo has some links to useful World Cup tracking workbooks. Only one of them (the first one) [...]
  16. [...] World Cup fever is here!In FIFA Worldcup Excel Spreadsheets Roundup, Chandoo has some links to useful World Cup tracking workbooks. Only one of them (the first one) [...]
  17. Hey, you missed ours! It has everything you need and more, but not a whole pile of silly extras (National Anthems, etc).  I'll be making another one for the 2014 world cup.  We had over 4000 hits on it!
  18. Neil says:
    @Michael Harwood.
    Where is it then? You should have posted a link
  19. phillip says:
    Sie sollten an einem Wettbewerb teil zu nehmen für einen der besten Blogs im Web. Ich werde empfehlen Sie diese Seite!
    Google translation: You should take part in a contest for one of the best blogs on the web. I will recommend this site!
  20. [...] and welcome to the forum, Maybe these similar spreadsheets might give you a few initial ideas: FIFA Worldcup Excel Spreadsheets [Roundup] | Chandoo.org - Learn Microsoft Excel Online If you have specific areas / formulae / layout choices for parts of your spreadsheet that you are [...]
  21. Petros says:
    Calling all football fans around the globe! The biggest football festival will kick off on the 12th June 2014 and everyone is placing their bets of who will have the honour of lifting the golden trophy.
    Use our free interactive Excel templatel to predict the World cup finalists ! No macros !
    http://www.spreadsheet1.com/world-cup-2014-free-excel-prediction-template.html
  22. marten says:
    I also made a Worldcup-tracker, with MS Access, which can also generate reports in Excel
    e.g. a match-schedule with locations on y-axis and dates on x-axis, see:
    http://worktimesheet2014.blogspot.com.es/2014/05/excel-with-match-schedule-for-2014-fifa.html
    and:
    http://worktimesheet2014.blogspot.com.es/2014/05/match-access-app-to-track-world-cup.html
  23. Vivek Ranjan says:
    where can i find raw data in excel file format of fifa world cups (1930-2014)
Leave a Reply
