Send mails using Excel VBA and Outlook
Share
Facebook
Twitter
LinkedIn
This is a guest post by Vijay, our in-house VBA Expert.
Send mails using Excel VBA and Outlook - how to
In this article we well learn how to use VBA and Microsoft Outlook to send emails with your reports as attachment.
Scenario
We have an excel based reporting template for the Customer Service Dashboard. We want to update this template using VBA code to create a static version and email it to a list of people. We will define the recipient list in a separate sheet.
Features
1. Code will automatically create necessary folders to save the output file.
2. Email sheet to contain the list of people who are going to receive the report.
3. Sending mail using Microsoft Outlook, primary target is corporate people who are using Outlook as their mail program.
On our VBA project we would need to add references to the below
1. Microsoft Outlook Object Library
2. Microsoft Scripting Runtime Library
Please note the Outlook library will be available depending on the version of Microsoft Outlook installed on your system, in the example workbook the reference is towards version 14 as available with Outlook 2010. If you have a different version of Outlook installed on your system, you need to point to the correct library installed.
We have assumed the data used to create the report is already available in the sheet called “rawData”.
We have then updated the “rawData” sheet with 2 new columns having the Date and Time.
Date has been calculated in the rawData sheets using the Date Function.
=DATE(YEAR(B2),MONTH(B2),DAY(B2))
The time has been calculated by converting the actual time of the call into the relevant 30 minute interval.
=INT((TIME(HOUR(B2),MINUTE(B2),SECOND(B2)))/(1/48))*(1/48)
If you need to setup your report into 15 minutes interval then replace 1/48 with 1/96.
We have then used the COUNTIFS and SUMIFS function to create the data view in the Interval Data sheet.
Understanding the VBA code to send mails
I will be discussing only the key elements of the code here.
Sheets(Array("Cover", "Interval Data", "rawData")).Copy
This list will create a new workbook containing the 3 sheets that we have included within the Array() parameter. If your report has more sheets feel free to add them.
Set objfile = New FileSystemObject
If objfile.FolderExists(xDir & xMonth) Then
If objfile.FileExists(xPath) Then
objfile.DeleteFile (xPath)
newWB.SaveAs Filename:=xPath, FileFormat:=xlOpenXMLWorkbook, Password:="", WriteResPassword:="", ReadOnlyRecommended:=False _
, CreateBackup:=False
Application.ActiveWorkbook.Close
xNewFolder = xDir & xMonth
MkDir xNewFolder
The above code checks if the correct folder exists for the report to be saved or not and creates one if not existing. This also takes cares of overwriting the existing report in case you need to re-run the report again during the same day.
Creating the List of recipients
currentWB.Activate
Sheets("Email").Visible = True
Sheets("Email").Select
strEmailTo = ""
strEmailCC = ""
strEmailBCC = ""
xStp = 1
Do Until xStp = 4
Cells(2, xStp).Select
Do Until ActiveCell = ""
strDistroList = ActiveCell.Value
If xStp = 1 Then strEmailTo = strEmailTo & strDistroList & "; "
If xStp = 2 Then strEmailCC = strEmailCC & strDistroList & "; "
If xStp = 3 Then strEmailBCC = strEmailBCC & strDistroList & "; "
Loop
xStp = xStp + 1
Loop
The above code will create the list of people for whom the report is intended. We make use of the Do Until Loop here to update the 3 variables to hold the TO, CC and BCC list. The actual email addresses are captured from the Email sheet of the report template.
Please note: there should be no blanks in the list when you are defining the same.
Set olApp = New Outlook.Application
Dim olNs As Outlook.Namespace
Set olNs = olApp.GetNamespace("MAPI")
olNs.Logon
Set olMail = olApp.CreateItem(olMailItem)
olMail.To = strEmailTo
olMail.CC = strEmailCC
olMail.BCC = strEmailBCC
olMail.Subject = Mid(xFile, 1, Len(xFile) - 4)
olMail.Body = vbCrLf & "Hello Everyone," _
& vbCrLf & vbCrLf & "Please find attached the " & Mid(xFile, 1, Len(xFile) - 4) & "." _
& vbCrLf & vbCrLf & "Regards," _
& vbCrLf & "Chandoo.Org"
The above code creates a new instance of Outlook and then logs in to your default mailbox, using which we will be sending the mail out to the recipients. We also create the body of the mail and specify the To, CC and BCC list.
olMail.Attachments.Add xPath
olMail.Display
Finally we add the attachment to the email we have created and then using the Display method bring it on the screen. You may also use the .Send method to send the mail directly.
That is all the code we needed to create a copy of the report with selected few sheets and then send them out using VBA. There are a lot of other methods using which you may be able to send out mails, however this specifically helps out to create report templates to use within your organization and send out mails.
Do you also use VBA and Other methods to send mails, if yes please share the same for the benefit of everyone.
Download Excel File
Click here to download the file & save it on your system and use it to understand this technique.
Do you use Excel to automate emails?
I often use Excel to automatically email reports & messages. This is quite useful when you have to send a snapshot of a report to a large team, but need to customize the email for each recipient.
What about you? Have you used Excel to automate emails? What is your experience like? Do you use VBA or some other technique? Please share using comments.
More on VBA & Macros
If you want to learn more about using VBA to automate reporting & email tasks, read these:
Join our VBA Classes
If you want to learn how to develop applications like these and more, please consider joining our VBA Classes. It is a step-by-step program designed to teach you all concepts of VBA so that you can automate & simplify your work.
Click here to learn more about VBA Classes & join us.
Facebook
Twitter
LinkedIn
Learn & be awesome.
Welcome to Chandoo.org
Rebekah S
Reporting Analyst
Advanced Pivot Table tricks
25 Responses to “Display Alerts in Dashboards to Grab User Attention [Quick Tip]”
  1. Alex Kerin says:
    I prefer the red,grey,light grey,black icon set. I've also used in-cell pie charts from Fabrice's Sparklines for Excel as an alert which could also provide another piece of information.
  2. Alex Kerin says:
    I prefer the red,grey,light grey,black icon set. I've also used in-cell pie charts from Fabrice's Sparklines for Excel as an alert which can also provide another piece of information.
    For Excel 2007, your formula should do the same as the Excel 2003 version, so that non-alert rows are blank - if they are 0, the unnecessary green icon will show
  3. Rohit1409 says:
    Hi Chandoo,
    Nice Post !! just to add something for EXL 2003, we can also 4 Ifs and link to the alert data
    For Ex: If we have alert data in Cell A2 and want to split in 4 orders namely <25%, 25-50%, 50-75% and 75%< then we can following formula and put fonts as you have suggested :
    =IF(A2<0.25,CHAR(153),IF(A2<=0.5,CHAR(155),IF(A2=0.76,CHAR(152)))))
    And then using Conditional Formating we can dashboard reflected on different COLOURS as per their respective alert.
    Best Regards
    Rohit1409
  4. Rohit1409 says:
    Hi Chandoo,
    Nice Post !!! just to add something for EXL 2003, we can also 4 Ifs and link to the alert data
    Best Regards
    Rohit1409
  5. Rohit1409 says:
    The Complete formula [Don't Know how it got cut ]
    PS : Use in single line [I have split it to avoid cuts 😉 ]
  6. Rohit1409 says:
    Hi Chandoo..
    why it is not displaying the complete formula..
    anyways here is the balance
    "=IF(A2<0.25,CHAR(153), IF(A2<=0.5,CHAR(155), IF(A2=0.76,CHAR(152)))))"
  7. Chandoo says:
    @Rohit... your formulas are fine. Just that the width of comment area is fixed and hence my website is cropping it at 640pixels. I just edited your formula and added few white spaces so that it wraps nicely.
    Very good idea btw.. kudos!
  8. Tom says:
    Maybe just go for 'bold' ; 'underline' or 'italic' to draw the users attention? Those methods (if those can be called methods) are used cross media type (books, journals, blogs, billboards, ...) to guide the readers eye to valuable information.
    Just a basic thought
  9. Chandoo says:
    @Tom.. good idea..
  10. [...] has a very nice writeup on how to add such alerts to dashboard sheets. Possibly related posts: (automatically generated)Divide your data set into workbooksHow to enforce [...]
  11. Ramesh Panakkal says:
    Hi Chandoo,
    You certainly grabbed my attention! although I wasn't sure what my brother (Suresh) and cousin (Shyam) were doing right, and I was doing wrong? 😉
    I love your blog btw - Many thanks for all your hard work in unravelling the secrets and mysteries of Excel!
    Best regards
    Ramesh
  12. Jeff Whitesel says:
    I thought I saw an advertisment for a book about learning excel called excel himalaya or something. It cost about 35.00 us money but seemed to have the things I need to have my admin assistant to start to use. I was hoping to start with this book and then send her to school if she shows some interest and aptitude. Any help on this would be appreciated. Thanks
    Great web site and information!!!!
  13. [...] There are lots of numbers in this dashboard. I would suggest adding few more visualizations like showing indicators or applying conditional formatting or replacing a table with a chart. This would reduce the [...]
  14. [...] is the same technique as alert icons in dashboard. Just that I also showed green [...]
  15. [...] is the same technique as alert icons in dashboard. Just that I also showed green [...]
  16. RROBBITT says:
    Hi Chandoo
    Firstly thanks for all the cool tips on how to use Excel better.
    I am new to the site and have a question which you may be able to assist with but dont know if these comment boxes are the best way of asking ?
    I am looking at assets and trying to calculate the depreciation total by taking a year (say 2010) adding the expected life of the asset (say 10 years) then comparing that to a future date (say 2015) using an IF statement. The calculation in normal is - IF((year in col B (2010) plus 10years)>year 2015, add a years depreciation, otherwise leave blank). The converted date value does not appear able to add 10 years in order to compare it to 2015. Am I missing something ?
  17. Rocky says:
    I use the “IF” Statement in conjunction with Conditional Formatting in MS Excel to give verbiage to alert one of a required action, dependant on a review date. This makes a visual stimulus, plus it clues one as to what the conditional format is trying to warn you about and what follow-up actions are required.
  18. Wow, I'm really impressed with dashboards. I had no idea this stuff was even possible with excel. I'd like to offer an interactive dashboard to my customers, showing analytics of their data. I have a .pdf file with the datapoints. I'd like them to enter the data on my website, and be able to see their data. Is something like that possible.
  19. Adam G says:
    Hi Chandoo,
    I've recently purchased the package for both templates.
    In the portfolio dashboard,under the calculations worksheet, I'm attempting to change the date range in the gantt chart to show only the range of the project that starts in late 2013.  How do I do this?
    Adam
  20. [...] is the same technique as alert icons in dashboard. Just that I also showed green [...]
  21. Bianca says:
    Hi Chandoo,
    I'm new at Excel Dashboard and found your blog really useful and helpful! It's very nice of you that you dedicate your time to do this.
    Could you please explain how can I use Alerts based on dates on a Dashboar?
    For example, if a target date is coming closer to the actual date, the alert is yellow or red.
    I'd really appreciate some help!
    Thank you
  22. Marco says:
    Where can I download the file Excel of Averall Statistics ???
    Thanks a lot.
Leave a Reply
