This article is part of our VBA Crash Course. Please read the rest of the articles in this series by clicking below links.
- What is VBA & Writing your First VBA Macro in Excel
- Understanding Variables, Conditions & Loops in VBA
- Using Cells, Ranges & Other Objects in your Macros
- Putting it all together – Your First VBA Application using Excel
- My Top 10 Tips for Mastering VBA & Excel Macros
In part 3 of our VBA Crash Course, we are going to learn how to speak with various Excel objects like Cells, Ranges etc. and deal with them.
Objects – what are they?
Any thing and everything is an object. Your dog, your bed, your neighbors cat, their car, your bike, your computer, the shiny new Excel workbook you just created, my website, your email account – every thing is an object. For that matter, Lady Gaga’s meat dress is an object too. But that is a whole different subject.
From our “We are nuts” example yesterday, you can already see these objects:
- One awesome owner (that is you)
- 24 store manager objects
- 24 store objects
Some sample objects you can find in Excel workbooks
- Cells, lots of them
- Ranges of cells
- Worksheets
- Charts
- Pivot Tables
- The entire workbook
Objects & Excel VBA
Since your Excel workbook is nothing but a collection of objects, whenever you want to make any change (like modify a cell’s value or recolor a chart), you need to refer to the corresponding object and do the necessary thing.
But how do we talk to these objects from VBA. Well, to know that, you must understand how an Object looks to our eyes vis-a-vis computer’s eyes. Here is an illustration to help you understand the difference.
As you can guess, Objects have Properties. In the case above, color RED is a property of the cell object.
Objects – What are they made of?
In VBA world, objects are made of 2 things – properties & methods.
The color of a cell is a property.
You use copy method to copy cell’s value to Excel’s clipboard.
In other words, properties are what an object has. Methods are operations you do on the object.
Note: Certain objects also have a special class of methods called as Events. An Event is a special type of method that runs only when a circumstance is met. For example, select a cell, Excel internally runs SelectionChange Event on the current worksheet.
How do we access these properties & methods?
In plain English, if you want to know the color of a cell, you would ask “What is the color of cell A4?”
In Excel VBA language, the same becomes Range(“A4”).Interior.Color
Notice how the dot (.) is used like of in our plain English version.
Dot (.) is your best friend when dealing with objects. Since many Excel objects have dozens of properties and methods associated with them, to help us understand and use right properties, VBE (Visual Basic Editor) shows all the properties and methods whenever you press . after typing an object, like this:
Most commonly used Objects in VBA:
While there are no single set of objects that are used by everyone for every need, there are a few VBA objects that are used in many situations. In this section, we will examine these objects.
Range Object:
Range object is used to refer to a range of cells. For example Range(“A1:A10”) refers to the cells A1:A10 in the current worksheet. Range has a lot of useful methods and properties. One of the commonly used property is is Range(“A1:A10”).cells which refers to all the cells in the range.
Tips on using range object:
- You can use named ranges in Range object like this: Range(“myStoreList”)
- You can use square brackets [] to refer to ranges like this: [A10] refers to Range(“A10”)
- You can use variables in Range Object like this: Range(mylist) refers to whatever address is stored in mylist variable.
- You can use variables along with static text, like this: Range(“A1:A” & endPoint) refers to the range A1:A120, assuming endPoint variable is 120.
ActiveCell Object:
Active cell object refers to the currently selected cell. If you have selected a range of cells, usually ActiveCell refers to the top-left cell.
Tips on using ActiveCell Object:
- Use ActiveCell.End(xlDown).Activate to select the last cell in the same row with a value (assumes you have no breaks in between). You can also use options like xlToLeft, xlToRight, xlUp too.
Selection Object:
Selection object refers to the currently selected cells or anything else that is selected (like a chart or drawing shape).
How to learn about various Excel Objects and use them:
Excel has a lot of objects. Some times objects contain other objects. For example a Range contains some Cells. A Selection may contain some Charts. Understanding the hierarchy and properties of all these objects is a tough task. But thankfully, there is help.
Here are my top tips to learn about various Excel Objects:
- Use Macro Recorder: Whenever you need to use an object that you are not familiar with, just use built-in macro recorder and do some operations on that object. Now stop it and view the code. You would have a good idea how to deal with that object. For ex. if you want to learn how to use VBA to refresh a pivot table, just start recorder, select the pivot, refresh it and stop the recorder. Now go and see the code and you will have a good idea how to refresh pivot tables from VBA.
- Use VBA Help: Excel VBA has a very good help system. Just go to Visual Basic Editor (ALT+F11) and press F1 to start the help. Type the object name you want help on and read thru the pages to learn. VBE also has a helpful screen called “Object Browser” to visually browse various Excel objects and understand the methods & properties.
- Learn from Code Examples: There are several sites, including Chandoo.org that publish frequent articles, code samples and tips on Excel & VBA. Follow a handful of these sites and learn from the shared examples.
- Take up some project: In your day to day work, you always see some problems that can be solved with VBA. So go ahead and take up one such task and try to do it using VBA. This is a great way to learn a new language like VBA.
- Join a Training Program: Last but not least, joining a training program is a good way to learn VBA. If you want a good program on VBA, consider joining our upcoming batch of VBA Classes.
Putting it all together – a Daily Sales Tracker for “We Are Nuts”:
So far you have learned What is Excel VBA, How to use variables, conditions & loops and How to use various Excel Objects.
In the next part, learn how to create a VBA Application combining all the things you learned so far.
What are your tips for learning about Excel Objects & Using Them?
Excel Object Model is vast and deep. There are a lot of things that we can learn (and remember), but there are a lot more that we will never know or memorize until we need to use them. I always rely on built-in macro recorder to learn about the objects and then modify the code until it works just right.
What about you? How do you learn about Excel Objects? Please share your tips & ideas using comments.
Join Our VBA Classes
We run an online VBA (Macros) Class to make you awesome. This class offers 20+ hours of video content on all aspects of VBA – right from basics to advanced stuff. You can watch the lessons anytime and learn at your own pace. Each lesson offers a download workbook with sample code. If you are interested to learn VBA and become a master in it, please consider joining this course.
37 Responses to “Quickly Change Formulas Using Find / Replace”
Chandoo,
this is a really cool stuff what I use quite often. In addtion this method also could be a good choice to switch the reference type of the formulas from relative to absolute or vice versa. (just simply replace the $ in the same way).
Andras
@Andras: you are right, we can use find / replace to change references, reference types etc. Now, only if they had regex in find/ replace, we could so much more 🙂
@Tony Rose: Thank you. This is very useful and powerful feature. I even use it for cleaning up data. While formulas are good, they are not the solution for every problem. Often when I need more powerful cleanup / changing, I copy paste the stuff to text editors like notepad++ and then use their find/replace to do the dirty task.
What if i have to change the formula from ='Analysis'!C1 to 'Analysis 1'!C1?
I tried doing it using Find /Replace but could't. Encountered some errors.
And is there a way to change this using VBA???
Did you ever get a reply to this?
Ollie
to make your life easier, suggest you to avoid (Space) in worksheet names whenever possible. Consider (underscore) instead.
As the first formula wouldn't have the single apostrophes (since there's no space) need to include that in replace. So, search for:
Analysis
and replace with:
'Analysis 1'
This could be the most useful tips I've seen in a while. I use this all the time and can instantly change 400 formulas with a few clicks. Like so many other functions in Excel, I don't know what I would do without this one.
Keep 'em coming!
[...] on formulas: 5 areas where mouse kicks keyboard’s butt | Edit formulas in bulk using Find / Replace | Excel Formulas Online [...]
THANKS BRO
You, sir, are a god among men...
This is really cool. Your just save me hours of work. Thanks.
Thanks so much for this fix! It saved me tons of work. I'm muddling my way through and this really helped!
Oh... My... God!
This tip just saved me about 2 hours every month! I can't believe how easy it is to use. Now, can somebody tell me who I should call to get a refund for the previous 100 hours I spent manually changing formulas cell by cell?
Thanks so much!
THANK YOU!!!
THANK YOU!!!!
You saved me hours, I had a sheet that has more than 500 formulas, and i needed to replace the year in all of them, you saved me hours
Awesome info on replacing cell addresses in formulas. I have never heard about Ctrl+` before. Thank you!
I have something inside a formula like:
=sum(A1, A2*10) all over I now need to get rid of the *10 {=sume(A1, A2)} I thought to use the find replace trick above but with a blank in the replace but it then outputs just zeros. I thought I could trick it by doing *1 but then it just turns into =*1) with none of my references. Does anyone have an idea how to do this?
The Ctrl+ trick is cool.
@T
Instead of replacing with a blank try replacing
*10)
with
Thank you! This literally will save me hours and hours of time, and that's without losing my sanity in the process!
I have Sheet(1), Sheet(2), Sheet(3), etc ... Sheet(100).
Then there's a summary tab where I want to recap information on all those different sheets. Is there anyway to create a formula on the Summary tab to get ='Sheet(1)'!B$29 copied down for all 100 sheets without having to change each sheet # within the formula by hand?
@Brigitte
If you have a list of the sheet names in A2:A100
In B2: =INDIRECT("'"&A2&"'!$B$29")
Copy down
or if you don't have a list of the sheets names you can make it up on the fly
=INDIRECT("'sheet("&ROW()-1&")'!$B$29")
Copy down
Thanks for the suggestion. However, I copied your formula right back to my file and it didn't work. So I did it another way. I put the tab/cell reference in one cell and then did an =INDIRECT() to capture that information.
K2="'Sheet("&L2&")'!B$29" which has a value of 'Sheet(1)'!B$29
B2=INDIRECT(K2) which now has a value of 40 (contents on Sheet(1).
Thank you!!!!
Thank you ..
Hi, Out of all the formulae, I wish to replace the formula which has generated 0 value with blank space? I am unable to do it with find and replace function,
Please suggest.
Thanks.
Chandoo, you literally just saved me about 2 hours of work. I had a document with a daily report in two formats. The second formate just linked to all the appropriate cells in the other format (different sheets). This was 180 references that needed to be changed and I had to make this for a 4 week period (aka 28 different sheets at 180 references to change per sheet).
Thanks so much.
I have tried this way and without using the Ctrl-` formula view
Either way, I am trying to do something simple, but it won't let me.
I have a bunch of cells with a simple math formula like
=-(0.5*20)
various values in each cell, multiplied by 20
I simply want to change the multiplier globally from 20 to 25. But when I tell it to find *20 and replace it with *25, it replaces the entire cell contents with *25, rather than just replacing the *20 portion of the cell contents.
Can anyone assist with this? Seems so simple, but Excel isn't letting me do it.
Search/Replace 20 or 20) with a cell Reference eg A1 or A1)
Then put the value 25 in A1
By using a * in the search it replaces all the text
how to find a specific cell's value in a column & replace replace it with another cell value i actually need a method to replace a data in ca column and replace with the value i have in a specific cell can i give a [ location ] of data to what i need to find and then give row or column range to where i need to find and the given value & then give a [ location ] of data to what i want to be replace with the find and replace by row & column range & than by specific criteria and than by specific location.
please help.
how to find a specific cell’s value in a column & replace replace it with another cell's value.
i actually need a method to find a specific cell's data in a column and replace it with the value i have in a specific cell.
can i give a [ location ] of data to what i need to find and then give row or column range from where i need to find the given value & then give a [ location ] of data to what i want to be replace with.
please help.
how to find a specific cell’s value in a column & replace it with another cell’s value.
i actually need a method to find a specific cell’s data in a column and replace it with the value i have in a specific cell.
"find and replace by row & column range & than by specific criteria and than by specific location."
in more than 100 sheets in entire workbook
please help.
This is a great tool, does anyone knows an easiest way??
I'm working with a system that has over 59000 references... so every time the replace all is activated. I lose an entire day.
i actually needs to find cell number "D12" in column "D" and replace with Cell Number "B8" for example
find what = Cell Number "D12" John McNamara
find Where = in Column "D"
Replace with = Cell Number "B8" Bieber D'Souza
Replace Range = Column "D"
In which Sheet = All Sheets in Work Book (more than 100 Sheets)
Note: in every Sheet Cells Number "D12" & "B8" containing Different Employ Name but the find rang and replace rang are same in every sheet and find what cell number and replace with cell number are same also.
please help!
thank you. saved lot of time.
Thank you from the bottom of my heart!
Hi, I am trying to figure out how to use RE to find and replace several values in a column. Using find and replace does not work because of the values I am working with. I have a column with hundreds of rows that have a description of several operating systems and other info, which looks like this: Windows Server 2008 R2 Member Server Security Technical Implementation Guide; Windows 2008 Member Server Security Technical Implementation Guide; Solaris 10 10 SPARC SECURITY TECHNICAL IMPLEMENTATION GUIDE; and Windows Windows 2003 Member Server Security Technical Implementation Guide.
I need to be able to find and replace (or basically curtail the descriptions) to be Windows 2008 R2; Windows 2008; Windows 2003; and Solaris 10. BUT when I run find and replace with just *2008*, it finds every instance, including the ones with R2 at the end. I need it to only change the ones with 2008 to Windows 2008 and the ones that have 2008 R2 to Windows 2008 R2. I know it is possible, but I have no clue on how to write a macro to do this.
Thanks for your help,
Gerard
Wickedly efficient workaround. Excel really is a powerhouse program, all you have to do is dig into it. Ctl ~ exposes the formulas, and Ctl H allows for the multi edit. Brilliant, Chandoo!
