Excel Links – Dilbert is Recession-proof Edition
I guess the title says it all. I have realized that most of the readers here connected with the phrase “pointy haired dilbert” and the logo. So I axed the excel@work and brought the hairy man back.
In this edition of excel links:
Jumping to next cell during data entry
Debra shares a very interesting trick that can be handy if you spend a lot of time doing data entry in excel. Just define a named range for all the cells that you need to visit. Now select the named range and then when you tab you will automatically move to the next cell in the defined range.
Array formula trick to include all values
Here is a sweet array formula trick. We all know a formula like =SUM((C2:C101="Male")*(D2:D101="Tx")*(E2:E101)) would sum up all the cells in e2:e101 when column C is Male and column D is Tx. But what if you want to match everything in one column but apply conditions on the other columns? Well, the formula =SUM((D2:D101=H3)*(E2:E101)*(IF(G3="All",TRUE,(C2:C101=G3)))) is for you. More on the DDoE blog.
Peltier teaches us some very neat auto filter tricks, including how you can add the |filter the range based on the selected cell’s value” button to your excel ribbon / menus.
String Manipulation UDFs for you
Douglas at Newton Excel Bach realized that he is spending fair bit of time writing lengthy formulas in excel to manipulate text. So he went ahead and made a sweet list of user defined formulas that you can download here.
The functions are, leftw(): Return the first word(s) from a string, rightw(), Midw(), FINDrev(): Find from the right hand end, Leftval(): Extract a value from the left end of a string, Rightval(), Reverse().
A very nifty find / replace hack, for MS Word
Of course we post a lot of tips and trick on using Excel. But an MS Word tip cant hurt you. Here is one I found extremely nifty. Do you know that you can use Find / Replace in MS Word to search patterns?
Browse earlier posts on excel links
Have a great week everyone.
Comments
RSS feed for comments on this post. TrackBack URI
Leave a comment
If you have a question, please ask in the forums
At Pointy Haired Dilbert, I have one goal, "to make you awesome in excel and charting". PHD is started in 2007 and today has 300+ articles and tutorials on using excel, making better charts.
Welcome back “Pointy hair Dilbert” !
Good Choice. I really like the PHD brand
@Daniele, Alex: thank you..
My comment is short, if I were to present a problem could you direct me to a solution somewhere in your blog?
Bob
Yeah.. you can. Please ask the question in the forums. That way either me or someone else from our community will help you out. Here is the URL : http://chandoo.org/forums/
