My guest post on monitoring web page changes using google docs is posted in Digital Inspiration – one of the most popular technology blogs. Do read it to learn a little bit about using XPATH, RSS Feeds, Google Spreadsheet import() functions.
Here is a summary of the technique:
- First go to the web page which you are planning to track using spreadsheets
- For each item on the web page that needs to be tracked, findout its XPATH (learn more about XPATH)
- Create a
importXML()formulas for each of this elements in your Google spreadsheets. - Finally, save the spreadsheet and subscribe to its RSS Feed to keep track of the web page you are aiming to monitor.
If you are looking for a way to access RSS feeds from your Excel sheet, read this.
54 Responses
Hi Chandoo,
This is awesome *****
Khalid
go to AB201 on Sheet2, you will see Panda there !!!
Press F2 in Cell A1 and then read the actual text !!
In Sheet 2 go to Cell AB201. You will find one.
There is one on first sheet, if you press F5 (goto), the word PANDA can be seen there.
Oh I found the last one, (custom format hmm)
You are an Artist Chandoo.
Hi Chandoo,
Thanks!
-Ranjith
yeah! found all 7 panda, time to go to china.
This was very fun and challenging, thanks for posting! I found all of them (well, Sheet1 was tricky, it seems you’re supposed to find the cell and type it in yourself?). Wasn’t sure if it was cool to post the answers here or not, though. Guess I’ll post SPOILER ALERTS so you can skip the rest of the message if you don’t want to see what I came up with.
SPOILER! SPOILER! SPOILER!
My answers appear below.
Sheet2: cell AB201
Sheet3: cell J8 (Picture1)
Sheet4: cell H9
Sheet5: expand Chart1
Sheet7: named range (A1:I18)
Wookie – I would love to get a walkthrough of HOW you figured out sheet 1 and a bit of a formula walkthrough for Sheet 6.
Hi Rachel,
I agree, this was a fun way to test your ability to navigate through the functionality of Excel! And since you already posted the SPOILER ALERT warning, I should be safe posting a reply to your comment with some solutions of my own… 🙂
I must admit sheet 7 defeated me, but I have some corrections
Sheet 6 – I corrected to
I know; that was weird. I did try using a LEFT formula, but I kept getting the $ prefix from the cell address. So I tried a couple of variations using MID and it gave me the result I needed. This is actually the first time I’ve ever tried using a MID formula starting at the first character, but I wasn’t trying to spend a lot of time on it, so I went with what worked.
Sheet1: Type 1 in PAN3489
Sheet6: =LEFT(ADDRESS(9,2^3*23*59,4),3)&BIN2HEX(11011010)
Slight change…
For sheet 1 goto PAN3489 and type in 1. The word PANDA appears.
Love it!
Sheet 6 was my favorite. How many people still know what binary, hex and octal are? :o)
—–Spoilers———
Alternate Solutions
@ Rob
You reach PAN3489 by pressing Ctrl + End to bring you to the last used cell in Sheet 1
@ Navdeep I found PAN3489 by going to “Formulas” and then “Name Manager” and saw there was a field called “Clue1” listed in the Name Manger that references 3489. Finding PAN as the column index was just a bit of a lucky guess through trial and error. Then a note in cell PAN3489 when you navigate there says to try “typing something.” I tried scrolling through the Format Cells menu to see if the text typed in the cell needed to be formatted a certain way, and noticed that “1= Panda” was listed in the custom text menu and tried it. A bit brute force, but I think the desired text entry.
Clever!
The Data Validation one took me a bit. Had to resort to brute force.
Thanks for the fun!
Awesome! Found 7 pandas in 20 minutes)))
Sheets 1 and 6 were the best!
Thanks!
Sheet 1: The answer is not type in Panda. Type 1. There’s a special formatting that replaces 1 with Panda.
when you changed the zoom level to 39% or below, you will see the name of namedrange (if any)
WOW! I’ve just found the secret eighth PANDA!
Truly awesome!!!
Btw, thanks for the puzzle!
Found them all – very inventive. Had to think outside the “box”. Great fun!
It was truly a artists work
chandoo you are grate
it is fun and great invent
Guys I Got 8 PANDA in the workbook… 🙂
Here is the full list:
2) Sheet2: Goto Cell AB201
4) Sheet4: Goto Cell H8
4) Sheet4: Goto Cell H9
Actually, for sheet7, if you set the zoom to 39% or less, you will see the word PANDA. Yet another PANDA! 🙂
Thanks,
Ram
Hi Chandoo!
Sheet 1: ??
Sheet 2: ??
Sheet 3: Cell J8
Sheet 4: Cell H9
Sheet 6: B2
Sheet 7: ???
Sheet1 F5
Sheet2 AB201
Sheet3 Picture1
Sheet4 H9
Sheet5 Chart
Sheet7 Zoom to 30%
I love this time of year and look forward to Chandoo’s egg hunts. Whilst I got all the pandas, I do not understand how sheet 7 works; Where is the source data and why does it only work when zoomed out to 39% or more?
@Leon-K
When you change the zoom level to be less than 40% Excel shows the Ranges which have Names applied to them
Ha ha, that’s fantastic. Thanks Hui. @Chandoo, thanks for yet another method to decrypt worksheets in order to re-build or explain them better to clients.
These were fantastic and kept me intrigued until I could finish them. (Had to look here for help with Sheet1!) Definitely learning a lot about some new formulas. Awesome, Chandoo!
Ok, just saw the notes on the Zoom 39% on Sheet 7. Can someone explain what’s happening here and why PANDA shows up at that level?
@Bryan
Wow, great exercise.
Thanks 🙂
Hi Chandoo,
Gr8 …had fun in searching it. I got 5 out of 7.
You are brilliant.
Found all except in sheet6 as not able to understand formula.
thanks
Raja Aurongzeb
I am not able to find 1st Panda, which is on Sheet1. Rest all I have found.
Wonderful Chandooji… you are brilliant.
Wow.. Awesome set of puzzles Chandoo!!
Thanks!
Looks like this is an XL feature.. Zooming out the worksheets below 40% level, by default displays all named ranges (more than 2 cells)! Had not come across this till date..
Great works! Was having FUN in finding the pandas. Thanks.
Had fun doing this, Found 5 and the rest I saw clues on here 🙂
I really enjoyed when finding the pandas.And also I am so surprised.Very Nice thought and Excellent.
This was fun! Thanks!
Nice and fun post. Thanks, Chandoo!
