Transpose this address data [VBA homework]
Here is an interesting problem to keep you busy.
transpose-address-data-problem
Transpose the address data in column A into the format indicated in C:G using either VBA, formulas or Power Query. Once done, post your answers in comments section.
Read these rules before solving:
  • First download the problem workbook.
  • Each address may have up to 8 lines.
  • Each address is delimited by a blank line.
  • Once you finish your formula / VBA / Power Query code, when pasting that in comment box,
    • First write <PRE>
    • then paste your code
    • Then write </PRE>
Go ahead and solve.
Tips: Here is a FREE VBA Crash course in case you are new.
Facebook
Twitter
LinkedIn
Learn & be awesome.
Welcome to Chandoo.org
Rebekah S
Reporting Analyst
Advanced Pivot Table tricks
147 Responses
  1. Sub Vertical_Records_into_Matrix()
    Set Rng = Range(“A1:A” & Cells(Rows.Count, 1).End(xlUp).Row)
    R = 1
    For Each a In Rng.SpecialCells(xlCellTypeConstants, 23).Areas
    RC = a.Rows.Count
    Cells(R, 3) = Cells(a.Row, 1)
    Cells(R, 4) = Cells(a.Row + 1, 1)
    Cells(R, 5) = Cells(a.Row + 2, 1)
    Cells(R, 6) = Cells(a.Row + 3, 1)
    Cells(R, 7) = Cells(a.Row + 4, 1)
    Cells(R, 8) = Cells(a.Row + RC – 1, 1)
    If Cells(R, 7) = Cells(R, 8) Then Cells(R, 8) = “”
    R = R + 1
    1. I have tested your code but it is not working properly. Same address is repetting. So I think you need to check it again.
  2. Sub TransposeAddress()
    LstRw = Cells(Rows.Count, “A”).End(xlUp).Row
    x = 1
    y = 4
    For i = 1 To LstRw
    If Cells(i, 1).Value “” Then
    Cells(x, y).Value = Cells(i, 1).Value
    x = x + 1
    y = 3
    y = y + 1
      1. @David
        If you are copying code from here be careful as often the ” & – characters get messed up
        Simply retype those characters and see if that helps
        1. David is right, this code is not working because the conditional “” is missing, must be
        2. @Chandoo,
          Please take care of the “NOT EQUAL” opearator (as you, already, did for the “Minus” and “Inverted commas” signs).
          Thanks.
          1. Unfortunately, the not equal signs can’t be turned off as this will open up a security vulnerability in the blog. I will see if there are alternatives.
          2. Testing using instead of the original sign.
            This can be a “workaround” but I’m skeptic if random visitors will know about it.
  3. Sub TransposeVBA()
    Dim j, i
    j = 1
    While j < 87
    i = i + 1
    With Cells(j, 1).CurrentRegion
    Sheets("answer").Cells(i, 1).Resize(, .Rows.Count) = Application.Transpose(.Cells)
    j = j + .Rows.Count + 1
    Wend
  4. here is my short with the formula
    Define names:
    d = transpose!$A$1:$A$87
    la = IFERROR(LOOKUP(ROW(d),ROW(d)*1/(d=””)),1)
    Final formula is
    IFERROR(LOOKUP(“Ω”,IF((ROW(d)=SMALL(IF(FREQUENCY(la,ROW(d))>0,ROW(d)),ROW($A1))+COLUMN(A$1)-1+ISNUMBER((ROW(A1)-1)^0)),IF(la=SMALL(IF(FREQUENCY(la,ROW(d))>0,ROW(d)),ROW($A1)),d))),””)
    Change the ? with an Omega sign
    To be array entered..drag it down and across..
    I am looking to shorten it.
  5. Edited:
    Define names:
    Final formula is
    IFERROR(LOOKUP("Ω",IF((ROW(d)=SMALL(IF(FREQUENCY(la,ROW(d))>0,ROW(d)),ROW($A1))+COLUMN(A$1)-1+ISNUMBER((ROW(A1)-1)^0)),IF(la=SMALL(IF(FREQUENCY(la,ROW(d))>0,ROW(d)),ROW($A1)),d))),"")
    1. Edited Again:
      Everything remains the same, but reduced the final one by 12 Chars..
      Define Names:
      Final Formula: Drag and copy across
      IFERROR(LOOKUP(“?”,IF((ROW(d)=SMALL(IF(FREQUENCY(la,ROW(d))>0,ROW(d)),ROW($A1))+COLUMN(A$1)-1+(ROW($A1)>1)),IF(la=SMALL(IF(FREQUENCY(la,ROW(d))>0,ROW(d)),ROW($A1)),d))),””)
  6. @r1c1 – there seems to be some issue..I can see the entire formula and secondly, I dont see the characters that i used in this formula…suppose it is lookup OMEGA not a Question Mark
  7. Option Explicit
    Public Sub Answer()
    ‘* Transpose Data
    Dim wsd As Worksheet, wsa As Worksheet
    Dim last_row As Long, row_nbr As Long, row_dest As Long
    Dim col_nbr As Integer
    Dim rng_copy As Range
    Set wsd = ThisWorkbook.Worksheets(“transpose”) ‘ Set Data worksheet
    Set wsa = ThisWorkbook.Worksheets(“answer”) ‘ Set Answer worksheet
    wsa.Cells.ClearContents
    row_nbr = 1
    row_dest = 1
    With wsd
    last_row = .Cells(Rows.Count, “A”).End(xlUp).Row ‘ Last data row
    Do While row_nbr <= last_row
    If Len(wsd.Cells(row_nbr, "A")) = 0 Then GoTo continue ' Blank Row
    Set rng_copy = Range(.Cells(row_nbr, "A"), .Cells(row_nbr, "A").End(xlDown))
    rng_copy.Copy
    wsa.Cells(row_dest, "A").PasteSpecial Paste:=xlValues, Transpose:=True ' Copy with Traspose
    row_nbr = row_nbr + rng_copy.Rows.Count + 1 ' + 1 to include net blank row
    row_dest = row_dest + 1
    continue:
    Loop
  8. In my first post col_nbr is not used in code; could be used instead of “A” column in case you wanted to write your results in other column in sheet “answer”
  9. I don’t know, but I was third to post my answer – and it didn’t appear here. Post once again:
    Sub TransposeVBA()
    Dim i, j
    j = 1
    While j < 87
    i = i + 1
    Wend
  10. tem infinitas formas de se fazer
    uma possibilidade mais dinâmica
    tem como melhorar e muito
    Sub segue_()
    ‘origem——————-
    li = 1
    ci = “A”
    lf = Cells(Rows.Count, ci).End(xlUp).Row
    rngo = Range(ci & li, ci & lf).Value2
    ‘destino————————–
    li = 1
    ci = “c”
    cf = “g”
    c1 = Cells(1, ci).Column
    c2 = Cells(1, cf).Column
    c = c1
    For l = 1 To UBound(rngo, 1)
    Cells(li, c).Value2 = rngo(l, 1)
    If c >= c2 Then c = c1: li = li + 1 Else c = c + 1
  11. me desculpe,
    como eu uso tradutor online não percebi que tinha ir para outra ABA
    correção:
    Sub segue_()
    ‘origem——————-
    li = 1
    ci = “A”
    aba = “transpose”
    lf = Sheets(aba).Cells(Rows.Count, ci).End(xlUp).Row
    rngo = Sheets(aba).Range(ci & li, ci & lf).Value2
    ‘destino————————–
    li = 1
    ci = “f”
    cf = “g”
    aba = “answer”
    c = c1
    Sheets(aba).Cells(li, c).Value2 = rngo(l, 1)
  12. I don’t like my first suggested code – so here is a better one:
    Sub Transpose_Vertical_Fields_into_Horizontal_Records()
    Set SH = Sheets(“Transpose”)
    LR = SH.Cells(Rows.Count, 1).End(xlUp).Row
    STRT_R = 1: R = 1
    While STRT_R < LR
    END_R = SH.Cells(STRT_R, 1).End(xlDown).Row
    SH.Cells(STRT_R, 1).Resize(END_R – STRT_R + 1).Copy
    ActiveSheet.Cells(R, 3).PasteSpecial Paste:=xlPasteAll, Transpose:=True
    STRT_R = END_R + 2
    R = R + 1
    Wend
    1. And this one is a general code which can be launched from any Sheet or Module:
      Set SH1 = Sheets(“Transpose”)
      Set SH2 = Sheets(“Answer”)
      LR = SH1.Cells(Rows.Count, 1).End(xlUp).Row
      STRT_R = 1
      R = 1
      While STRT_R < LR
      END_R = SH1.Cells(STRT_R, 1).End(xlDown).Row
      SH1.Cells(STRT_R, 1).Resize(END_R – STRT_R + 1).Copy
      SH2.Cells(R, 1).PasteSpecial Paste:=xlPasteAll, Transpose:=True
      STRT_R = END_R + 2
      R = R + 1
      Wend
      1. @David Rahman,
        All “Minus” signs copied from this forum page into the VBA Editor – produce an error.
        Same story with the “Inverted commas”.
        It is about time for Chandoo to “fix” those “bugs”
        1. Thanks for the suggestion Micky. It seems this was an easy change. So I have implemented it. Checking.
          debug.print “hello world, these minus signs should work fine — – –“
  13. Sub www()
    Dim a, i&, r&, c&
    a = Range(Cells(1, 1), Cells(Rows.Count, 1).End(xlUp)).Value
    r = 1
    ReDim b(1 To 8, 1 To r)
    For i = 1 To UBound(a)
    If a(i, 1) = “” Then
    r = r + 1
    c = 0
    ReDim Preserve b(1 To 8, 1 To r)
    c = c + 1
    b(c, r) = a(i, 1)
    Cells(1, 3).Resize(UBound(b, 2), UBound(b, 1)) = Application.Transpose(b)
  14. peço desculpa
    com tradutor online é difícil definir exatamente o que é para fazer
    por favor apegue minhas primeiras tentativas
    ainda não consegui definir um separador por que não achei a logica de endereçamento
    Sub segue_()
    ‘origem——————-
    li = 1
    ci = “A”
    aba = “transpose”
    ‘destino————————–
    li = 1
    ci = “c”
    aba = “answer”
    li = li – 1
    c = c1
    l2 = 1
    If rngo(l, 1) = “ZYZ LTD” Then li = li + 1
    If rngo(l, 1) = “” Then li = li + 1: c = c1 Else c = c + 1
    1. Hello
      I’m from Brazil and I’m using an online translator
      It happened some strange things here,
      I tested in various browsers’ untranslated ”
      the type of quotes “” is changed
      l-1 -> minus sign is changed
      code did not work
      it is only me that is?
      Other than that I found the challenge a bit confusing
      I like to play making macros, displacement and dynamically reallocate data using arrays
      so I posted a solution
      the beginning I thought it was because of translation
      but the solutions presented do not believe I was the confused single
      ATT
  15. Sub transpozycja()
    Dim RNG As Range
    Dim wb As Workbook
    Dim ws As Worksheet
    Dim RNG_AREAS As Areas
    Dim arrAREAS()
    Set wb = ThisWorkbook
    Set ws1 = wb.Worksheets(“transpose”)
    Set ws2 = wb.Worksheets(“answer”)
    Set RNG = ws1.Range(ws1.Range(“A2”), ws1.Range(“A1048576”).End(xlUp))
    Set RNG_AREAS = RNG.SpecialCells(xlCellTypeConstants).Areas
    For i = 1 To RNG_AREAS.Count
    arrAREAS = WorksheetFunction.Transpose(RNG_AREAS(i))
    ws2.Range(ws2.Cells(i, 1), ws2.Cells(i, UBound(arrAREAS))) = arrAREAS
    1. @Kuba,
      Nice peace of code.
      Just change the “A2” into “A1” and you are set.
      I would change that command into:
      Set RNG = ws1.Range(“A1”, ws1.Cells(Rows.Count, 1).End(xlUp))
      Thanks.
    2. Nice code but it is not working properly. It is mixing up with other address and repetting one address again and again.
  16. Surely not the best or nicest VBA code but it works!
    Sub Transpose_to_Rows()
    Dim a As Range
    Dim b As Long
    Dim c As Integer
    Dim d As Long
    Dim e As Integer
    Dim cell As Range
    Set a = Range(“A:A”)
    b = 1
    Range(“A1”).Select
    For Each cell In a
    c = Selection.Rows.Count
    Selection.Copy
    Range(“C” & b).Select
    Selection.PasteSpecial Paste:=xlPasteAll, Operation:=xlNone, SkipBlanks:= _
    False, Transpose:=True
    If b > 1 Then
    e = 1
    e = 0
    d = d + c + e
    b = b + 1
    Range(“A” & 2 + d).Select
    If ActiveCell.Value = “” Then
    MsgBox “Done!”
    Columns(“C:J”).EntireColumn.AutoFit
    Exit Sub
    Next cell
    Have a nice day!
    Baudouin
    1. I found some problem with your following code:
      1. I made this code yesterday in a few minutes before going to bed and tested it with satisfaction.
        I did test it again this morning and found no problem on my system (W8.1 and Excel 2013 French versions).
        Then I did some changes to the code to make it “better”:
        Add a clean of the paste range.
        Add some comments.
        Did cancel the “Select/Selection” part of the PasteSpecial part.
        Change the paste range (C:J –> K:R).
        I did not cancel the “Select/Selection” part of the Copy part because c value would not be correct (would stay at value = 1).
        I did add some extra values to the column A for testing and everything was OK.
        Here is the actual code:
        Dim a As Range ‘Is the range of datas.
        Dim b As Long ‘Counter to determine the row number where the transposed datas are pasted.
        Dim c As Integer ‘Counter of copied cells used to determine d as total counter.
        Dim d As Long ‘ Counter to find the next line where the following copy starts.
        Dim e As Integer ‘Value to be added to c to make d after first paste. Because there is no blank row before row 1.
        Dim cell As Range
        b = 1
        Columns(“K:R”).ClearContents
        Range(“A1”).Select
        For Each cell In a
        Selection.Copy
        Range(“K” & b).PasteSpecial Paste:=xlPasteAll, Operation:=xlNone, SkipBlanks:= _
        If b > 1 Then
        e = 1
        e = 0
        d = d + c + e
        b = b + 1
        MsgBox “Done!”
        Columns(“K:R”).EntireColumn.AutoFit
        Exit Sub
        Next cell
        Have a nice day!
        Baudouin (from Belgium)
        1. And here is the adapted version to use with the “answer” sheet.
          ‘Application.ScreenUpdating = False
          Dim cell As Range
          Set a = Sheets(“transpose”).Range(“A:A”)
          b = 1
          Sheets(“answer”).Columns(“A:H”).ClearContents
          Sheets(“transpose”).Select
          Range(“A1”).Select
          For Each cell In a
          Selection.Copy
          Sheets(“answer”).Range(“A” & b).PasteSpecial Paste:=xlPasteAll, Operation:=xlNone, SkipBlanks:= _
          If b > 1 Then
          e = 1
          e = 0
          d = d + c + e
          b = b + 1
          Sheets(“transpose”).Range(“A” & 2 + d).Select
          MsgBox “Done!”
          Sheets(“answer”).Select
          Columns(“A:H”).EntireColumn.AutoFit
          Range(“J1”).Select ‘To avoid datas being selected unnecessary.
          Exit Sub
          Next cell
          Baudouin
  17. My code in Power Query M is the longest so far 🙂 Apart from the function part it can be done using PowerQ User Interface.
    1. define range in Excel: =transpose!$A$1:$A$88 (one blank row at the end!)
    2. create a blank query in Power Query and paste:
    let
    // import data and add column to identify data records
    Source = Excel.CurrentWorkbook(){[Name=”myRange”]}[Content],
    AddInd = Table.AddIndexColumn(Source, “Index”, 0, 1),
    IsNull = Table.AddColumn(AddInd, “Custom”, each if [Column1] = null then [Index] else null),
    FilledUp = Table.FillUp(IsNull,{“Custom”}),
    RenameCol = Table.RenameColumns(FilledUp,{{“Custom”, “ColGroup”}}),
    //small function to transpose each data record separetly
    fTransform = (group as number) =>
    let
    Filter1 = Table.SelectRows(RenameCol, each ([ColGroup] = group)),
    Filter2 = Table.SelectRows(Filter1, each ([Column1] null)),
    RemoveIndexCol = Table.RemoveColumns(Filter2,{“ColGroup”,”Index”}),
    Transpose = Table.Transpose(RemoveIndexCol)
    in
    Transpose ,
    // trigger function for each record
    DistinctGroups = Table.Distinct(RenameCol, {“ColGroup”}),
    TriggerFunction = Table.AddColumn(DistinctGroups, “Custom”, each fTransform([ColGroup])),
    RemovedOtherColumns = Table.SelectColumns(TriggerFunction,{“Custom”}),
    ExpandedCustom = Table.ExpandTableColumn(RemovedOtherColumns, “Custom”, {“Column1”, “Column2”, “Column3”, “Column4”, “Column5”, “Column6”, “Column7”, “Column8”}, {“C1”, “C2”, “C3”, “C4”, “C5”, “C6”, “C7”, “C8”})
    in
    ExpandedCustom
  18. Sub transpose_Address()
    Dim sAddress(100, 8) As String
    Dim iAddressCnt(100) As Integer
    Dim i As Integer
    Dim j As Integer
    Dim iAddCnt As Integer
    ‘Read col A to store the address untill two continual blank lines
    i = 1
    iAddCnt = 1
    j = 1
    Do While Cells(i, 1) “” Or Cells(i + 1, 1) “”
    sAddress(iAddCnt, j) = Cells(i, 1)
    i = i + 1
    j = j + 1
    If Cells(i, 1) = “” Then
    iAddressCnt(iAddCnt) = j
    i = i + 1
    j = 1
    iAddCnt = iAddCnt + 1
    Loop
    ‘ Print the Values from C to H
    iAddCnt = iAddCnt – 1
    For i = 1 To iAddCnt
    For j = 1 To iAddressCnt(i)
    Cells(i, j + 2) = sAddress(i, j)
  19. Beaten to the punch for the first Power Query solution 🙁
    My approach is a little different.
    I replace the blank rows with CR/LFs and then convert the list into a comma delimited list, add in a header and throw back through Power Query’s CSV parser.
    let
    Table1 = let
    Source = Excel.CurrentWorkbook(){[Name=”Table1″]}[Content],
    #”Changed Type” = Table.TransformColumnTypes(Source,{{“Column1″, type text}}),
    #”Replaced Value0″ = Table.ReplaceValue(#”Changed Type”,null,”#(cr)#(lf)”,Replacer.ReplaceValue,{“Column1″}),
    #”Replaced Value” = Table.InsertRows(#”Replaced Value0″, 0, { [Column1 = “Address1”],
    [Column1 = “Address2”], [Column1 = “Address3”], [Column1 = “Address4”], [Column1 = “Address5”], [Column1 = “Address6”],[Column1 = “#(cr)#(lf)”] }),
    Transform.ToCSVString = (table) =>
    Text.RemoveRange(List.Accumulate(Table.ToList(#”Replaced Value”), “”, (a,b) => if b=”””#(cr)#(lf)””” then a&”#(cr)#(lf)” else if Text.End(a,2) = “#(cr)#(lf)” then a & b else a & “,” &b), 0, 1)
    in
    Transform.ToCSVString (#”Replaced Value”),
    #”Imported Text” = Lines.FromText(Table1),
    ConvertBackToBinary = Lines.ToBinary(#”Imported Text”),
    #”Imported CSV” = Csv.Document(ConvertBackToBinary,[Delimiter=”,”,Encoding=1252]),
    #”Removed Duplicates” = Table.Distinct(#”Imported CSV”, {“Column1″}),
    #”Filtered Rows” = Table.SelectRows(#”Removed Duplicates”, each ([Column1] “Address1″))
    in
    #”Filtered Rows”
  20. I have used macro recorder. It work fine but need to fine tune only:
    ‘ TransposeAddress Macro
    ‘ Copy and pase text into a column
    ‘ Keyboard Shortcut: Ctrl+Shift+T
    Range(“C15:G20”).Select
    Selection.Copy
    Range(“C2”).Select
    ActiveSheet.Paste
    Columns(“G:G”).EntireColumn.AutoFit
    Range(“A1:A5”).Select
    Selection.Copy
    Range(“C2”).Select
    ActiveSheet.Paste
    Range(“A7:A10”).Select
    Selection.Copy
    Range(“D2”).Select
    ActiveSheet.Paste
    Range(“A12:A14”).Select
    Selection.Copy
    Range(“E2”).Select
    ActiveSheet.Paste
    Range(“A16:A21”).Select
    Selection.Copy
    Range(“F2”).Select
    ActiveSheet.Paste
    Range(“A23:A27”).Select
    Selection.Copy
    Range(“G2”).Select
    ActiveSheet.Paste
  21. Sub Mysolution()
    myrow = 1
    mycol = 1
    Range(“A1”).Select
    While (ActiveCell.Value “”) Or (ActiveCell.Offset(1, 0).Value “”)
    mycol = 1
    myrow = myrow + 1
    Worksheets(“Answer”).Cells(myrow, mycol) = ActiveCell.Value
    mycol = mycol + 1
    ActiveCell.Offset(1, 0).Activate
    Wend
  22. Try code below
    Sub Test()
    Dim Rng As Range, a As Range, RngDestination As Range
    Dim aStartTime
    Dim bErrorHandle As Boolean
    ‘~~> Start Timer
    aStartTime = Now()
    ‘~~> Speeding Up VBA Code
    Call SpeedOn
    On Error GoTo errHandler
    bErrorHandle = False
    ‘~~> Variables
    ‘~~> Erase old Data
    Columns(“C:AD”).Delete
    ‘~~> Tranpose item in Areas
    Set RngDestination = Range(“C” & Rows.Count).End(xlUp).Offset(1, 0)
    RngDestination.Resize(1, a.Rows.Count) = Application.Transpose(a)
    Next a
    ‘~~> Tidy Up
    Range(“C1:Z1”).Delete Shift:=xlUp
    Columns(“C:N”).EntireColumn.AutoFit
    errHandler:
    If Err.Number 0 Then
    MsgBox Err.Number & “: ” & Err.Description, vbCritical, “Whoops, something went wrong…”
    MsgBox “Time taken: ” & Format(Now() – aStartTime, “h:mm:ss”) & vbNewLine & ” You’re good to go!”, vbInformation, “Excellent”
    ‘~~> Remove items from memory
    Set Rng = Nothing
    Set RngDestination = Nothing
    Call SpeedOff
    Private Sub SpeedOn()
    ‘Speeding Up VBA Code
    With Application
    .ScreenUpdating = False ‘Prevent screen flickering
    .Calculation = xlCalculationManual ‘Preventing calculation
    .DisplayAlerts = False ‘Turn OFF alerts
    .EnableEvents = False ‘Prevent All Events
    Private Sub SpeedOff()
    With Application
    .ScreenUpdating = True ‘Prevent screen flickering
    .Calculation = xlAutomatic ‘Preventing calculation
    .DisplayAlerts = True ‘Turn OFF alerts
    .EnableEvents = True ‘Prevent All Events
    1. Hi Bhavik,
      Really liked your full options sub. Rare to see this altogether.
      Can you please explain start timer? I didn’t see it stop? I want to know how to use it, once I ll get up to speed.
  23. Sub oranus()
    i = 0
    j = 1
    k = 3
    Do
    i = i + 1
    a = Cells(i, 1)
    If a = “” Then
    If Cells(i – 1, 1) “” Then
    j = j + 1
    k = 3
    Exit Do
    Cells(j, k) = a
    k = k + 1
    Loop
  24. Sub transpose()
    Sheets(“transpose”).Range(“A1”).Select
    ActiveSheet.Next.Select
    ActiveSheet.Range(“A1”).Select
    ActiveSheet.Previous.Select
    Do Until IsEmpty(ActiveCell.Value)
    Selection.Copy
    False, transpose:=True
    ActiveCell.Offset(1, 0).Range(“A1”).Select
    Selection.End(xlDown).Select
    ActiveCell.Offset(2, 0).Range(“A1”).Select
    Loop
  25. Hello
    code did not work
    ATT
  26. Here is my transpose function for this.
    Sub transepose()
    Dim counter As Integer
    Dim LastRow As Long
    With ActiveSheet
    LastRow = .Cells(.Rows.Count, “A”).End(xlUp).Row
    MsgBox LastRow
    Dim rr As Integer, cc As Integer
    rr = 1
    cc = 10
    For counter = 1 To LastRow
    If Not IsEmpty(Cells(counter, 1)) Then
    Cells(rr, cc).Value = Cells(counter, 1).Value
    cc = cc + 1
    rr = rr + 1
    cc = 10
    Next counter
  27. Hi Guys,
    Here is my solution:
    Sub CopyTranspose()
    Dim Rng As Range, i As Long, j As Long
    Set Rng = Worksheets(“answer”).UsedRange
    ‘Worksheets(“answer”).Columns(“C:H”).Clear ‘might not need here
    j = 1
    For i = 1 To Rng.Rows.Count + 1
    If Rng.Cells(i, 1) = “” Then
    Range(Cells(i – 1, 1), Cells(i – 1, 1).End(xlUp)).Copy
    Cells(j, 3).PasteSpecial Paste:=xlPasteAll, Operation:=xlNone, SkipBlanks:=False, Transpose:=True
    j = j + 1
    ‘Worksheets(“answer”).Columns(“C:H”).Columns.AutoFit ‘might not need here
  28. Sub transposedata()
    Dim ans As Worksheet
    Dim trs As Worksheet
    Dim x As Long
    Dim finalrow As Long
    ‘ sets the answer sheet
    Set ans = Sheets(“answer”)
    ‘set the transpose sheet
    Set trs = Sheets(“transpose”)
    ‘counts the final row
    finalrow = Cells(Rows.Count, 1).End(xlUp).Row
    ‘intialize the first row as 1
    x = 1
    trs.Activate
    Range(“A1”).Select
    ‘loop until x variable becomes equal to the lastrow
    Do Until x = finalrow
    trs.Activate
    Range(Selection, Selection.End(xlDown)).Copy
    x = ActiveCell.Row
    ActiveCell.Offset(2, 0).Select
    ans.Activate
    Loop
    ans.Cells.Columns.AutoFit
  29. My code is longer but is working perfectly based on the question. But this code has some limitation. So I need to figure out how to make it small and dynamic. But the code is working perfectly. You can test following code:
    ‘ Auther: David Rahman
    Selection.Copy
    Range(“C2”).Select
    ActiveSheet.Paste
    Selection.Copy
    Range(“D2”).Select
    ActiveSheet.Paste
    Selection.Copy
    Range(“E2”).Select
    ActiveSheet.Paste
    Selection.Copy
    Range(“F2”).Select
    ActiveSheet.Paste
    Selection.Copy
    Range(“G2”).Select
    ActiveSheet.Paste
    Range(“A29:A32”).Select
    Selection.Copy
    Range(“C9”).Select
    ActiveSheet.Paste
    Range(“A34:A36”).Select
    Selection.Copy
    Range(“D9”).Select
    ActiveSheet.Paste
    Range(“A38:A43”).Select
    Selection.Copy
    Range(“E9”).Select
    ActiveSheet.Paste
    Range(“A45:A49”).Select
    Selection.Copy
    Range(“F9”).Select
    ActiveSheet.Paste
    Range(“A51:A54”).Select
    Selection.Copy
    Range(“G9”).Select
    ActiveSheet.Paste
    Range(“A56:A58”).Select
    Selection.Copy
    Range(“C16”).Select
    ActiveSheet.Paste
    Range(“A60:A65”).Select
    Selection.Copy
    Range(“D16”).Select
    ActiveSheet.Paste
    Range(“A67:A71”).Select
    Selection.Copy
    Range(“E16”).Select
    ActiveSheet.Paste
  30. Hi Chandoo,
    here is my answer with formula only :
    http://www.cjoint.com/c/FArxwYkXLfd
    explanations …
    in B1 :
    =IF(A1=””,ROW(),””)
    in C1 :
    =SMALL(B:B,ROW())
    copy them down
    in D1 :
    =IF(C1″”,T(OFFSET($A$1,(COLUMN()-4),0,1,1)),””)
    copy to the right 8 times
    in D2 :
    =IF(C2″”,T(OFFSET($A$1,$C1+(COLUMN()-4),0,1,1)),””)
    copy to the right
    then Down
    1. Oupssss….
      in D1 :
      =IF(C1?”,T(OFFSET($A$1,(COLUMN()-4),0,1,1)),””)
      in D2 :
      =IF(C2?”,T(OFFSET($A$1,$C1+(COLUMN()-4),0,1,1)),””)
      copy to the right
      then Down
      1. Re-Oupssss….
        Grrrrr….
        signe different not accepted ???
        in D1 :
        =IF(C1{different}””,T(OFFSET($A$1,(COLUMN()-4),0,1,1)),””)
        in D2 :
        =IF(C2{different}””,T(OFFSET($A$1,$C1+(COLUMN()-4),0,1,1)),””)
        copy to the right
        then Down
  31. Hi Chandoo
    My try :
    Set RangeToUse = Range(“A:A”).SpecialCells(xlCellTypeConstants, 23)
    NextRow = 1
    If RangeToUse.Areas.Count = 1 Then
    MsgBox RangeToUse.Address
    For Each SingleArea In RangeToUse.Areas
    NextCol = 3
    For Each Cell In SingleArea
    Cells(NextRow, NextCol).Value = Cell.Value
    NextCol = NextCol + 1
    NextRow = NextRow + 1
  32. Sorry forgot to take out some test code. Updated code as below
    NextRow = 1
    NextCol = 3
  33. Hey Chandoo
    Sub test()
    Dim i, j, k As Integer
    i = 1: j = 3: k = 1
    Do While Sheets(“transpose”).Cells(i + 1, 1).Value “” Or Sheets(“transpose”).Cells(i + 2, 1).Value “”
    Sheets(“transpose”).Cells(k, j) = Sheets(“transpose”).Cells(i, 1).Value
    If Sheets(“transpose”).Cells(i, 1).Value = “” Then k = 1: j = j + 1: i = i + 1 Else k = k + 1: i = i + 1
    Loop
    Vignesh
  34. Hi
    Please check this code.
    Sub test()
    i = 1: j = 3: k = 1
    Loop
  35. its very easy, don’t go in lengthy way
    just via using array formula
    for transposing range A1:A5
    click first on cell C7
    now from cell C7, select range C7:G7 go right side via using shift and arrow key (we selected only 5 cells cos Range A1:A5 consist 5 counts)
    now put function in =TRANSPOSE(A1:A5) in cell C7 with selecting all 5 cells as C7:G7
    now don’t enter, u have to do Ctrl+Shift+Enter
    now u got the result as per need
  36. I know this is not very good; but as my first trial in writing VBA, a working code seems more important. 🙂
    Sub TransposeBlocksinCol()
    Dim i As Integer
    Dim myRange As Range
    Dim pRange As Range
    Dim n As Integer
    Columns(“A:A”).Select
    Selection.SpecialCells(xlCellTypeConstants, 23).Select
    n = Selection.Areas.Count
    For i = 1 To n
    Set myRange = Selection.Areas(i)
    myRange.Copy
    Cells(i, 3).Select
    1. @MF,
      For a first trial in writing VBA it look very nice.
      As good practice try to eliminate the use of SELECT (despite the use of ScreenUpdating pair)
      1. Hi Michael, Thanks for your advice!! I will keep that in mind, and more importantly, try.
        Indeed, trying and practicing is the best way to learn. 🙂
        1. Here’s revised code without Select 🙂 Also allow user to select where to start pasting.
          Sub TransposeBlocksinCol1()
          ‘revised without using select
          Dim i As Long
          Dim n As Long
          Dim start As Range
          Set start = Application.InputBox(“Input the starting cell to paste”, “Paste Location:”, Default:=ActiveCell.Address, Type:=8)
          If TypeName(start) “Range” Then Exit Sub
          Set start = start.Range(“A1”)
          n = Columns(“A:A”).SpecialCells(xlCellTypeConstants, 23).Areas.Count
          For i = 1 To n
          Columns(“A:A”).SpecialCells(xlCellTypeConstants, 23).Select
          myRange.Copy
          start.PasteSpecial Paste:=xlPasteAll, Operation:=xlNone, SkipBlanks:= _
          Set start = start.Offset(1, 0)
          1. @MF,
            You left one SELECT behind.
            Try instead:
            Set myRange = Columns(“A:A”).SpecialCells(xlCellTypeConstants, 23).Areas(i)
            myRange.Copy
          2. Thanks Michael! I tried your suggestion and it is better.
            Thanks again for pointing me to the right direction!
            Cheers, 🙂
  37. Sub TranRow2Col()
    Dim LastRow As Long, PstCol As Integer
    With ActiveSheet
    GrpStrt = ActiveCell.Row
    Grp1End = ActiveCell.Row
    Selection.End(xlUp).Select
    PstCol = 1
    For GrpEnd = Grp1End To LastRow
    Selection.Copy
    Range(“C” & PstCol).Select
    Range(“A” & GrpEnd).Select
    GrpEnd = ActiveCell.Row
    PstCol = PstCol + 1
  38. This is actually possible in under 20 lines of code.
    The trick is not to copy or paste anything and make use of a loop through the variable with a secondary loop updating the table on the rights, using the blanks to tell the code when to start a new line and move to the next address. Then use something along the lines of
    If linevariable+1=””
    GoTo: End Sub
    To stop the code when it meets multiple blanks (the end of the table).
  39. Like the approaches of MF and SunnyKow with Selection.SpecialCells(xlCellTypeConstants, 23).Select approach !
    I see several participants not declaring vars… probably just because of the code extracts… or is var declaration no longer ‘good practice’?
  40. Sub TransposeColToRow()
    Dim LastRow As Integer
    Dim j As Integer
    Dim SaveJ As Integer
    Dim Myvalue As String
    Dim CurrValue
    LastRow = Range(“A65536”).End(xlUp).Row
    k = 0
    l = 0
    For j = 1 To LastRow
    If Range(“A” & j).Value “” Then
    Range(“D1”).Offset(k, l).Value = Range(“A” & j).Value
    l = l + 1
    l = 0
    k = k + 1
    Next j
  41. Sub TransposeColToRow()
    Dim j As Integer
    Dim CurrValue
    k = 0
    l = 0
    l = l + 1
    l = 0
    k = k + 1
    Next j
  42. I made a formula and inserted a blank range in (1 :1)
    Named range Tlist A1:a89
    Named formula makearray iferror (–(Tlist) +row(Tlist),” “)
    Named formula lbound small(makearray, row())+1
    Named formula unbound small(makearray, row()+1)-1
    Formula in g1
    Iferror (index(Tlist,lbound+columns($g:g)-1+((lbound+columns($g:g)-1)>ubound)*rows(Tlist)),” “)
    The iferror +second formula part ((lbound+….) is only to make neat empty cells, where the formula goes beyond the current range in Tlist. Somebody has a better solution for this?
    Have a good day.
  43. Sub transposeAddress()
    Dim iRow As Integer
    Dim iLastRow As Integer
    Dim iOutputRow As Integer
    Dim sString As String
    Dim iCol As Integer
    Dim sht As Worksheet
    Set sht = Sheets(“Answer”)
    iLastRow = sht.Cells(sht.Rows.Count, “A”).End(xlUp).Row
    iOutputRow = 1
    iCol = 3
    iRow = 1
    Do Until iRow = iLastRow + 1
    If sht.Cells(iRow, 1) = “” Then
    iCol = 3
    iOutputRow = iOutputRow + 1
    GoTo nxtRow
    sString = sht.Cells(iRow, 1)
    sht.Cells(iOutputRow, iCol) = sString
    iCol = iCol + 1
    nxtRow:
    iRow = iRow + 1
    Loop
    sht.Cells.Columns.AutoFit
  44. Sub Transpose()
    Dim start
    Dim lrow
    Range(“A1”).Select
    ActiveCell.SpecialCells(xlLastCell).Select
    lrow = ActiveCell.Row
    Range(“A1”).Select
    start = ActiveCell.Row
    While start <= lrow + 1
    Selection.Copy
    Sheets("answer").Select
    Range("A1").Select
    If (ActiveCell.Value “”) Then
    If (ActiveCell.Offset(1, 0).Value “”) Then
    ActiveCell.Select
    Range(“A” & start).Select
    Wend
  45. VBA code with simple do until loop to copy and transpose address blocks
    Sub transposer()
    Dim x, nrows As Integer
    x = 0
    nrows = 0
    startpastecell = Range(“c1”).Address()
    Range(“A1”).Select
    Do While ActiveCell.Value “”
    startcell = ActiveCell.Address()
    nrows = ActiveCell.CurrentRegion.Rows.Count
    Range(ActiveCell, ActiveCell.Offset(nrows – 1, 0)).Copy
    Range(startpastecell).Offset(x, 0).Select
    x = x + 1
    Range(startcell).Offset(nrows + 1, 0).Select
    Loop
    Range(“A1”).Select
  46. This is my first attempt at a Chandoo challenge! Code isn’t pretty, it’s very simple, but it gets the job done. I have tested it and it all worked. I hope it works for you, too.
    Sub transpose()
    ‘written by Laura Pienkowski
    ‘for Chandoo challenge to transpose data
    ‘variables for sheet name
    datasheet = “transpose”
    answersheet = “answer”
    Sheets(datasheet).Select ‘make sure on the data sheet
    ‘row variables on data sheet
    rlast = ActiveSheet.UsedRange.SpecialCells(xlCellTypeLastCell).Row ‘get last row number
    rdatastart = 1
    ranswer = 1 ‘starting point on answer sheet
    For r = rdatastart To rlast + 1
    rstart = r ‘starting point then loop to find end
    Do Until Cells(r, 1) = “”
    r = r + 1
    Loop
    Range(Cells(rstart, 1), Cells(r – 1, 1)).Copy ‘copy range
    ‘go to answer sheet and paste values transpose
    Sheets(answersheet).Select
    Selection.PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks:=False, transpose:=True
    Cells(ActiveCell.Row + 1, 1).Select ‘go to next open line
    Sheets(datasheet).Select ‘back to data sheet
    ‘find the start of the next section
    Cells(r, 1).Select
    Do Until Cells(r, 1) “”
    If Cells(r + 1, 1) = “” And Cells(r + 2, 1) = “” Then ‘if 2 rows are empty, that’s the end
    Exit For
    r = r + 1 ‘otherwise, increment the row
    Loop
    r = r – 1 ‘back up one so that when the next r code hits, it increments correctly
    Next r
  47. I really find strange that all the post above was for VBA (99%) and none of the them posted any workaround using power query. Hence I thought to give it a try.
    Initially I have used excel formulas and then fully power query. Even the initial steps could be done in Power Query but I am not yet fully aware of it. Someone can really help me with that.
    Step 1: I copied the data to new sheet in Column A2. Gave column heading as “Data”.
    Step 2: In Cell D2 I entered formula
    =–ISTEXT(Table1[@Data])
    And copied for entire table
    Step 3: In Cell E1 entered “0”
    Step 4: Entered following formula
    =IF(D2=1,D2+E1,D2)
    And copied to entire table.
    Step 5: I copied the result I got in step 4 as second column under column B and named it as “Count”.
    Step 6: Converted the column A (Data) and Column B (Count) into table. The imported into Power Query.
    All further steps were done in power query. Above steps could be done in power query but I am not yet aware about it.
    Following is script of Power Query:
    let
    #”Changed Type” = Table.TransformColumnTypes(Source,{{“Data”, type text}, {“Count”, Int64.Type}}),
    #”Replaced Value” = Table.ReplaceValue(#”Changed Type”,null,”Break”,Replacer.ReplaceValue,{“Data”}),
    #”Added Index” = Table.AddIndexColumn(#”Replaced Value”, “Index”, 1, 1),
    #”Inserted Subtraction” = Table.AddColumn(#”Added Index”, “Subtract”, each [Index] – [Count], type number),
    #”Removed Columns” = Table.RemoveColumns(#”Inserted Subtraction”,{“Index”}),
    #”Pivoted Column” = Table.Pivot(Table.TransformColumnTypes(#”Removed Columns”, {{“Count”, type text}}, “en-US”), List.Distinct(Table.TransformColumnTypes(#”Removed Columns”, {{“Count”, type text}}, “en-US”)[Count]), “Count”, “Data”),
    #”Removed Columns1″ = Table.RemoveColumns(#”Pivoted Column”,{“Subtract”, “0”}),
    #”Replaced Value1″ = Table.ReplaceValue(#”Removed Columns1″,null,””,Replacer.ReplaceValue,{“4”, “5”, “6”})
    in
    #”Replaced Value1″
  48. here is the VBA code:
    Sub Set_Report()
    Dim lastRow As Long, I As Long
    Dim RowNum As Long, ColNum As Long
    RowNum = 1
    ColNum = 3
    lastRow = Cells(Rows.Count, 1).End(xlUp).Row
    For I = 1 To lastRow
    Cells(RowNum, ColNum) = Cells(I, 1)
    If IsEmpty(Cells(I, 1)) Then
    ColNum = 3
    RowNum = RowNum + 1
    ColNum = ColNum + 1
    Next I
  49. Really easy with power query. Really only 10 lines of code.
    Set named range “myRange” as “=transpose!$A$1:$A$87″
    let
    Add_Initial_Index = Table.AddIndexColumn(Source, “Index”, 1, 1),
    Specify_tmp_Record_Nbr = Table.AddColumn(Add_Initial_Index, “tmp_Record_Nbr”, each if [Index]=1 then 1 else if [Column1] = null then [Index]+1 else null),
    Fill_Down_Record_Nbr = Table.FillDown(Specify_tmp_Record_Nbr,{“tmp_Record_Nbr”}),
    Assign_Line_Nbr = Table.AddColumn(Fill_Down_Record_Nbr, “Line_Nbr”, each “Line_” & Text.From([Index]-[tmp_Record_Nbr]+1)),
    Remove_Nulls = Table.SelectRows(Assign_Line_Nbr, each ([Column1] null)),
    Remove_Initial_Index = Table.RemoveColumns(Remove_Nulls,{“Index”}),
    Pivot_Lines = Table.Pivot(Table.TransformColumnTypes(Remove_Initial_Index, {{“Line_Nbr”, type text}}, “en-US”), List.Distinct(Table.TransformColumnTypes(Remove_Initial_Index, {{“Line_Nbr”, type text}}, “en-US”)[Line_Nbr]), “Line_Nbr”, “Column1”),
    Remove_tmp_Record_Nbr = Table.RemoveColumns(Pivot_Lines,{“tmp_Record_Nbr”}),
    Remove_Duplicates = Table.Distinct(Remove_tmp_Record_Nbr, {“Line_1”, “Line_2”, “Line_3”, “Line_4”, “Line_5”, “Line_6”})
    in
    Remove_Duplicates
    1. Nice method in power query. All steps could be done with ribbon commands and no need to edit M language. Very easy to learn compared to VBA.
      one of the line code should be
      this was missing.
  50. I didn’t see any formula solutions so I’d thought I’d provide one. Only requires one small change: insert a cell in col. A so the first address starts in A2.
    Put this in C1 (array-entered) and fill across and down:
    =IFERROR(INDEX(INDIRECT(“A”&SMALL(IF(ISBLANK(rng),ROW(rng)),ROW())+1&”:A”&SMALL(IF(ISBLANK(rng),ROW(rng)),ROW()+1)-1),COLUMN()-2),””)
    where “rng” is defined as A1 to the first black cell after the last cell with text (in this case, it would be A89).
    1. =IFERROR(INDEX(INDIRECT(“A”&SMALL(IF(ISBLANK(rng),ROW(rng)),ROW())+1&”:A”&SMALL(IF(ISBLANK(rng),ROW(rng)),ROW()+1)-1),COLUMN()-2),””)
  51. =IFERROR(INDEX(INDIRECT(“A”&SMALL(IF(ISBLANK(rng),ROW(rng)),ROW())+1&”:A”&SMALL(IF(ISBLANK(rng),ROW(rng)),ROW()+1)-1),COLUMN()-2),””)
  52. My try using formulas:
    1) Insert a blank row at A1
    2) Cell C2 enter the formula =IF(A1=””,A2,””)
    3) Cell D2 enter the formula =IF(AND(C20,$A3″”,C2″”),IF(OFFSET($A2,COLUMN()-3,0)=0,””,OFFSET($A2,COLUMN()-3,0)),””)
    4) Copy the formula in cell D2 copy to as many columns as needed
    5) You can then copy the entire row formula downwards
    1. Hmm my formula got changed when submitted. Try again
          1. @ Hui
            Thank you.
            =IF(AND(C2 NE 0,$A3 NE “”,C2 NE “”),IF(OFFSET($A2,COLUMN()-3,0)=0,””,OFFSET($A2,COLUMN()-3,0)),””)
  53. Sub Arrange()
    Dim i As Integer
    Dim j As Integer
    Dim StrtClm As Integer
    Dim StrtRow As Integer
    StrtClm = 1 ‘Column to Start
    StrtRow = 1 ‘Row to Start
    For i = 1 To 87
    StrtRow = StrtRow + 1
    StrtClm = 1
    i = i + 1
    Sheets(“answer”).Cells(StrtRow, StrtClm).Value = Sheets(“transpose”).Cells(i, 1).Value
    StrtClm = StrtClm + 1
    1. Very good one.
      Just replace the “87” value by the following: Sheets(1).Range(“A1048576”).End(xlUp).Row
      It will then work for the whole column of data.
      Have a nice day,
      Baudouin
      1. @Baudouin,
        You suggested command will fail if used in “Excel 2003” and earlier.
        It is good practice to use the following – which suits all versions of “Excel”
        LastRowR = Sheets(“transpose”).Cells(Rows.Count, 1).End(xlUp).Row
        Micky
  54. I do not consider that is meaningful answer here
    it is better to respond in a forum
    where the code will serve to someone and where others will point out your mistakes and successes so that you can improve
    up here had a choice of the best code
    the staff would worry more, to leave the code cleaner and faster
  55. Hi I
    I rewrote my formula for better readability. The formula is using indirect, what I wanted to avoid first . I use named formulas because they take on array formulas. I use index because that formula also takes array formula. Didn’t find much documentation on how this really works. Anyone?
    I inserted a row in (1:1).
    Named range Tlist a1:a89
    Named formula makearray iferror (–(Tlist) +row(Tlist), “”)
    Named formula lbound small (makearray, row() +1
    Named formula ubound small(makearray, row() +1)-1
    in g1 IFERROR (INDEX (INDIRECT (“A” & LBOUND&”A:”&UBOUND), COLUMNS($ G:G)), “”)
    I cannot see more than 46 comments on your Web page, which are the comments already there before my first post. Any solution? Thanks.
    1. Index is an array formula by nature…
      read the below links
      Hi – This is a good read though..
      http://excelxor.com/2014/09/05/index-returning-an-array-of-values/#more-98
      http://excelxor.com/2014/09/01/index-an-alternative-to-array-cse-formulas/#more-13
      If you wish to see the single formula solution without any changes to the base data…see the solution no 5.
      I am looking to improvise the solution in terms of length as soon as I get enough time to think over it again..
      1. Hi Asheesh, I agree with your index(index formula. I think this is the best formula solution..
        I visited the excelxor blog and wow I felt like my son when he was freshly admitted at Poudlard, 10 years ago. My understanding of index offset choose and array formula is much better now. Thanks again.
        However when your array formula is put in a named formula., It doesn’t need CSE again.
        IFERROR (INDEX (index (Tlist, lbound.) :index(Tlist, ubound). Column(a1)),””)
        On the excelxor blog
        Sum(indirect(adress({1,2,3,4,5},1) CSE gives the a1 value.
        When this whole formula is in a named formula, no need for CSE and the formula yields the sum of sum(a1:a5).this is equivalent to Sum(N(indirect(adress({1,2,3,4,5},1))) no CSE.
        Sum(named formula with INDIRECT……) CSE or not gives the a1value.
        Sum(N(named formula with INDIRECT……) CSE or not gives the a1value.
        I didn’t t see any “good ” explanation for this, named formulas are not promoted.
        Have a good day.
  56. Hi,
    Please see Power Query codes below.
    let
    DataSet1 = Table.AddIndexColumn(#”Changed Type”, “Index”, 0, 1),
    #”Filtered Rows” = Table.SelectRows(DataSet1, each ([Column1] = null)),
    #”Added Index1″ = Table.AddIndexColumn(#”Filtered Rows”, “Index.1″, 1, 1),
    DataSet2 = Table.RenameColumns(#”Added Index1”,{{“Index.1”, “Row”}}),
    #”Merged Queries” = Table.NestedJoin(DataSet1,{“Index”},DataSet2,{“Index”},”NewColumn”,JoinKind.LeftOuter),
    #”Expanded NewColumn” = Table.ExpandTableColumn(#”Merged Queries”, “NewColumn”, {“Row”}, {“NewColumn.Row”}),
    #”Sorted Rows” = Table.Sort(#”Expanded NewColumn”,{{“Index”, Order.Ascending}}),
    #”Filled Up” = Table.FillDown(#”Sorted Rows”,{“NewColumn.Row”}),
    #”Added Custom1″ = Table.AddColumn(#”Filled Up”, “Row”, each if [NewColumn.Row]=null then 0 else [NewColumn.Row]),
    #”Filtered Rows1″ = Table.SelectRows(#”Added Custom1″, each ([Column1] null)),
    #”Removed Columns” = Table.RemoveColumns(#”Filtered Rows1″,{“Index”, “NewColumn.Row”}),
    #”Added Index” = Table.AddIndexColumn(#”Removed Columns”, “Index”, 0, 1),
    DataSet3 = Table.SelectRows(#”Added Index”, each ([Column1] null)),
    #”Grouped Rows” = Table.Group(DataSet3, {“Row”}, {{“Count”, each Table.RowCount(_), type number}}),
    #”Added Custom” = Table.AddColumn(#”Grouped Rows”, “Custom”, each {1..[Count]}),
    #”Expanded NewColumn1″ = Table.ExpandListColumn(#”Added Custom”, “Custom”),
    DataSet4 = Table.AddIndexColumn(#”Expanded NewColumn1″, “Index”, 0, 1),
    #”Merged Queries1″ = Table.NestedJoin(DataSet3,{“Index”},DataSet4,{“Index”},”NewColumn”,JoinKind.LeftOuter),
    #”Expanded NewColumn2″ = Table.ExpandTableColumn(#”Merged Queries1″, “NewColumn”, {“Custom”}, {“Column”}),
    #”Removed Columns1″ = Table.RemoveColumns(#”Expanded NewColumn2″,{“Index”}),
    #”Pivoted Column” = Table.Pivot(Table.TransformColumnTypes(#”Removed Columns1″, {{“Column”, type text}}, “zh-CN”), List.Distinct(Table.TransformColumnTypes(#”Removed Columns1″, {{“Column”, type text}}, “zh-CN”)[Column]), “Column”, “Column1″),
    #”Removed Columns2″ = Table.RemoveColumns(#”Pivoted Column”,{“Row”})
    in
    #”Removed Columns2″
  57. Sub TransposeEntries()
    Dim firstCell As Range
    Dim lastCell As Range
    Dim rowCount As Integer
    Dim entryNum As Integer
    Dim wsA As Worksheet
    Dim wsB As Worksheet
    Set wsA = Worksheets(“transpose”)
    Set wsB = Worksheets(“answer”)
    Set firstCell = wsA.Range(“A1”)
    Set lastCell = wsA.Range(“A1”)
    entryNum = 0
    While Not IsEmpty(firstCell)
    rowCount = Range(firstCell, firstCell.End(xlDown)).Rows.Count
    Set lastCell = firstCell.Offset(rowCount – 1)
    wsB.Range(“A1”).Offset(entryNum, 0).Resize(ColumnSize:=rowCount) = WorksheetFunction.Transpose(wsA.Range(firstCell.Address, lastCell.Address))
    entryNum = entryNum + 1
    Set firstCell = firstCell.Offset(rowCount + 1, 0)
    Wend
  58. Sub Address_Transpose()
    nrow = Cells(Rows.Count, 1).End(xlUp).Row
    k = 1
    k1 = 2
    For i = 1 To nrow
    x = Range(“a” & i).Value
    k1 = k1 + 1
    If x “” Then
    Cells(k, k1) = x
    k = Cells(Rows.Count, 3).End(xlUp).Row + 1
    k1 = 2
  59. Hi there, try this, it should work.
    [code]
    Sub TransposeData()
    Dim getRange As Range: Dim cRow As Integer: Dim pCell As Range
    Sheet2.Cells.ClearContents
    Set getRange = Sheet1.Range(“A1:A” & Sheet1.Range(“A1048576”).End(xlUp).Row)
    Sheet1.Activate: cRow = 1
    For Each pCell In getRange
    If pCell.Value “” And pCell.Offset(1, 0).Value Empty Then
    ‘ CountA returns column count uptil 52 columns (AZ)
    Sheet2.Cells(cRow, WorksheetFunction.CountA(Sheet2.Range(“A” & cRow & “:AZ” & cRow)) + 1).Value = pCell.Value
    ElseIf pCell.Offset(1, 0).Value = Empty Then
    Sheet2.Cells(cRow, WorksheetFunction.CountA(Sheet2.Rows(cRow & “:” & cRow)) + 1).Value = pCell.Value
    cRow = cRow + 1
    Next pCell
    [/code]
  60. I read some of the other solutions out there, but I really think this is the most elegant vba solution out there, one simple for loop with an if statement embedded in it. Prove me wrong please.
    Sub Transpose_Address_Data()
    Dim myLR As Long
    Dim x As Long
    Dim y As Integer
    Dim z As Integer
    ‘Used to transpose data in single column format to linear format.
    y = 3
    z = 1
    myLR = Cells(Rows.Count, “A”).End(xlUp).Row
    For x = 1 To myLR
    If Cells(x, 1) = “” Then
    z = z + 1
    y = 3
    Cells(z, y) = Cells(x, 1)
    y = y + 1
    Next x
    1. Option Explicit
      Dim myLR As Long
      Dim x As Long
      Dim y As Integer
      Dim z As Integer
      y = 3
      z = 1
      For x = 1 To myLR
      z = z + 1
      y = 3
      y = y + 1
      Next x
      Edit: Formatting…
  61. I’ll agree with Jason Morin in saying there haven’t been “many” formula solutions. What I think makes this one different is that it’s non-volatile (no INDIRECT or OFFSET), uses no helper cells/columns, doesn’t require alteration of the data table, and doesn’t leverage defined names to make itself “shorter.”
    It does require execution as a CSE array and should be entered into a horizontal range of 8 cells (based on Chandoo’s rule that each address could have up to 8 lines). Then it can simply be copied down to obtain subsequent addresses.
    =IFERROR(TRANSPOSE(INDEX($A$1:$A$87,IFERROR(SMALL(IFERROR(ROW($A$1:$A$87)/($A$1:$A$87=””),””),ROW(A1)-1),0)+1):INDEX($A$1:$A$87,SMALL(IFERROR(ROW($A$1:$A$87)/($A$1:$A$87=””),””),ROW(A1))-1)),””)
    1. Hi David,
      Awsome Idea…
      Changed your formula from a multiple cell array to single cell array..way shorter than my solution..
      IFERROR(INDEX(INDEX($A$1:$A$87,IFERROR(SMALL(IFERROR(ROW($A$1:$A$87)/($A$1:$A$87=””),””),ROW(A1)-1),0)+1):INDEX($A$1:$A$87,SMALL(IFERROR(ROW($A$1:$A$87)/($A$1:$A$87=””),””),ROW(A1))-1),COLUMN(A$1)),””)
  62. Sub Transpose()
    Row = 1
    col = 1
    For Each cell In Rng.Cells
    If Not cell = “” Then
    Worksheets(“Answer”).Cells(Row, col) = cell.Value
    col = col + 1
    col = 1
    Row = Row + 1
  63. Option Explicit
    Sub SortAddresses()
    ‘robrussell.net
    Dim aFinalRow As Integer
    Dim i, k, l As Integer
    k = 1
    l = 3
    aFinalRow = Cells(Rows.Count, 1).End(xlUp).Row
    For i = 1 To aFinalRow
    If Cells(i, 1) “” Then
    Cells(k, l) = Cells(i, 1)
    l = l + 1
    l = 3
    k = k + 1
  64. Sub Chando_Transpose()
    Dim FirstRowData, LastRowData, FirstColumnData, FirstRowTransposed, FirstColumnTranspose, TransposedColumnIncrement As Integer
    FirstRowData = 1
    FirstColumnData = 1
    LastRowData = 87
    FirstRowTransposed = 1
    FirstColumnTranspose = 3
    TransposedColumnIncrement = 0
    For FirstRowData = FirstRowData To LastRowData
    If Cells(FirstRowData, FirstColumnData).Value = vbNullString Then
    FirstRowTransposed = FirstRowTransposed + 1
    GoTo Skip
    Cells(FirstRowTransposed, FirstColumnTranspose + TransposedColumnIncrement).Value = Cells(FirstRowData, 1).Value
    TransposedColumnIncrement = TransposedColumnIncrement + 1
    Skip:
  65. Sub Reloc()
    b = 3
    a = 1
    For i = 1 To 87
    If IsEmpty(Cells(i, 1).Value) = False Then
    Cells(a, b).Value = Cells(i, 1).Value
    a = a
    b = b + 1
    a = a + 1
    b = 3
  66. I have done with Macro and it works fine.
    Sub Transpose_AddressDr()
    ‘Author: David Rahman
    ‘ Transpose_AddressDr Macro
    Selection.Copy
    Range(“C1:J1”).Select
    Selection.Copy
    Range(“C2:J2”).Select
    Selection.Copy
    Range(“C3:J3”).Select
    Selection.Copy
    Range(“C4:J4”).Select
    Selection.Copy
    Range(“C5:J5”).Select
    Selection.Copy
    Range(“C6:J6”).Select
    Selection.Copy
    Range(“C7:J7”).Select
    Selection.Copy
    Range(“C8:J8”).Select
    Selection.Copy
    Range(“C9:J9”).Select
    Selection.Copy
    Range(“C10:J10”).Select
    Selection.Copy
    Range(“C11:J11”).Select
    Selection.Copy
    Range(“C12:J12”).Select
    Selection.Copy
    Range(“C13:J13”).Select
    Selection.Copy
    Range(“C14:J14”).Select
    Selection.Copy
    Range(“C15:J15”).Select
    Selection.Copy
    Range(“C16:J16”).Select
    Selection.Copy
    Range(“C17:J17”).Select
    Selection.Copy
    Range(“C18:J18”).Select
    Selection.Copy
    Range(“C19:J19”).Select
  67. @David Rahman,
    if your suggested MAcro should be considered as a Joke – may I say it is far from being funny…
    1. Michael Avid@ I am a not specialist like you. Although you said it is funny but it is working fine. Thanks for your remark.
  68. @David Rahman,
    It has nothing to do with being or not being a specialist.
    What will be the length of your Macro if the amount of the address-groups would have been 10,000 ?
    Your suggestion is similar to adding the values of a range of cells by adding one to the other – something like:
    =A1+A2+A3+A4+A5……….+A10000
    Instead of:
    =SUM(A1:A10000)
  69. =IFERROR(IF(ROW()=1,INDEX(INDIRECT(“a1:a”&MATCH(TRUE,IF($A$1:$A$87=””,TRUE,$A$1:$A$87),0)-1),COLUMN(A1),0),INDEX(INDIRECT(“a”&INDEX(ROW($A$1:$A$87),SMALL(IF($A$1:$A$87=””,ROW($A$1:$A$87),2000),ROW($A1)-1),0)+1&”:a”&INDEX(ROW($A$1:$A$87),SMALL(IF($A$1:$A$87=””,ROW($A$1:$A$87),2000),ROW($A2)-1),0)-1),COLUMN(A1),0)),””)
    USE With CSE
    Nitin Verma
    1. Sub project()
      Dim i As Integer
      Dim j As Integer
      Sheet1.Range(Cells(1, 1), Cells(Sheet1.Range(“a1”).End(xlDown).Row, 1)).Copy
      Sheet1.Range(“c” & Sheet1.Range(“c” & Rows.Count).End(xlUp).Row).PasteSpecial xlPasteValues, , , True
      For i = 1 To Sheet1.Range(“a” & Rows.Count).End(xlUp).Row
      If VBA.IsEmpty(Sheet1.Range(“a” & i).Value) = False And VBA.IsEmpty(Sheet1.Range(“a” & i + 1).Value) = True Then
      ‘Sheet1.Range(“a” & (i + 2) & “a” & Sheet1.Range(“a” & (i + 2)).End(xlDown).Row).Copy
      Sheet1.Range(Cells(i + 2, 1), Cells(Sheet1.Range(“a” & (i + 2)).End(xlDown).Row, 1)).Copy
      Sheet1.Range(“c” & Sheet1.Range(“c” & Rows.Count).End(xlUp).Row + 1).PasteSpecial xlPasteValues, , , True
      Sheet1.Range(“c1”).CurrentRegion.Columns.AutoFit
      Through VBA CODE
      Nitin verma
  70. Option Explicit
    Sub transpose()
    Dim i As Range, srng As Range, acell As Range, j As Long, k As Long, m As Long, lstrow As Long
    lstrow = ThisWorkbook.Worksheets(“Sheet1”).Range(“A” & ThisWorkbook.Worksheets(“Sheet1”).Rows.Count).End(xlUp).Row
    Set srng = ThisWorkbook.Worksheets(“Sheet1”).Range(“A1”, “A” & lstrow + 1)
    m = 1
    k = 1
    For Each acell In srng
    If IsEmpty(acell.Value) = True Or IsNull(acell.Value) = True Then
    Range(Split(acell.Address, “$”)(1) & m).Activate
    For j = k To Split(acell.Address, “$”)(2) – 1
    ActiveCell.Offset(0, 1).Value = Range(Split(acell.Address, “$”)(1) & j).Value
    ActiveCell.Offset(0, 1).Activate
    Next j
    k = Split(acell.Address, “$”)(2) + 1
    Set i = acell
    m = m + 1
    Next acell
  71. Sub AddressTransposer()
    Dim CurrCell As String
    Dim LstRow As Integer
    Dim i As Integer
    LstRow = Cells(Rows.Count, “A”).End(xlUp).Offset(1, 0).Row
    Range(“A1”).Select
    i = 1
    Do Until ActiveCell.Row = LstRow
    If Not IsEmpty(ActiveCell) Then
    CurrCell = ActiveCell.Address
    Selection.Copy
    Range(“C” & i).Select
    Do Until IsEmpty(ActiveCell)
    ActiveCell.Offset(0, 1).Select
    Loop
    ActiveSheet.Paste
    Range(CurrCell).Offset(1, 0).Select
    i = i + 1
    Loop
    Cells.EntireColumn.AutoFit
    Range(“A1”).Select
    MsgBox “Macro Complete”, vbInformation, “”
  72. Please review this:
    Public Sub Convert()
    Dim v, hc, hr As Integer
    Dim src, dst As Range ‘src as source, dst as destination
    Set src = Worksheets(“answer”).Range(“A1”)
    Set dst = Worksheets(“answer”).Range(“C1”)
    v = 0 ‘row in vertical table
    hc = 0 ‘column in horizontal table
    hr = 0 ‘row in horizontal table
    Do While Not (IsEmpty(src.Offset(v, 0)) And IsEmpty(src.Offset(v + 1, 0)))
    Do
    dst.Offset(hr, hc).Value = src.Offset(v, 0).Value
    hc = hc + 1
    v = v + 1
    Loop Until IsEmpty(src.Offset(v, 0))
    hc = 0
    hr = hr + 1
    v = v + 1
    Loop
    External loop checks logical value at the beginning in order to avoid empty source (i.e., when source vertical table has no address to transpose).
  73. Sub TransposeAddress()
    Application.ScreenUpdating = fales
    Dim cc As Range
    lastrowA = Cells(Rows.Count, 1).End(xlUp).Row
    Range(“A1”).Select
    For i = 1 To lastrowA
    On Error GoTo Err1:
    Set cc = ActiveCell
    lastrow = Cells(Rows.Count, 3).End(xlUp).Row
    Range(ActiveCell, ActiveCell.End(xlDown)).Copy
    Range(“c” & lastrow).Select
    If ActiveCell = “” Then
    ActiveCell.Select
    cc.Select
    ActiveCell.End(xlDown).Offset(2, 0).Select
    Err1:
    Columns(“C:H”).EntireColumn.AutoFit
  74. Nothing beats M
    let
    Source = Excel.CurrentWorkbook(){[Name=”D”]}[Content],
    mAddIndex = Table.AddIndexColumn(Source, “Index”, 0, 1),
    mAddCustom = Table.AddColumn(mAddIndex, “Custom”, each if [Column1] = null then [Index] else null),
    mFillUp = Table.FillUp(mAddCustom,{“Custom”}),
    mRemCols = Table.RemoveColumns(mFillUp,{“Index”}),
    mGrpRows = Table.Group(mRemCols, {“Custom”}, {{“Table”, each Table.Transpose(Table.SelectColumns(_,{“Column1”})), type table}}),
    mRemCols1 = Table.RemoveColumns(mGrpRows,{“Custom”}),
    mExpandTbl = Table.ExpandTableColumn(mRemCols1, “Table”, {“Column1”, “Column2”, “Column3”, “Column4”, “Column5”, “Column6”}, {“Column1”, “Column2”, “Column3”, “Column4”, “Column5”, “Column6”}),
    mRemDups = Table.Distinct(mExpandTbl)
    in
    mRemDups
  75. You can also build a solution independent of the rows in a block
    let
    Source = Excel.CurrentWorkbook(){[Name=”Table2″]}[Content],
    mBlk = Table.FromRecords({[Column1= null]}),
    mAppendQ = Table.Combine({Source,mBlk}),
    mAddIndex = Table.AddIndexColumn(mAppendQ, “Index”, 0, 1),
    mNoOfCols = List.Max(mGrpRows[Custom])- List.Min(List.MaxN(mGrpRows[Custom],2))-1,
    mCols = {1..mNoOfCols},
    mCovToTbl = Table.FromList(mCols,Splitter.SplitByNothing()),
    mChgTyp = Table.TransformColumnTypes(mCovToTbl,{{“Column1”, type text}}),
    mAddColNms = Table.AddColumn(mChgTyp, “Custom”, each “Column”&[Column1]),
    mRemOthCols = Table.SelectColumns(mAddColNms,{“Custom”}),
    mTblToLst = Table.ToList(mRemOthCols),
    mExpandTbl = Table.ExpandTableColumn(mRemCols1, “Table”, mTblToLst, mTblToLst),
    in
    mRemDups
  76. I got mNoOfCols wrong …..here is the revised “M” Code
    let
    mNoOfCols = Table.Max(Table.AddColumn(mGrpRows, “ColCount”, each Table.ColumnCount([Table])),”ColCount”),
    mCols = {1..mNoOfCols[ColCount]-1},
    in
    mRemDups
  77. sub transpose()
    Dim r, i, j, c As Integer
    r = 6
    For i = 1 To 87
    c = 1
    For j = 1 To 10
    If Worksheets(“transpose”).Cells(i, 1) = “” Then
    Exit For
    If Worksheets(“transpose”).Cells(j, 1) “” Then
    Worksheets(“answer”).Cells(r, c) = Worksheets(“transpose”).Cells(i, 1)
    c = c + 1
    i = i + 1
    Next j
    r = r + 1
    Next I
    end sub
  78. I used totally different approach and most popular for the data transformation and works really well.
    I just took me 5 minutes to design a versatile solution for this problem without knowing VBA.
    The code for the powerquery is listed here:
    let
    Source = Excel.Workbook(File.Contents(“C:\Users\ketan\Downloads\transpose-address-data-problem.xlsm”), null, true),
    transpose_Sheet = Source{[Item=”transpose”,Kind=”Sheet”]}[Data],
    #”Changed Type” = Table.TransformColumnTypes(transpose_Sheet,{{“Column1”, type text}, {“Column2”, type any}, {“Column3”, type text}, {“Column4”, type text}, {“Column5”, type text}, {“Column6”, type text}, {“Column7”, type text}, {“Column8″, type any}}),
    #”Removed Other Columns” = Table.SelectColumns(#”Changed Type”,{“Column1″}),
    #”Kept First Rows” = Table.FirstN(#”Removed Other Columns”,5),
    #”Transposed Table” = Table.Transpose(#”Kept First Rows”),
    #”Appended Query” = Table.Combine({#”Transposed Table”,#”transpose (2)”}),
    #”Appended Query1″ = Table.Combine({#”Appended Query”,#”transpose (3)”}),
    #”Appended Query2″ = Table.Combine({#”Appended Query1″,#”transpose (4)”})
    in
    #”Appended Query2″
  79. Hi,
    it took a while, almost a oneliner.
    Tlist is a dynamic named range. Here a1:a88.
    Sub transposer()
    Dim rCell As Range
    Dim pasterange As Range
    Set pasterange =cells(1, 3)
    Dim Counter as long
    Counter = 0
    For Each rCell In [Tlist]. SpecialCells (xlCellTypeBlanks)
    Counter = Counter +1
    Pasterange (Counter). PasteSpecial transpose :=True _
    =rCell. Offset (1,0).CurrentRegion. Copy
    Next rCell
    End sub
    1. Hi Jan
      Really like your coding simple and effective.
      Just ran it and spotted the first address block A1:A5 is not transposed for some reason. All the rest are perfect. Checked I have range name of TList correct as A1:A88 and this is Ok. Have I missed something?
      Mike H
      1. Hi Mike , thanks for appreciating.
        Most likely : I inserted a blank row in a1 when trying the formula solution.
        And then forgot about it. If you too insert a blank row, the code will work fine.
        This gives me a good reason to turn the code around and use SpecialCells constants.
        Hope this helps.
        1. Jan
          Yes works fine with a blank row added within the Tlist Named Range.
          Look forward to your next version.
          Mike H
      2. Hi Mike , thanks for appreciating.
        Let me know if this doesn’t help.
        You can replace rCell .Offset(1,0) by rCell(2).
        Jan
  80. Hi,
    in yesterday’s code I forgot that you need to insert a blank range in a1. Remainder of my formula trials. Also you can replace rCell. Offset (1,0) by rCell (2).
    Today’s code tackles the blank range problem , so this will work whether the first row is empty or not.
    I kept the rCell variable for demonstration and comparison with yesterday. Although a variable name like singlearea might be more appropriate.
    Sub transposerarea()
    Dim rCell As Range
    Set pasterange =cells (1,3)
    Dim Counter as Long
    Counter =0
    For Each rCell In [Tlist]. SpecialCells (xlCellTypeConstants). Areas
    Counter=Counter +1
    Pasterange (Counter). PasteSpecial transpose :=True = rCell. Copy
    Next rCell
    End sub
    Have a good day.
        1. Unfortunately not.
          Only Hebrew, English & German.
          I commonly use: “Chapeau bas à vous” to express appreciation.
  81. @Jan Martens,
    Not bad for the Hebrew…
    The German sentence should be something like:
    “Wir erfüllen bei der nächsten Hausaufgaben”
  82. Sub Rearrange_Address()
    Dim rngFirst As Range
    Dim strLastCell As String
    Dim rngCell As Range
    Dim lngColumn As Long
    Dim lngRow As Long
    Dim rngTranspose As Range
    Dim lngLastRow As Long
    Dim lngLastColumn As Long
    lngLastColumn = Feuil1.UsedRange.Columns.Count
    lngLastRow = Feuil1.UsedRange.Rows.Count
    If lngLastColumn 1 Then
    Range(Cells(1, 2),Cells(lngLastRow,lngLastColumn)).ClearContents
    ThisWorkbook.Save
    strLastCell = Feuil1.UsedRange.Address
    Set rngFirst = Range(strLastCell)
    Set rngTranspose = Range(“C1”)
    lngRow = 0
    For Each rngCell In rngFirst
    If rngCell “” Then
    lngColumn = lngColumn + 1
    rngTranspose.Offset(lngRow, lngColumn – 1) = rngCell.Value
    lngRow = lngRow + 1
    lngColumn = 0
  83. Option Explicit
    Private Sub transpose()
    Dim wsFrom, wsTo As Worksheet
    Set wsFrom = Sheets(“transpose”)
    Set wsTo = Sheets(“answer”)
    j = 1
    k = 1
    For i = 1 To wsFrom.UsedRange.Rows.Count
    If IsEmpty(wsFrom.Range(“A” & i).Value) Then
    j = j + 1
    k = 1
    wsTo.Cells(j, k).Value = wsFrom.Range(“A” & i).Value
    k = k + 1
  84. Select cells A1:H16 on the ‘answer’ tab. Then paste in he below formula as an array using Shift Control Enter:
    =IFERROR(INDEX(OFFSET(transpose!$A$1,SMALL(IF(transpose!$A$1:$A$88=””,ROW($1:$88),IF(ROW($1:$88)=1,0,””)),ROW()),0,SMALL(IF(transpose!$A$1:$A$88=””,ROW($1:$88),IF(ROW($1:$88)=1,0,””)),ROW()+1)-SMALL(IF(transpose!$A$1:$A$88=””,ROW($1:$88),IF(ROW($1:$88)=1,0,””)),ROW())-1,1),COLUMN(),1),””)
  85. Since there definitely weren’t many formula solutions proposed/available in the days before Excel 365, I thought I’d offer a fresh take on this old post by bringing some of Excel’s newest functions to the scene.
    With a long enough list, this one could fall prey to the 32,767 character limit for TEXTJOIN (and perhaps TEXTSPLIT)…
    =LET(
    list,TRIMRANGE(transpose!A:A),
    tmp,TEXTJOIN(“#”,,IF(LEN(list)=0,”;”,list)),
    TEXTSPLIT(tmp,”#”,”;”,TRUE,,””)
    …whereas this one should be able to handle even those longer lists
    =LET(
    rw,SEQUENCE(ROWS(list)),
    null,FILTER(rw,LEN(list)=0),
    beg,VSTACK(1,null+1),
    end,VSTACK(null-1,ROWS(list)),
    out,DROP(REDUCE(“”,SEQUENCE(ROWS(beg)),LAMBDA(acc,k,
    VSTACK(acc,TRANSPOSE(INDEX(list,INDEX(beg,k,1)):INDEX(list,INDEX(end,k,1))))
    )),1),
    IFNA(out,””)
Leave a Reply
