VLOOKUP(), MATCH() and INDEX() – explained in plain English
Share
Facebook
Twitter
LinkedIn
VLOOKUP may not make you tall, rich and famous, but learning it can certainly give you wings. It makes you to connect two different tabular lists and saves a ton of time. In my opinion understanding VLOOKUP, INDEX and MATCH worksheet formulas can transform you from normal excel user to a data processing beast.
Today, lets understand how to use these formulas better.
What is the syntax for Match, Vlookup and INDEX?
Here is the syntax for these three very powerful functions in plain English:
What are vlookup () and match () ?
VLOOKUP and MATCH are your way of asking excel to find a needle in haystack. Imagine you have all your customer contact information in one sheet in the range A1:D5000 in the format phone number, name, city and date of birth. Now you need to find out which customer has the phone number “936-174-5910”. How do you do it?
You guessed it right, you use VLOOKUP and summon excel to do the search and return with customer name.
While VLOOKUP is used to fetch value a based on what you are looking for, MATCH is used to fetch the position of the value you are looking for.
See this illustration to understand :
difference-between-vlookup-match-excel-formulas
What does VLOOKUP really do?
Imagine you have a list of data like this:
Sample Data - VLOOKUP Excel Formula
Now, how do you answer the question – “How many sales did Jimmy make?
Yes, your guess is right. VLOOKUP is one of the formulas you can use to answer questions like this.
VLOOKUP searches a list for a value in left most column and returns corresponding value from adjacent columns.
So, in our case, we need VLOOKUP to search for Jimmy and return the amount of sales he made from column 3.
VLOOKUP Syntax & Examples:
The syntax of VLOOKUP is simple:
=VLOOKUP( this value, your data table, column number, optional is your table sorted?)
Here is an example to get you started:
VLOOKUP Excel Formula - Syntax and Examples
Learn more about VLOOKUP Formula with examples
Please check out this page for 10+ examples of VLOOKUP and how to use it to solve real world problems.
VLOOKUP Examples & Homework
I have made a small excel file detailing 4 VLOOKUP formula examples. The file also contains some home work so that you can practice this formula.
Download VLOOKUP Example Workbook
[NEW] XLOOKUP replaces VLOOKUP in Excel 365
If you are using Excel 365, you can use the new & improved XLOOKUP function. It offers a shorter & more versatile syntax for performing lookups.
For ex: the same lookup as above will be done with XLOOKUP like below:
=XLOOKUP(“Jimmy”, A2:A14, C2:C14) will lookup “Jimmy” in column A and return sales amount from Column C.
Click here to learn more about XLOOKUP.
So what is INDEX() then?
INDEX function is your way of telling excel to fetch a value from large range of values. Since MATCH() function can tell us where the data is found, you can then use INDEX() function to extract corresponding data from another column. In this case, we can use MATCH() to find out which row has net sales 1,799 and INDEX() to return the name of the person. Like this:
Find the position of 1,799 in sales: =MATCH(1799, $C$2:$C$14, 0)
The answer will be 8.
To find the 8th person in names list, we can use INDEX() function like this:
=INDEX($A$2:$A$14, 8)
The answer will be Jagjit.
Related: Learn more about INDEX Formula.
So how are INDEX() and MATCH() linked to each other?
Since MATCH returns the position of the item you are looking for in a list, you can then use this position in INDEX to fetch values surrounding the searched value.
So, we can combine both functions like this:
=INDEX($A$2:$A$14, MATCH(1799, $C$2:$C$14, 0))
This combination is called as INDEX+MATCH formulas.
Related: Using INDEX + MATCH functions & INDEX+MATCH Video
Finally
Remember, both VLOOKUP and MATCH throw a fail error of #N/A if the value you are looking for is not there. If you want to stop seeing the error, use IFERROR function.
Just use them with some dummy data, play around with arguments and see how you can say “oh yeah, I can do that in few minutes” to your boss next time.
VLOOKUP tutorial – video
Please watch this quick video tutorial to understand all these concepts and how to write VLOOKUP formulas easily.
INDEX MATCH Tutorial – Video
Want to Learn More Formulas? Get my VLOOKUP book
If you want to learn VLOOKUP and other Excel lookup functions, then consider getting my VLOOKUP book.
The VLOOKUP Book - Definitive guide to Excel lookup functions & tricks
Comprehensive and easy to understand
This is a book for everyone who uses Vlookup. Most of us think… Oh.. I already know the function. But this book will open your eyes to some brilliant techniques. – By Dr. Nitin Paranjape
Solid introduction to lookup functions
This books does a wonderful job of taking each of the lookup functions available in Excel, breaking them down to a simple, easy-to-understand level. – by Lucas Moraga
Get your copy
Read next…
Facebook
Twitter
LinkedIn
Learn & be awesome.
Welcome to Chandoo.org
Rebekah S
Reporting Analyst
Advanced Pivot Table tricks
14 Responses to “How to Add your Macros to QAT or Excel toolbars?”
  1. Ashfire says:
    We have only just got excel 2007 so this is helping me navigate my way through the differences cheers.
    For Macro's i always add a Command Button, rename it something obvious, change the colour of it and finally add the following to its View Code section.
    Application.Run "MAcro1"
    This way anyone opening the file knows what to do if i ever win the lottery and dont make it in 🙂
  2. Ron Murphy says:
    Good article. But I have this problem.
    1) Customized QAT with a macro. Macro name = MacroX
    2) Runs OK from original location (e.g. C:\TestLoaction1\TestFile.xls)
    3) Copy past file to new location (e.g. C:\TestLoaction2\TestFile.xls)
    Menu button now fails:
    Cannot run the macro "C:\TestLoaction1\TestFile.xls'!MacroX' The macro may not be available in this workbook...
    Of course the code is there, and macros are enabled.
    Could get it to work after deleting and recreating macro custom buttons. So have to re-assign macro to QAT button every time I move the file?
    If I put a form button on he worksheet and assign the macro to that, it's location independent.
    Any ideas?
  3. Hui... says:
    @Ron
    What you have said is correct
    Macros within a worksheet are stored within the worksheet and hence follow it.
    Macros referenced by a button in the QAT or elsewhere are locaed in a file and if that file is moved the linkages don't follow.
    The easiest way around this is to store all your macros in a location that doesn't move and is in fact reloaded everytime that Excel starts and that is called the Personal.xlsx/b file.
    These are refered to several time at Chandoo.org or have a read of
    http://www.rondebruin.nl/personal.htm
    or
    http://office.microsoft.com/en-us/excel-help/deploy-your-excel-macros-from-a-central-file-HA001087296.aspx
    • Col Delane says:
      In Excel 2003 and prior versions, a button added to the Toolbar maintained a DYNAMIC link to the file (e.g. Personal.xlsb) holding the assigned macro, such that if the file was relocated for any reason (by using Excel's native Save As command rather than just moving it via Windows Explorer), the link between the button and the file was updated.
      I expected the same to occur with Excel 2007+, but alas, Microsoft in their infinite wisdom have removed another feature useful to advanced users (just as they did by removing the ability to design your own buttons)!!
      So having just done some reorganisation of my files, I now have to remove and recreate every friggin macro button on my QAT (I have lots) - what a pain in the proverbial!!
  4. Ron Murphy says:
    Hi Hui,
    Thanks for the help, that's really useful.
    1) The macros I'm adding are for one specific Excel application, so I really wanted the macros to follow the file
    2) I didn't want to have to pass other files around too and have users installing those - either Personal.xlsx/b or as an Add-In.
    3) I realise now that the QAT additions will appear for other Excel workbooks in which I don't want the macros available.
    So, it looks like I need to keep it local, by using a button on the worksheet. Unless you can suggest any way of adding to menus just for a specific workbook.
    Thanks again for your help. Great site, so I'll be signing up for the emails.
    Ron
  5. cheryl says:
    I know I'm a little late jumping on this post, but wondering if anyone knows how to add a UDF to the QAT? I've saved my UDF in my personal workbook, but it does not show up in my list when I choose Macros when customizing my QAT. Suggestions? Thanks!!
    • Chandoo says:
      @Cheryl: UDFs cannot be accessed like Macros. You can use them from other macros or from worksheet cells as formulas...
      @David: If you save your macros file and then install it as an add-in then it will be always available for you.
  6. David says:
    The instructions work great when you are creating a new file, and it is still open. I find that I can't access macros after I've saved a file as an xlam and closed it. When I reopen the xlam, either by browsing to it, or by having it set to open as an addin using Excel Options, the macros are no longer available in the macros list when I go to edit the QAT. Any way around that?
  7. JimH says:
    I need to create a button that will run a macro. Once you click the button it needs to open up a browser asking you to select a report/file. Once you select the file, it will run the macro on the selected file and then save it as a new report with a name and the current date. I created the macro to sort/modify the report but I do not know how to do what I mentioned above. I hope this makes sense.
  8. NathanG says:
    I'm having trouble adding a macro to the QAT. I've done everything up to step 5 but my macro isn't showing up. What am I doing wrong?
  9. surfinette says:
    Thank you for the explanation. Very useful for a recent switcher from office 2003 to office 2010.
    My follow-up question is: in Excel (or ppt) 2010, can you customize the macro button that you put in the QAT?
    In office 2003, once you chose the custom button for your Macro, you could then edit pixel by pixel the said button.
    For instance, I've created 2 Macros in PPT that are converting all my slides to either English or French language, so I'd like one button to show EN and the other FR... that would be more meaningful that any of the possible "custom" office 2010 buttons
  10. Morton Wakeland says:
    I read all the post and one important aspect to the QAT was never mentioned. That is, you have a macro driven worksheet that you want to share with other. You have customized the QAT with two icons to run the macros (VBA programs in reality). However, when the others receive the workbook, the icons are no where to be found. It's my understanding those "customized buttons" have been saved to an outside file, Excel.qat. QUESTION: Could one simply attach that file to your email, along with the worksheet, and tell the recipients to copy that file to correct location on their computer - C:\Users\\AppData\Local\Microsoft\Office|\
    Would the customize macro buttons then appear in the worksheet and, more importantly, work? Thanks for your thoughtfulness and thanks for well written instructions Chandoo!
    MortW
Leave a Reply
