Excel concatenate() is seriously crippled, it can add 2 or more strings together, as long as they are supplied as separate parameters. This means, when you have a range of cells with text which you want to add up to create a large text, you need to write an ugly looking biggish concatenate() or use ‘&’ operator over and again.
I felt bored enough the other day to write a better concatenate(), one that can accept a range as input and output one text with all the contents of the input range. What more you can use this to delimit the input range with your own favorite character.
For example, if each of the 7 cells in a1:a7 have “a”, “b”, “c”, “d”, “e”, “f”, “g”, if you want to add all of them up using concatenate you would have to write concatenate(a1,a2,a3,a4,a5,a6,a7) which can be painful if you are planning to do this over a large range or something.
Instead, you can use concat(a1:a7) by installing the UDF (User defined function) I have written. Its nothing miraculous or anything, it just does the dirty job of going through the range for you. If you want to delimit the input range with a comma just use concat(a1:a7,",") to get the out of a,b,c,d,e,f,g Just download the concat() UDF excel add-in and double click on it to install it. If you are little weary of installing UDFs / Macros from third parties, copy past the below excel code in a new sheet’s VB editor and save the sheet as an excel addin (.xla extension)
Added on Aug 26, 2008: I have updated the code, copy it again if you have the old one
Function concat(useThis As Range, Optional delim As String) As String
' this function will concatenate a range of cells and return one string
' useful when you have a rather large range of cells that you need to add up
Dim retVal, dlm As String
retVal = ""
If delim = Null Then
dlm = ""
dlm = delim
For Each cell In useThis
if cstr(cell.value)<>"" and cstr(cell.value)<>" " then
retVal = retVal & cstr(cell.Value) & dlm
end if
If dlm <> "" Then
retVal = Left(retVal, Len(retVal) - Len(dlm))
concat = retVal
End Function
Did you find this useful? Are you looking for some other excel UDFs as well, drop a comment, I am a busy coffee drinker, but between the sips I can whip out ugly looking but functional vb code 😛
6 Responses to “Using Lookup Formulas with Excel Tables [Video]”
H1 !
this is my very first comment.
Can you use same technique with Excel 2003 lists ?
thanks 😀
Thanks, Chandoo! I like seeing the sneak peak of what's to come on Friday too 🙂
@Damian.. Welcome to chandoo.org. Thanks for the comments.
Yes, you can use the same with Excel 2003 lists too.
@Tom.. You have seen future and its awesome.. isnt it?
[…] Using Tables – Video 1, Video 2 […]
Hi, is there a vlookup formula for the second example (IDlist)? I used a similar formula to look up the ID for the person, but the reverse way (look up the person with the ID) comes up N/A.
