Specify row number to use for a formula
MadMark43
I have data for each person in rows.
I create a display or a formula using the values in one row. How do I now create the same display with a different row.
I
Example:
NameStart-DateMonthly Salary
Joe15-MAR-2018 11,522
Fran01-JAN-2021 720
Jane01-APR-1997 119,356
I create a display using data in Row a:
Row to use: A
startdate: March 15, 2018
Annual Salary: $138,264
Now I want to specify to use a different row to display
Row to use: C
startdate: April 1, 1995
Annual Salary: $1,432,272
How do I specify which row to use by simply entering the row value into a cell?
Mark
Next, When learning Excel ensure that you use the correct nomenclature/names for various objects
eg: Your question says:
Row to use: A
But you actually mean
I create a display using data in Row 2:
Row to use: 2
Rows are Horizontal and numbered 1 to 1,048,576
Columns are vertical and are labelled A to XFD
As you will have a Header Row, your data starts in Row 2, Not Row A
Finally I would use an Index match Formula
eg:
76549
or see the attached file:
Enjoy
  • Book1.xlsx
