Can a manual work which i do regularly be automated using excel macros or plugin type thing?
SONJOE JOSEPH
As You don't know what 'question' means ... seems that You don't know what 'original' neither mean.
Your sent 'original' ... something as below
The Original CSV-file look like above which has used with my SJ.xlsb
... or any other xlsb-files which I've made!
Can You see any difference?
Term 'backfill' ... yes ... I still remember that too ... especially, that You didn't want that!
I can also copy & paste below:
Hope now u understood and please update the necessary corrections.
... actually, I don't hope ...
Dear Vletm,
This csv file was from my another trading terminal which i'm not using now. The csv file format has changed ya in my new trading terminal and this was the file which i have uploaded you earlier named "NIFTY19APRFUT.csv Forget about the old format and focus about the new format and just make a new SJ file with the conditions mentioned in 99
Hope u understood.
Sonjoe
You use more and more terms, which You just don't understand!
Still, You cannot give answers ... You give and gave misinformation.
... hopeless ... whatever ... whoever u ?
Ps You should give needed correct information -- means -- others do not need to dig dig those from You.
Thank You my friend its working perfectly. Sorry for troubling you
