Hi all...I need some help...I am attaching a workbook that has 2 pages....on the "Schedules" page, you dble-click a cell in the columns shown and it will jump to the Data Sheet...you then select a dat item and it will copy into the cell on Schedules....everything seems to work fine, unless you scroll to part of the Data Sheet that isn't shown on your screen (eg: cell AY282)....if you scroll and then select an item, it throws an error ('424').....any ideas about why this is happening?
http://www.speedyshare.com/files/29866187/Misfire_sample.xls for the sample file....thank you
