zetaacosta
I have a couple of strange issues that I cannot get to the bottom of.
The first is that whenever the user opens the spreadsheet an error message is displayed advising that links cannot be updated. I have tried absolutely everything to get rid of this but to no avail. Any help on this would be appreciated.
The second is that my pivot tables are not picking up my dynamic range but this used to work (also if you type Data_Input in the range box in the top left, it picks the correct rows up). If the users adds some any details to the bottom of the data input page then refreshes the pivot it does not update, yet if you add the data before the last row then it adds them?
I have used Offset etc to calculate these ranges and as I say it used to work so I am unsure why it has gone wrong.
Sheet attached.
Thanks in advance.
Sheet attached.
Thanks in advance.
