only Copy range of cells using command button
sandane
Hi chandoo, i have created a excel macro that will copy a particular range of cells when clicking a button. its copying the selected whole area. but i m looking in that selected area, it has to copy only data not blank space. (Eg. in selected range of cells is ten rows and the data was only two rows. it has select only two rows not ten rows means not blank rows). Please help me out.
Sandane
Welcome to the Chandoo.org forums
Can you post your code please
Hi Sandane,
You call this in command button
First you need to put the range
like:
Sub copy()
Range("cell number").selection //this is the first cell of the data//
Range(Selection, ActiveCell.SpecialCells(xlLastCell)).Select
Selection.copy
I think it will help..
Here you go!
Sub Copy()
Range("A1").Select
Selection.Copy
