Interesting problem - Excel 2007 Offset formula set for range but returning valu
andrewbroadway
On the tab named "Dashboard" I am playing with the offset function to return a range of rows from the "Missed Time - AD Usage' tab.
=OFFSET('Missed Time - AD Usage'!$B$5,0,1,92,1)
That is the formula I am using. So I am starting at B5, moving 0 rows down, 1 column to the right, the height is 92 and I only want 1 column.
Yes instead of returning #VALUE, the formula actually gives me whats in cell C15.
I am so frustrated! What am I doing wrong?
Andrewbroadway
You rarely use offset by itself except to return a single cell
Normally offset is used to return a range and you need to do something with it
eg:
=Sum(OFFSET('Missed Time - AD Usage'!$B$5,0,1,92,1))
=Min(OFFSET('Missed Time - AD Usage'!$B$5,0,1,92,1))
etc
Then what do I use to return the range of cells?
I am trying to use Name's to point to a range of cells.
That range will then be used for the series in a chart.
Andrew
You can use your formula in a named range and then use the named range as an X or Y value in a series for a chart
These are entered using the Name Manager not into cells
Also check that there aren't any text values in the range
Thank Hui, I understand that. The problem I am having is my formula is returning a single value. Not a range. I have the formula setup correctly yes? What else could be the problem.
Andrew
Try creating the named range from scratch
Delete the old Named Range and create a new Named Range
Type in =Offset(and then use the mouse to select the starting cell
once that is correct finish the 0,1,92,1) part
That should do it for you
Andrew,
what hui means is this:
Your formula is right. Your application is a bit off. copy that formula from the cell and create a range with the name as "test" or something. "refers to" should be filled with your formula.
