Help with VBA CODE ERROR
Jet Fusion
Hi
Please can someone help, somewhere I've changed something now I keep getting an error code - Compile error - Sub or Function not defined
Sub AddNewWorksheet()
Const cstrTitle As String = "Add new worksheet"
Const cstrPrompt As String = "Give the name for the new worksheet." & vbCrLf & "Not allowed are the characters: : \ / ? * [ and ]"
Dim strInput As String
Dim strDefault As String: strDefault = ""
Dim strInputErrorMessage As String
Dim booValidatedOk As Boolean: booValidatedOk = False
    On Error GoTo HandleError
    Do
        strInput = InputBox(Prompt:=cstrPrompt, Title:=cstrTitle, Default:=strDefault)
        If Len(strInput) = 0 Then GoTo HandleExit
        GoSub ValidateInput
        If Not booValidatedOk Then
            If vbCancel = MsgBox(strInputErrorMessage & "Retry?", vbExclamation + vbOKCancel) Then GoTo HandleExit
    Loop While Not booValidatedOk
    Dim wb As Workbook: Set wb = ActiveWorkbook
    Dim shts As Sheets: Set shts = wb.Sheets
    Dim obj As Object
    Set obj = shts.Add(Before:=ActiveSheet, Count:=1, Type:=XlSheetType.xlWorksheet)
    obj.Name = strInput
HandleExit:
    Exit Sub
HandleError:
    MsgBox Err.Description
    Resume HandleExit
ValidateInput:
    If SheetExists(strSheetName:=strInput) Then
        strInputErrorMessage = "Sheet already exists. "
    ElseIf Not IsValidSheetName(strSheetName:=strInput) Then
        strInputErrorMessage = "Sheetname not allowed. "
        booValidatedOk = True
    Return
Thanks in advance
Jet
Hui
Staff member
The line
is looking for a function called SheetExists()
and also later it looks for IsValidSheetName()
So add the following code after the end of the existing Sub
Public Function SheetExists(strSheetName As String, Optional wbWorkbook As Workbook) As Boolean
    If wbWorkbook Is Nothing Then Set wbWorkbook = ActiveWorkbook 'or ThisWorkbook - whichever appropriate
    Dim obj As Object
    Set obj = wbWorkbook.Sheets(strSheetName)
    SheetExists = True
    Exit Function
HandleError:
    SheetExists = False
End Function
Public Function IsValidSheetName(strSheetName As String) As Boolean
    IsValidSheetName = False
    If Len(strSheetName) = 0 Then Exit Function
    If Len(strSheetName) > ciMaxLenSheetName Then Exit Function
    Dim varSheetNameIllegalCharacters As Variant: varSheetNameIllegalCharacters = SheetNameIllegalCharacters
    Dim i As Integer
    For i = LBound(varSheetNameIllegalCharacters) To UBound(varSheetNameIllegalCharacters)
        If InStr(strSheetName, (varSheetNameIllegalCharacters(i))) > 0 Then Exit Function
    IsValidSheetName = True
End Function
Private Function SheetNameIllegalCharacters() As Variant
    SheetNameIllegalCharacters = Array("/", "\", "[", "]", "*", "?", ":")
End Function
then also add the following line at the top of the code module
Private Const ciMaxLenSheetName As Integer = 31
Jet Fusion
o_O Did I paste it wrong, getting compile error - syntax error :rolleyes: lol I'm not very good with VBA
Private Const ciMaxLenSheetName As Integer = 31Const cstrTitle As String = "Add new worksheet"
Dim strDefault As String: strDefault = "" 'setting initial value for inputbox can be useful
    Do
        GoSub ValidateInput
    Dim obj As Object
    obj.Name = strInput
HandleExit:
    Exit Sub
HandleError:
    Resume HandleExit
ValidateInput:
    Return
    Dim obj As Object
    SheetExists = True
    Exit Function
HandleError:
    SheetExists = False
End Function
    Dim i As Integer
End Function
End Function
Hui
Staff member
2 errors
see code below
    Do
        GoSub ValidateInput
    Dim obj As Object
    obj.Name = strInput
HandleExit:
    Exit Sub
HandleError:
    Resume HandleExit
ValidateInput:
    Return
    Dim obj As Object
    SheetExists = True
    Exit Function
HandleError:
    SheetExists = False
End Function
    Dim i As Integer
End Function
End Function
Jet Fusion
Hi @Hui ,
I have tried the code and it works for the 1st bit except it is not copying the sheet that I would like it to copy. I have this written but have no idea where to put it in your above code.
Worksheets("Sheet 1").Copy Before:=Sheets(Worksheets.Count)
Would it also be possible to change your code so that the new sheet it copies goes to infront of the current active tab?
Thanks in advance
Jet
