Help with Date look up please
adown
Hi everyone, I found this formula on date look up from this website. This is awesome. I didn't know Excel would do so much. Here is the formula I am using =IF(SUMPRODUCT(--(E6:E15<=F3)*(F6:F15>=F3))=1,"Row no. "&SUMPRODUCT(--(E6:E15<=F3)*(F6:F15>=F3),ROW(E6:E15))-5,"Not Found") . It is looking in column E and F, and returning a row number. What I would like to do is return text that is in the corresponding row in column G. I understand a little of whats going on, but I don't know how to tell it what to give me. Thanks, adown
Hui
Staff member
Adown
=IF(SUMPRODUCT(--(E6:E15<=F3)*(F6:F15>=F3))=1,"Row no. "&SUMPRODUCT(--(E6:E15<=F3)*(F6:F15>=F3),ROW(E6:E15)),"Not Found")
Does it for me
You will only get a valid result provided there is only 1 row that meets the criteria
adown
Yes, it does work. Let me explain myself. I am using this for positions held in my company. I have "from date" in column E,"to date" in column F, and "position held" in column G. Instead of returning the row # where the date is found, I would like to return the position held, which would be in the same row, but in the next column over. It seems simple enough, but I'm new at Excel. Thanks for your help, adown
Hui
Staff member
Adown
Try This beauty:
=IF(SUMPRODUCT(($E$6:$E$15<=$F$3)*($F$6:$F$15>=$F$3))=1,INDEX($G$6:$G$15,SUMPRODUCT(($E$6:$E$15<=$F$3)*($F$6:$F$15>=$F$3),ROW($E$6:$E$15))-ROW($G$5)),"Not Found")
adown
This retuns Not Found. I am using A2- A21 for from date, B2-B21 for to date, D2-21 for positions held, B25 for look up date, and B26 for results. Here is what I did to your formula to adapt it. I'm sure it works, I've done something wrong. Thanks again for your time, adown
=IF(SUMPRODUCT(($A$2:$A$21<=$B$25)*($B$2:$B$21>=$B$25))=1,INDEX($D$2:$D$21,SUMPRODUCT(($A$2:$A$21<=$B$25)*($B$2:$B$21>=$B$25),ROW($A$2:$A$21))-ROW($D$1)),"Not Found")
Hui
Staff member
It Works ok in those ranges
Not Found means there is either no data or 2 or more rows which have valid answers
Have you checked manually ?
adown
Yes, It works. After I wrote last, I saved and shut down. After getting ready for work, I decided maybe I missed something even though I checked everything 10 times. after a computer restart, it was working flawlessly. It wouldn't work until I shut down. Strange. Thank you very much for your formula and subsequent help, it works like a charm. adown
