I wanted to get how many numbers in the list of range numbers are equal to 305.
For ex,there are range of values like 100-110,320-350,405-415,430-445 like this there are around 100 ranges i want to know which formula can give all the range details.
Thanks for the reply it is working with the ranges as you said.
I have another query can this IF formula work with Vlookup formula since i have that requirement also of bringing the column data.if it is possible can you give that example .
