Error in macro - Index refers
Dee
Dear All,
I am getting the following error "Index refers beyond end of list" in the row presented within astricks (***)when i try to run this macro. I have two tabs called 'Project Managers' & 'Project List' in the file and at present i have only 4 names in Project Managers tab. The will grow in future.
Sub getprojects()
Dim Ftwbook As Workbook
Dim Thiswbook As Workbook
Dim LastPM, LastCell, RIndex, counter As Integer
Dim Wksheet As Worksheet
Dim Flatfilename As String
Dim Filewithmacro As String
Flatfilename = Application.GetOpenFilename(FileFilter:="Excel files (*.xls), *.xls", Title:="Please choose a file")
Filewithmacro = ThisWorkbook.Name
Set Ftwbook = Workbooks.Open(Filename:=Flatfilename, ReadOnly:=yes)
Set Thiswbook = Workbooks(Filewithmacro)
ThisWorkbook.Worksheets("Project Managers").Activate
Range("A1").Select
LastCell = ActiveCell.SpecialCells(xlCellTypeLastCell).Row
ReDim PM(LastCell) As String
For counter = 0 To LastCell - 1
PM(counter) = ActiveCell.Value
ActiveCell.Offset(1, 0).Activate
Next counter
Thiswbook.Worksheets("Project List").Activate
Range("A4", Range("A4").SpecialCells(xlCellTypeLastCell).Address).Rows.ClearContents
Ftwbook.Activate
Ftwbook.Worksheets("Flat File").Select
Range("Z4").Select
LastPM = ActiveCell.SpecialCells(xlCellTypeLastCell).Row
RIndex = 4
For counter = 0 To LastPM - 1
For Index = 0 To LastCell - 1
If ActiveCell.Value = PM(Index) Then
ActiveCell.EntireRow.Copy
ActiveSheet.Paste Destination:=Range(Cells(RIndex, 1), Cells(RIndex, 1))
Ftwbook.Worksheets("Flat File").Activate
RIndex = RIndex + 1
Exit For
Next Index
Next counter
Ftwbook.Close SaveChanges = no
'Call LastRowofPM
Thanking you in advacne
Dee
Sorry i have not highlighted the error row
The error i am getting is in 13th row ie., ***ThisWorkbook.Worksheets("Project Managers").Activate***
Thanks,
TessaES
Dee,
To me, that error sounds like the worksheet is not present in the workbook you refer to.
Just before the line with the error, you define names for two workbooks: Ftwbook and Thiswbook. But on the line with the error you refer to ThisWorkbook. Are you referring to the correct workbook?
Also, check the worksheet name for any typing errors and leading or trailing spaces.
Dee
Thanks for this.
But i tried all these things but still i am not getting the reason why i am getting this error
Dee...
Hui
Staff member
Dee
Your 2 lines
Shouldn't the second line be
Thiswbook.Worksheets("Project Managers").Activate
