Dr. Demento
I'm stuck in how to replace a term with the appropriate VBA code. The goal is to have a dynamic hyperlink that changes not only anchor but also the Display Text. I realize the code as it stands is circular, but I can figure out how to make it work if I could only get the syntax correct.
The original looks like this:
However, I want replace rtsDisplayText term with the VBA equivalent of this code the from Macro Recorder:
where Sheet2!R11C11 = gnrAnchor.Parent.name & "'!" & gnrAnchor.Address
Thanks y'all.
BTW, I'm cross-posting from here.
Function Hyperlink_dynamic(gnrAnchor As range, _
rtsDisplayText As String) As String
' ~~ Puts a dynamic hyperlink formula in the destination cell. _
Formula automatically adjusts if its target is moved.
' http://www.vbaexpress.com/kb/getarticle.php?kb_id=237
Dim strPath As String
'This next statement avoids an error if the target workbook hasn't been saved
If gnrAnchor.Parent.Parent.path <> vbNullString Then _
strPath = gnrAnchor.Parent.Parent.path & Application.PathSeparator
Hyperlink_dynamic = "=HYPERLINK(""[" & strPath & gnrAnchor.Parent.Parent.name & "]"" & " & _
"CELL(""address"",'" & gnrAnchor.Parent.name & "'!" & gnrAnchor.Address & "),""" & _
rtsDisplayText & """)"
End Function
Hyperlink_dynamic = "=HYPERLINK(""[Book1]"" & _
CELL(""address"",Sheet2!R11C11), _
CELL(""address"",Sheet2!R11C11))"
Thanks y'all.
