Combining scatter charts with quadrants or other charts
mrivadeneirap
Hi Chandoo and everybody:
We all know that scatter charts are excellent to plot X Y data, however in many ocasions you need to show such data on top of a parametrized section, such as a quadrant or a matrix. I wonder if any of you have worked with these type of challenges. I tried to work on a program like this. First a I intented to use X Y error bars to establish a perimeter around certain data, but it was difficult and cumbersome to define and almost impossible to fill the permiter area with color. Finally I ended up "cheating" the system and created two different files and grouped them for this purpose. Please take a look to the adjoining file and let me know a better way to do it.
Marcelo
http://tinyurl.com/Scatter-Risk-Graph
Marcelo
This is a simple chart but a little bit messy to make
Firstly, Make the Background Risk Areas as 3 series of a Stacked Area chart, this will be on the Primary Y axis.
You will need to change your values on the Risk Area sheet accordingly as they are now stacked
Then add a new series for the Scatter Chart
Initially add it as data and just use the Y values for the Scatter Chart
Select the series and Change its Axis to the secondary Y Axis
Change the Chart type to Scatter
Then add the X Axis range
Adjust Axis ranges
Add labels
Format to suit
If that is too complicated I've done it for you here: https://rapidshare.com/files/116107600/Scatter_Risk_Graph_REV3_Hui.xls
Hi Hui:
Thanks for your answer. However I have problems downloading it from Rapidshare. Would you be so kind to send it through a different service provider. Thanks.
Best regards,
Marcelo
The above link works fine (i just tested it)?
Try here :(
http://chandoo.org/wp/wp-content/uploads/2012/02/Scatter_Risk_Graph_REV3_Hui.xls
I am trying to modify this example to create a scatter with a "box" on the scatter with the exterior points that aren't "square" (203.157, -64.185, 203.097, -64.245). I would like for the this serve as control limits of sorts for some measurement data.
The data I want to place in it looks like this.
203.113 -64.211
203.111 -64.21
203.116 -64.211
203.111 -64.21
203.118 -64.212
203.116 -64.212
203.146 -64.221
203.122 -64.213
203.121 -64.213
203.112 -64.21
203.103 -64.207
203.114 -64.211
203.109 -64.209
203.108 -64.209
203.101 -64.207
203.115 -64.211
203.114 -64.211
203.116 -64.211
203.111 -64.21
203.114 -64.211
203.116 -64.212
203.11 -64.21
203.109 -64.209
203.103 -64.207
203.109 -64.209
203.118 -64.212
203.108 -64.209
any help or links to other posts would be much appreciated.
Sorry the data points for the exterior square are
203.157 -64.185
203.097 -64.245
203.157 -64.245
203.097 -64.185
I just modified this example..... brain does not work hard until I post something and dont want someone to figure it out first.
I just added 4 new series to create the box. Duh!!!
http://www.analyticshero.com/2012/09/11/how-to-use-scatterplot-quadrant-analysis-with-your-web-analytics-data/
Rebelmrd
I was going to say just a dd a new series to the chart and setup coordinates as appropriate
Have you solved your problem now?
