Advanced Filter - VBA code
vinu
Hello Team,
How do I use advanced filter in vba code. code should select all the data and put advance filter and conditon(i listed in sheet2 a1:d4 including heading) after filtering the same it should delte the same filtered rows by visible cells (make sure it should not delte the heading). and code should ends with normal view(with out filter.
Thanks,
Vin.
Hui
Staff member
Vinu
In VBA
Data_Range.AdvancedFilter xlFilterCopy, Criteria_Range, Filtered_Range
Data_Range is the range of your source data including heading
eg: A1:F1000 or a dynamic range etc
Criteria_Range is a range which includes your criteria and values that apply to that
eg:
[pre]
Age    Name   Year
10     Fred   1963
[/pre]
Filtered range is a Range which has a list of the Fields you want returned
eg: Age Name Year etc etc in a single row
Example
[data].AdvancedFilter xlFilterCopy, [crit], [filtered]
data, crit and filtered are named ranges
or
Range("A1:D1000").AdvancedFilter xlFilterCopy, range("g1:J2"), Worksheets("Sheet2").Range("A1:D1")
