xls bug - help for solving it !!
DAGUET
Hi all
this GIF shows you what my problem is and despite digging into forums etc.... without success - copy/paste the link into your browser
C:\Users\p.daguet\Desktop\xls bug\xls bug.html
maybe you could help me
many thanks!!
Do you think we have direct access to your pc to open that link. Pls share a open link so that we can visualize it.
Very strange problem.
Does this happen with all workbooks ?
Is there any macro running from your Personal workbook ?
Do you have any Addin's installed or enabled ?
Do you have any Conditional Formats applied to the worksheet?
If you re-install great
After you remove Excel, shutdown and restart the computer manually, don't do a Windows, restart
Try using a few existing workbooks and a few new workbooks before you install the Thomson Reuters Eikon add-in
Then install the add-in and check again
If the probvlem persists I'd check with Thomson Reuters Eikon
