When Running Long Macros Is It Better To?...
When running long macros is it more efficient-faster to break them up into individual subs, or to combine them all with one set of references (Dims, Ranges, etc..) ?
Anything that gets repeated/called out several times should probably be a seperate macro. It's also handy simply for debugging purposes to have breaks whenever a major change has happened (say, open workbook B, sort, copy, paste, do some stuff in workbook A. Would be nice to have the stuff in workbook A be a seperate macro in case I want to skip the first part).
Gotcha, definitely with major event changes breaking is best.
But by repeated does that include "MyRange" as well?
I set it at the top once, and I reference it dozen times.
Is this okay?
Yes, you'd want your module definitions called out before all the subs, like:
Dim MyRange as Range
Dim MyString as String
Sub FirstMacro()
'blahblahblah
Sub SecondMacro()
'more stuff
