supersonic373
Hi All - First time to post so thanks in advance for the help in responses.
I have a data set as below where customers receive certain % rebate from a
product. I am putting together a sheet for someone to be able to use a pull down
in a cell to select the product and the customer, then automatically using vlookup
or other solution, to locate the correct % rebate based on what is selected on these
two pull down selections (Customer Name & Product#). Based on the % rebate then
other calculations are performed before providing the user with a result.
Customer Name Product1 Product2 Product3
ABC x% y% x%
DEF f% x% e%
EFG e% g% y%
Thanks again for any responses/solutions. Ron
ABC x% y% x%
DEF f% x% e%
EFG e% g% y%
