VBA_HELP_02/19/2015
Ravindra
Hi All,
Greetings for the day !!!!
I am having problem with attached file. It is filling cells while selecting "September" month from combo box. Please see it and help me to fix this problem.
Many-many thanks...
  • Jan-2015.xlsm
Ravindra
That was bizarre, as the code looked, at a quick glance, to be fine
I would change your code to that as per below:
Private Sub ComboBox1_Change()
Dim month As String
month = ComboBox1.Value
Sheet1.Columns("C:BV").EntireColumn.Hidden = True
Select Case month
Case Is = "Show All"
Sheet1.Columns("c:bv").EntireColumn.Hidden = False
Case Is = "January"
Sheet1.Columns("C:H").EntireColumn.Hidden = False
Case Is = "February"
Sheet1.Columns("I:N").EntireColumn.Hidden = False
Case Is = "March"
Sheet1.Columns("O:T").EntireColumn.Hidden = False
Case Is = "April"
Sheet1.Columns("U:Z").EntireColumn.Hidden = False
Case Is = "May"
Sheet1.Columns("aa:af").EntireColumn.Hidden = False
Case Is = "June"
Sheet1.Columns("ag:al").EntireColumn.Hidden = False
Case Is = "July"
Sheet1.Columns("am:ar").EntireColumn.Hidden = False
Case Is = "August"
Sheet1.Columns("as:ax").EntireColumn.Hidden = False
Case Is = "September"
Sheet1.Columns("ay:bd").EntireColumn.Hidden = False
Case Is = "October"
Sheet1.Columns("be:bj").EntireColumn.Hidden = False
Case Is = "November"
Sheet1.Columns("bk:bp").EntireColumn.Hidden = False
Case Is = "December"
Sheet1.Columns("bq:bv").EntireColumn.Hidden = False
End Select
