VBA Used Column range
senthil murugn
Need a macro to count the no of specific task name (strings) in Column A.
When used the following code it is working fine but takes too much time (go over the excel's maximum column count)
Set myrange = Worksheets("Sheet1").Range("A:A")
But when used the following code it ends up with error.
Set myrange = Worksheets("Sheet1").UsedRange.Columns("A")
Could you please provide any other alternative workaround.
Thanks & regards
Senthil
Belleke
Sub Task_Cnt()
Dim ANSYS As Integer, MATLAB As Integer, MPASM As Integer
For Each c In Sheets("Sheet1").UsedRange.Columns(1).Cells
    If c.Value = "Ansys" Then ANSYS = ANSYS + 1
    If c.Value = "Matlab" Then MATLAB = MATLAB + 1
    If c.Value = "Mpasm" Then MPASM = MPASM + 1
Next c
MsgBox "# of Ansys: " & (ANSYS)
MsgBox "# of Matlab: " & (MATLAB)
MsgBox "# of Mpasm: " & (MPASM)
Marc L
Hi, no such error on my side with your attachment and as it is the right way to proceed even if the Range variable is useless …​
Marc L
According to the attachment an Excel basics VBA demonstration :​
Sub Demo1()
             Dim V, S$
    With Sheet1.UsedRange.Columns
        For Each V In [{"Ansys","Matlab","Mpasm"}]
            S = S & V & " : " & Application.CountIf(.Item(1), V) & vbLf & vbLf
        MsgBox S
Belleke
This remark pisses me off, maybe in Paris it is basic, for most users this is not basic. Respect please!
Marc L
Cool down big head ‼ There is no remark about you within my previous post, do not misread, thanks !​
According to TEBV rule, for good enough readers only :rolleyes: :​
