VBA to write a formula in column if cell not empty
aggie81
I don't know VBA and asking for help on learning VBA to write a formula in column C if the cell in column A is not empty.
I have attached a workbook with the formula and the way I am using now is to put the formula in more cells than the user will use.
The user may add comments to explain what they want done by the people doing the work and each row doesn't need a formula based on the contents of column A.
I thought about using a Table format but it doesn't copy the formula if there user adds a blank line above.
Can VBA apply row formatting?
Any help is appreciated.
Thank you.
Hui
Staff member
Aggie81
Try the following:
Sub x()
Dim LR As Integer
LR = Range("A" & Rows.Count).End(xlUp).Row
Dim c As Range
For Each c In Range(Cells(5, 1), Cells(6, 1))
   If c.Value <> "" Then c.Offset(0, 2).Formula = "=XLOOKUP(A" + CStr(c.Row) + ",Items[ITEMNO],Items[DESC],"""",0)"
Next c
aggie81
I'm not sure I have done it correctly but I can't get it to work.
When I type the item number in A36 it should write the formula in C36 but I can't get it to work.
75955
I hope I have included enough for you to see what I've attempted.
Hui
Staff member
If Intersect(ActiveCell, Range("A:A")) Is Nothing Then Exit Sub
If Target.Value <> "" Or Target.Value <> " " Then Target.Offset(0, 2).Formula = "=XLOOKUP(A" + CStr(c.Row) + ",Items[ITEMNO],Items[DESC],"""",0)"
Hui
Staff member
That code has to be in the Marciela Worksheet Object
You also have to save the file a s a *.xlsm or *.xlsb file type
aggie81
I got the code to run but there is a Debug box that returns.
75993
75995
The formula should go in the C36 cell.
Thank you for being patient with me and helping.
Hui
Staff member
I have changed the Worksheet event that is used to trigger the code and added a few tweaks
Replace the existing code with the code below:
If Target.Value <> "" Or Target.Value <> " " Then Target.Offset(0, 2).Formula = "=XLOOKUP(A" + CStr(Target.Row) + ",Items[ITEMNO],Items[DESC],"""",0)"
Enjoy...
