VBA to centre range of images in cells
darb79
I need to resize images that come from a filepath to 90% of size of cell they are being placed over then centre the image in the cell. Here is my VBA:
Sub AddPictures()
Dim myPic As Picture
Dim wkSheet As Worksheet
Dim myRng As Range
Dim myCell As Range
Dim rowCount As Long
Dim rowCount2 As Long
Set wkSheet = Sheets(1) ' -- Change to your sheet
'-- The usual way of finding used row count for specific column
rowCount2 = wkSheet.Cells(wkSheet.Rows.Count, "A").End(xlUp).Row
If rowCount2 <> 0 Then
Set myRng = wkSheet.Range("A2", wkSheet.Cells(wkSheet.Rows.Count, "A").End(xlUp))
For Each myCell In myRng.Cells
If Trim(myCell.Value) = "" Then
MsgBox "No file path"
ElseIf Dir(CStr(myCell.Value)) = "" Then
MsgBox myCell.Value & " Doesn't exist!"
ActiveSheet.Shapes.AddPicture _
Filename:=myCell.Value, LinkToFile:=msoFalse, _
SaveWithDocument:=msoTrue, _
Left:=myCell.Offset(ColumnOffset:=1).Left, Top:=myCell.Top, _
Width:=myCell.Width, Height:=myCell.Height
Next myCell
MsgBox "There is no file paths in your column"
Enjoy
Sub AddPictures()
Dim myRng As Range
Dim myCell As Range
Dim factor As Double
factor = 0.9
  Filename:=myCell.Value, _
  Left:=myCell.Offset(ColumnOffset:=1).Left + (myCell.Offset(, 1).Width - myCell.Offset(, 1).Width * factor) / 2, _
  Top:=myCell.Top + (myCell.Offset(, 1).Height - myCell.Offset(, 1).Height * factor) / 2, _
  Width:=myCell.Offset(, 1).Width * factor, _
  Height:=myCell.Offset(, 1).Height * factor
  Next myCell
