I would like to be able to check my data and if the word "Type" Column A and "*Essentials*" Column J (would need to use a wildcard) not on the same rows is found then add a row and add the words Play > Essentials. I only need this to happen once for a Heading, and then to look further down my data for other words like "Elevate" or "Orbit" and do the same thing with the word Play > Elevate or Play > Orbit
Data is on Sheet (ProductsCopied) and is getting copied from another Sheet (Products)
The macro attached can be updated for this to happen but I dont know how to.
Sub FilteredDataSelection()
Dim wsProducts As Worksheet
Dim wsProductsCopied As Worksheet
Dim wsPriceList As Worksheet
Dim lngLastrow As Long
Dim strCategory As String
Dim i As Integer
Dim rngCategories As Range
Dim c As Range
Dim rng As Range
Dim intRow As Integer
Dim LastRow As Long, erow As Long
Call subDeleteWorksheet("ProductsCopied")
Sheets.Add.Name = "ProductsCopied"
' Create Price List sheet.
'Worksheets.Add After:=Worksheets("ProductsCopied")
'ActiveSheet.Name = "Price List"
Set wsPriceList = Worksheets("Price List")
Set wsProductsCopied = Worksheets("ProductsCopied")
Set wsProducts = ThisWorkbook.Worksheets("Products")
'-----PLAY > ESSENTIALS
Sheets("Products").Activate
ActiveSheet.ShowAllData
On Error GoTo 0
ActiveSheet.Range("A1:ADU5000").AutoFilter Field:=11, Criteria1:="=*Essentials*"
wsProducts.AutoFilter.Range.SpecialCells(xlCellTypeVisible).Copy 'copy the AF first
Set rng = wsProducts.UsedRange.Offset(0, 1)
Set rng = rng.Resize(rng.Rows.Count)
rng.Copy
Sheets("ProductsCopied").Activate
lr = ThisWorkbook.Worksheets("ProductsCopied").Cells(1, 1).SpecialCells(xlCellTypeLastCell).Row + 1
Range("A" & lr).PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks _
:=False, Transpose:=False
LastRow = Cells(Rows.Count, 1).End(xlUp).Row
For i = 1 To LastRow
If IsEmpty(Cells(i, 1)) Then
Cells(i, 2).Value = "Play > Essentials"
'End If
'Next i
'-----PLAY > ELEVATE
On Error GoTo 0
ActiveSheet.Range("A1:ADU5000").AutoFilter Field:=11, Criteria1:="=Play > Elevate*"
rng.Copy
lr = ThisWorkbook.Worksheets("ProductsCopied").Cells(1, 1).SpecialCells(xlCellTypeLastCell).Row + 2
Cells(i, 2).Value = "Play > Elevate"
'End If
'Next i
'-----PLAY > ORBIT
On Error GoTo 0
ActiveSheet.Range("A1:ADU5000").AutoFilter Field:=11, Criteria1:="=*Orbit,*"
rng.Copy
ActiveWorkbook.Save
