Hello all,
I'm attempting to setup some code so that when a table header is double clicked, the column will automatically sort (ascending). If double clicked again, it will sort the other way (descending).
I've put together bits and pieces to come up with the below code, but I'm not very familiar with VBA. When I double click the header, the column turns light gray - which is part of the code - but no sorting occurs. Any thoughts on what I'm doing wrong?
Other details:
My table is named "Summary"
It is sitting in cells B4 - Q1003 (with headers in row 4)
I'm using Excel 2011 for Mac
Many thanks!
Other details:
Many thanks!
Private Sub Worksheet_BeforeDoubleClick(ByVal Target As Range, Cancel As Boolean)
Dim rngTable As Range
Dim rngActiveColumn As Range
Dim rngOneCell As Range
Dim intSortOrder As Integer
Dim blnNumericCol As Boolean
Dim intExistingSortOrder As Integer '0: unsorted, 1: ascending, 2: descending
Dim intNewSortOrder As Integer
Dim strFormula1 As String
Dim strFormula2 As String
' Exit sub if double click outside of defined table range name "SummaryTable"
If Application.Intersect(ActiveCell, Range("Summary").Cells) Is Nothing Then Exit Sub
' Define the ranges of the table and of the active column
Set rngTable = Range("Summary")
Set rngActiveColumn = _
Range("Summary").Cells(2, ActiveCell.Column - Range("Summary").Cells(1, 1).Column + 1).Resize(Range("Summary").Rows.Count - 1, 1)
' Check if the active column contains numbers or alphanumeric data
blnNumericCol = True
For Each rngOneCell In rngActiveColumn
If Not IsNumeric(rngOneCell) Then
blnNumericCol = False
Exit For
Next rngOneCell
' Check if the column is sorted and detect the existing sort order (create array formula strings to be evaluated)
strFormula1 = "AND(" & rngActiveColumn.Resize(rngActiveColumn.Rows.Count - 1, 1).Address & ">=" & _
rngActiveColumn.Resize(rngActiveColumn.Rows.Count - 1, 1).Offset(1, 0).Address & ")"
strFormula2 = "AND(" & rngActiveColumn.Resize(rngActiveColumn.Rows.Count - 1, 1).Address & "<=" & _
If Evaluate(strFormula1) Then
intExistingSortOrder = 2
ElseIf Evaluate(strFormula2) Then
intExistingSortOrder = 1
intExistingSortOrder = 0
' Set the new sort order
Select Case intExistingSortOrder
Case 0:
If blnNumericCol Then
intNewSortOrder = xlDescending
intNewSortOrder = xlAscending
Case 1: intNewSortOrder = xlDescending
Case 2: intNewSortOrder = xlAscending
End Select
' Sort the table
rngTable.Offset(1, 0).Sort Key1:=Cells(rngTable.Row + 1, ActiveCell.Column), Order1:=intNewSortOrder, Header:=xlNo, OrderCustom:=1, MatchCase:=False, Orientation:=xlTopToBottom
' Optional: Set the fill color of the sorted column to a light grey
rngTable.Offset(1, 0).Resize(rngTable.Rows.Count - 1, rngTable.Columns.Count).Interior.ColorIndex = xlNone
rngActiveColumn.Interior.Color = RGB(234, 234, 234)
' Clean up
Set rngTable = Nothing
Set rngActiveColumn = Nothing
Set rngOneCell = Nothing
