Pilot5000
I have a worksheet with the following information
Cell F3 contain drop list for different currencies & percentage
Cell E3 contain the symbol of each currency & percentage according to F3
Column I trough K contain numbers and percentages
Presently I have a code that I got from the web that change the currency symbol based on the selection in Cell E3 in all columns
I need a code that go through columns I-K and change only the numbers that are with currency symbol and not the number with percentage (%) symbol, or if I select in F3 percentage (%) it will change only the number with percentage format
My other problems is that when the as you can see column -”I18”, when number is negative it does not take the currency symbol but only the number, I need to have also the currency symbol
Thank you all for your collaboration
