VBA - Download all documents using URLs & Save As to folder as same extension documents
Gunasekaran
Hi Team
I wonder whether someone can help me.
Hyperlink had a different type of extension like .xlsx. xls, pdf, .msg documents, all document should download and save in folder as the same Extention
Could someone possibly tell me please is there a way by which I can amend the code. this code is work as if document as .xlsx, but Other Extention not able to download through macro
To help this is the code that I use to create the list of files.
Declare Function URLDownloadToFile Lib "urlmon" _
Alias "URLDownloadToFileA" (ByVal pCaller As Long, _
ByVal szURL As String, ByVal szFileName As String, _
ByVal dwReserved As Long, ByVal lpfnCB As Long) As Long
Dim Ret As Long
'~~> This is where the images will be saved. Change as applicable
Const ParentFolderName As String = "\\gssux002\GBS_CHE_GL_TMS\ICV\"
Sub Download_Report()
Dim ws As Worksheet
Dim LastRow As Long, i As Long
Dim Folderpath, strPath As String
Set ws = Sheets("ICV Report")
LastRow = ws.Range("A" & Rows.Count).End(xlUp).Row
For i = 2 To LastRow
Folderpath = ParentFolderName & ws.Range("A" & i).Value & "\"
If Len(Dir(Folderpath, vbDirectory)) = 0 Then
MkDir Folderpath
strPath = Folderpath & ws.Range("A" & i).Value & i & "*.*"
Ret = URLDownloadToFile(0, ws.Range("H" & i).Value, strPath, 0, 0)
If Ret = 0 Then
ws.Range("I" & i).Value = "File successfully downloaded"
ws.Range("I" & i).Value = "Unable to download the file"
MsgBox "Completed This process !!!", vbInformation
  • ICV Auto Download Report.xlsm
Perhaps because your file macro is still using the following line of code ?
strPath = Folderpath & ws.Range("A" & i).Value & i & ".xlsx"
