VBA conditional formatting - multiple in same range
cacos
Hi!
Trying to figure out why this conditional formatting code (Excel 2007) is not working. It's two relative conditions:
- one adds borders on an entire range if the first cell in that row is not empty.
- the other condition colors a cell in just column1 of that range, if that cell is equal to a named range called "SetVal" (I'm using the mouseover technique from Chandoo).
Sub Format_Range()
    With Sheet1.Range("A1:C40")
        .FormatConditions.Delete
        .Activate
        .FormatConditions.Add xlExpression, Formula1:="=$A1<>"""""
        .FormatConditions(1).Borders.LineStyle = xlContinuous
        .FormatConditions(1).Borders.ThemeColor = 1
        .FormatConditions(1).Borders.TintAndShade = -0.249946592608417
        .FormatConditions(1).Borders.Weight = xlThin
        .FormatConditions(1).StopIfTrue = False
    With Sheet1.Range("A1:A40")
        .FormatConditions.Add xlExpression, Formula1:="=$A1=SetVal"
        .FormatConditions(1).Interior.Color = 5
Any help is appreciated. Thanks!
Try changing the code as per:
        .FormatConditions(2).Interior.Color = 5
        .FormatConditions(2).StopIfTrue = False
