lloydbangera
Dim m_astrOldFilePaths() As String
Dim m_lngOldFileCount As Long
Public Sub ZipOldFiles()
'+++ RUN THIS PROCEDURE +++
Dim vntAgeInMonths
Dim vntFolderPath
Dim vntFilePath
Dim lngZipCount As Long
Dim wksResults As Worksheet
On Error GoTo ErrorHandler
Erase m_astrOldFilePaths
m_lngOldFileCount = 0
vntFolderPath = GetFolderPath()
If IsEmpty(vntFolderPath) Then Exit Sub
vntAgeInMonths = GetAgeInMonths()
If IsEmpty(vntAgeInMonths) Then Exit Sub
Call GetOldFilePaths(CStr(vntFolderPath), CInt(vntAgeInMonths), True)
If m_lngOldFileCount > 0 Then
Set wksResults = ThisWorkbook.Sheets("ZIP RESULTS")
If wksResults Is Nothing Then
Set wksResults = ThisWorkbook.Sheets.Add()
wksResults.Name = "ZIP RESULTS"
wksResults.Activate
wksResults.Cells.Clear
wksResults.Range("A1").Value = "The following files were zipped."
wksResults.Range("A1").Font.Bold = True
For Each vntFilePath In m_astrOldFilePaths
If ZipFile(CStr(vntFilePath)) Then
lngZipCount = lngZipCount + 1
wksResults.Range("A" & lngZipCount + 2).Value = vntFilePath
Kill vntFilePath ' <-- Only uncomment after testing!
Next vntFilePath
MsgBox "Macro run is complete!"
'' MsgBox Format(lngZipCount, "#,0") _
'' & " of " & Format(m_lngOldFileCount, "#,0") _
'' & " old files were zipped successfully.", vbInformation
''MsgBox "No files over " & vntAgeInMonths _
'' & " month(s) old were found.", vbInformation
Exit Sub
ErrorHandler:
MsgBox Err.Description, vbExclamation
Private Function GetAgeInMonths()
Dim blnValid As Boolean
Dim strInput As String
Dim dblInput As Double
Do
strInput = InputBox("Enter age in months:", "Zip Old Files", 3)
If strInput <> vbNullString Then
If IsNumeric(strInput) Then
dblInput = Val(strInput)
If dblInput = Int(strInput) Then
Rem --------------------------------------------------------------------------------------- Condition for age
If dblInput >= 0 And dblInput <= 6 Then
blnValid = True
If Not blnValid Then
MsgBox "You must enter a whole number between 1 and 6.", vbExclamation
Loop Until (strInput = vbNullString) Or blnValid
If strInput = vbNullString Then
GetAgeInMonths = Empty
GetAgeInMonths = Int(strInput)
Exit Function
ErrorHandler:
End Function
Private Function GetFolderPath()
Const msoFileDialogFolderPicker = 4
Dim objFolderPicker As Object
Set objFolderPicker = Application.FileDialog(msoFileDialogFolderPicker)
objFolderPicker.Title = "Zip Old Files"
objFolderPicker.ButtonName = "Select Folder"
If objFolderPicker.Show() Then
GetFolderPath = objFolderPicker.SelectedItems(1)
Exit Function
ErrorHandler:
GetFolderPath = Empty
End Function
Private Sub GetOldFilePaths(strFolderPath As String, _
intAgeInMonths As Integer, _
Optional blnRecursive As Boolean = False)
Dim objFileSystem As Object
Dim objSubfolder As Object
Dim objFolder As Object
Dim objFile As Object
Set objFileSystem = CreateObject("Scripting.FileSystemObject")
Set objFolder = objFileSystem.GetFolder(strFolderPath)
On Error GoTo FileError
For Each objFile In objFolder.Files
Rem ---------------------------------------------------------------------- Check for age of file Date Accessed/ Date Created
' DateLastAccessed
' DateCreated
' DateLastModified
If objFile.DateLastAccessed < DateAdd("m", -intAgeInMonths, Now()) Then
m_lngOldFileCount = m_lngOldFileCount + 1
ReDim Preserve m_astrOldFilePaths(1 To m_lngOldFileCount)
m_astrOldFilePaths(m_lngOldFileCount) = objFile.Path
GoTo NextFile
FileError:
Err.Clear
Resume NextFile
NextFile:
Next objFile
If blnRecursive Then
On Error GoTo SubfolderError
For Each objSubfolder In objFolder.SubFolders
Call GetOldFilePaths(objSubfolder.Path, intAgeInMonths, True)
GoTo NextSubfolder
SubfolderError:
Err.Clear
Resume NextSubfolder
NextSubfolder:
Next objSubfolder
Set objFileSystem = Nothing
Set objSubfolder = Nothing
Set objFolder = Nothing
Set objFile = Nothing
Private Function ZipFile(strFilePath As String) As Boolean
Dim strParentFolderPath As String
Dim strBaseFileName As String
Dim strZipFilePath As String
Dim blnError As Boolean
Dim objShell As Object
Dim cnt As Variant
strParentFolderPath = objFileSystem.GetParentFolderName(strFilePath) & "\"
strBaseFileName = objFileSystem.GetBaseName(strFilePath)
cnt = objFileSystem.GetFolder(strParentFolderPath).Files.Count
strZipFilePath = strParentFolderPath & strBaseFileName & ".zip"
Dim sFile As Variant, ExtFind As Variant
sFile = Dir(strParentFolderPath & strBaseFileName & "*")
ExtFind = Right$(sFile, Len(sFile) - InStrRev(sFile, "."))
If ExtFind = "zip" Then
blnError = False
GoTo ExitHandler
Debug.Print ExtFind
objFileSystem.CreateTextFile(strZipFilePath, True).Close
Set objShell = CreateObject("Shell.Application")
objShell.Namespace(CVar(strZipFilePath)).CopyHere CVar(strFilePath)
Rem ------------------------------------------------------------------------------ Wait time
Do
Application.Wait (Now + TimeValue("00:00:05"))
Loop Until objShell.Namespace(CVar(strParentFolderPath)).Items.Count <> cnt
''Application.Wait (Now + TimeValue("00:00:20"))
ExitHandler:
ZipFile = Not blnError
If ExtFind = "zip" Then ZipFile = False
If blnError Then objFileSystem.DeleteFile strZipFilePath
Set objShell = Nothing
Exit Function
ErrorHandler:
blnError = True
Resume ExitHandler
End Function
