VBA code to create folder and inside create workbook
Vanadu
I need help with VBA code to make a folder - in the same folder where is the file I run macro. That folder must have the name from cell A4. In this folder I need to create excel file named from cell A6.
Example:IF in cell A4 is TTX and in cell A6 is 111. I need to create folder named TTX an inside to create file 111.xls or 111.xlsx.In this file 111.xls must be copyed - with formathing - all data between column F and column ATfrom the file I run macro.
Sorry for my bad English.
kchiba
Hi Vanadu,
If the folder is with the same name as the file with the macro, then it already exists, so you do not need to create it, is that correct?
Vanadu
Hi, kchiba,
The name file with macro is TEST. So I need a VBA cod to make folder - with the name find in cell A2 (in this example is TTX). The excel file created in this folder will be teh name from cell B2 (in this example is 111.xls).
Hope you understand.
kchiba
Hi Vanadu,
Try this code
Sub folder_file()
vFolder = ThisWorkbook.Sheets("Sheet1").Range("A2") 'Note folder name must include full path
vFile = ThisWorkbook.Sheets("Sheet1").Range("b2") 'include .xls in the name
MkDir vFolder
On Error GoTo 0
ThisWorkbook.SaveAs Filename:=vFolder & "" & vFile, FileFormat:=xlExcel8
