chris heath
Hi Guys,
Please can anyone help with the code to click the link in the following:
<A style="COLOR: black" href="../track/detail.do?ID=2473543">2473543</A>
The ID number at the end of the link will be changing,
(I found when I copied the ID from another excel sheet the format it copied it in will not work as a direct link to the page a I need unlike is I type it in but I cant see anything different on the format options.
so can someone help with getting a code to click the link that is above or a way to change the format so its the same as if I typed it?
