Hi Suri,
You can do this without VBA and using some tricks..
* Select the column with "NoWebsite"
* Apply Filter on "NoWebsite". (select the cell with word as "NoWebsite" , Right Click and select
Filter > Filter by selected Cell's Value)
* Select Whole Column and Insert a New Column. (Ctrl + '+')
* Select all the blank cell correspondent to "NoWebsite". (Alt +
, Write "X" and (Ctrl + Enter)
* Now Remove all Filter. (Ctrl + Shift + L)
* Select the top "X" to the Bottom "X" and Move One Cell Below the current position. i.e If top cell is A5, then Move whole Set of "X" to A6.
* Now Re-apply Filter in "X". (select the cell with word as "X" , Right Click and select Filter > Filter by selected Cell's Value)
* Select all the blank cell correspondent to "X". (Alt +
* Insert New ROW.
* Delete the Extra added Column ("X").
* Remove all Filter (Alt D F F)
It only look like a long Task, but believe me, its much easier than the reading this post.
I am sharing this trick only because, we tried to solve your problem using VBA, but we are not getting any proper response, as I think you are not satisfied or not able to handle the case.
http://chandoo.org/forums/topic/vba-code-required-1
http://chandoo.org/forums/topic/vba-code-required-2
Please let us know, if have choose any of the option from above or share if you have any difficulties to apply VBA.
Deb
